07-20-2022, 07:13 PM | #1 |
Rep 2,744
Long haulers: Any brake jobs yet? (Maintenance plan)
I've read a couple of anecdotes about the rear brakes going early on G8x cars when tracking, but I'm curious if for more mundane DD use, people are seeing brakes needing work earlier than expected?
I'm trying to make a decision about a maintenance plan (which covers brakes), that I was quoted by Christine @ Steve Thomas BMW: Maintenance includes the brakes: 48 months/50k miles $1849 60 months/75k miles $3149 72 months/100k miles $4699 84 months/125k miles $5999 I doubt any G8x owners are anywhere near 75k miles, but I'm pretty sure that a single brake job (front + rear) would cost more than that $3149, so I'm a little tempted to take advantage of this.
07-20-2022, 07:47 PM | #2 |
Rep 1,773
Make sure you don't have spacers installed if you want them to cover brakes under that plan
07-20-2022, 07:59 PM | #3 |
Rep 1,241
I don't think I've EVER put 75k miles on a car I've owned....I just don't keep them that long.
How much does a rear brake job even cost on a G8x?
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
Limegrntaln13476.00 |
07-20-2022, 08:06 PM | #4 |
Rep 2,744
I've heard just the rears can be a $2k job (if both pads and rotors are needed). Even if I don't go 75k miles, if that's something that's likely to happen after 20-30k miles, then at least the 48/50 plan might be worthwhile.
07-20-2022, 08:31 PM | #5 |
Rep 1,929
Front rotors are around 400(aftermarket fronts can be found for $300), rear are 300.
Front ebc red pads are 300, rear are 100. $1800 if you do the work yourself. But there's no way the rotors need replacing when the pads go out, they might need machining but should still be usable.
07-20-2022, 08:46 PM | #6 |
Rep 1,606
The pads hold up very well. I have almost 18k miles and brought my car in for service yesterday. Measured 10mm all around or maybe it was different front and back but they said they had plenty of life and I drive the car pretty hard
NightWriter4844.00 |
07-20-2022, 08:48 PM | #7 | |
Rep 393
Drives: 22 G80 Sao Paulo Yellow
07-20-2022, 08:52 PM | #8 |
Rep 393
Remember tween deciding just on brakes the maintenance plan doesn't just cover brakes it overs spark plugs cabin filter air filters differential and much more
07-20-2022, 08:53 PM | #9 |
Rep 6,962
Yeah, I've seen 2 guys, both with 2021s, with 13k mi and they need back brakes. quoted about $1,900.
YT: G Dubyou |
07-20-2022, 08:54 PM | #10 | |
Rep 1,773
07-20-2022, 08:58 PM | #11 |
Rep 2,744
Which plan is this? Ultimate Care Plus? I paid $700 for 36 months.
I believe so, but I'll need to verify. I think the only difference between UC (standard for 3/36) and UC+ is that the latter covers wear-and-tear items (wipers, brakes, and MT clutch), right?
07-20-2022, 09:04 PM | #12 |
Rep 1,773
I believe so but they change their plans so much I've lost track. Mine technically covers pads, rotors, drive belts etc. $3149 seems high. They have a lot of margin on these plans. Negotiate more.
07-20-2022, 09:16 PM | #13 | |
Rep 1,369
Drives: 2020 X3MC
07-21-2022, 08:47 AM | #14 |
Rep 57
It is worth it just for the brakes alone. I got the 60 / 75k, I plan on keeping this car for a while. So not the worry about Maintenance for 5 year / 75k miles is a good thing.
Only you can answer this question really, depends how you drive the car and how long you plan on keeping it. |
09-06-2022, 10:00 PM | #15 |
Rep 32
UC+ is well worth it IMO. I have about 10k miles on mine, and I'm on my third set of pads and second set of rotors. I estimate the current set is at about 50% wear. All replaced under warranty/UC+.
09-07-2022, 06:16 AM | #16 |
Rep 2,744
Wow. I assume you track pretty heavily?
09-07-2022, 10:41 AM | #17 |
Rep 32
You would think. =/
I've done 4 total days at the track; spirited daily driving. (3 days at BMW HPDEs. 1 open lapping day.) Really rough estimate here, but I would say each day at the track uses about 30% of the life of the pads and rotors. |
M4Tejas788.00 |
09-07-2022, 09:14 PM | #18 | |
Rep 488
BMW a$$ raping the consumer on repair costs. NO wonder people dump the Germans after warranty end.
T0RM3NT3642.00 |
09-12-2022, 09:18 PM | #20 |
Rep 1,929
Rear pads are $100...
09-20-2022, 06:39 PM | #21 | |
Rep 393
What I'm trying to say is you might get away with a pad slap but most likely not its brakes and rotors |
09-20-2022, 06:41 PM | #22 | |
Rep 393
It should be Wipers Air filters Cabin filters Spark plugs Brake fluid Rear differential service Brake pads |
