Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      09-20-2022, 08:06 PM   #23
forcefed
forcefed's Avatar
Drives: .
Originally Posted by BLKSAPPE92 View Post
I don't think theirs enough to machine you can pad slap them. My previous M3 and m4 when brakes were needed the rotors were at 1mm or less. Also all bmw before that i never had a performance cars rotors that weren't under spec at brake change.
What I'm trying to say is you might get away with a pad slap but most likely not its brakes and rotors
Those dinky little pads in the back wear out the whole rotor? I hope not
      09-22-2022, 03:58 PM   #24
BLKSAPPE92
BLKSAPPE92's Avatar
Drives: 22 G80 Sao Paulo Yellow
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
They definitely don't wear the entire thing they create lips around the edges or grooves across the pad contact patch and to machine them out you would mill the rotor under specifications. So as i said pad slap or replace if they measure above spec at the thinest spot. But correctly matched steel pads will eat the rotor down to prevent high spots from material one the rotor. See below and the f80 rear pad size is not bigger then the g80 That is a lipped rotor
forcefed2567.00
      09-25-2022, 12:03 AM   #25
Forzanerazzurri
6918
Drives: E46 M3 Coupe/G80 M3CX
Maintenance plans are some of the dealers highest margin items for a reason. Just pay for the maintenance as it comes up.
      09-29-2022, 05:02 PM   #26
BLKSAPPE92
BLKSAPPE92's Avatar
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
Actually no CP is the highest gross of a dealer service department. Then maintenance plans and last warranty work.
If you trade your car in 1,2 pay for it cash.
front brakes $1,500 every 50-70k
Rear brakes $1,400 every 30-50k
Tune up $900 every 30k
Rear diff $550 every 50k
cabin filter $190 every 20k
air filter $270 every 30k
wipers $75 every 10k
A 5yr 75,000 is about $3,200
Let me know if CP adds up for a daily driver
      09-29-2022, 11:21 PM   #27
Forzanerazzurri
6918
I said "some". And i have no idea what "CP" is...
      09-30-2022, 04:08 PM   #28
BLKSAPPE92
BLKSAPPE92's Avatar
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
2022 BMW M3  [0.00]
Customer pay - highest gross and money maker
Prepaid maintenance - locked in at current prices even if inflation raises prices higher in 3-4-5yrs. Plus its discounted because you invest in it upfront.
Warranty- lowest gross usually for a dealership.
Most that keep there cars past 36k will benefit from a maintenance plan it just depends how long you keep the car
Aalfred2619.00
