Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      06-02-2022, 05:05 PM   #1
MinMax
MinMax's Avatar
228
Drives: G80
G80 trickle charger convenience setup
Hi guys,
Have a noob question. So I'm trying to set up my CTEK trickle charger with convience access setup on my G80. When I looked the ground post for negative attach point I see both of them are occupied by something else already. So is it okay I just put the negative on one of those post thats being occupied or should I look for other place?
Really appreciate for the help.
      06-03-2022, 08:35 AM   #2
nearwater4me
Drives: '22 G82 Base
Any ground should be fine.
Where are you routing the connector to?
Are you planning on attaching it under the hood somewhere close to the windshield so you don't have to open the hood when charging?
      06-03-2022, 09:35 PM   #3
MinMax
MinMax's Avatar
228
Drives: G80
Yes but the 2 negative ground posts nearby seem already being occupied by some wires. I'm not sure if I can put my negative connector together with those wires.
      08-29-2022, 08:01 AM   #4
GixY2K
Drives: '19 GLA45AMG(his) / '21 X3M40i
Late to the reply, but I put mine to the one closer to the Vin#.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior
2014 BE GTR FBO/e85
      08-29-2022, 12:05 PM   #5
moonluv810
moonluv810's Avatar
Drives: 2017 BMW X3, 2018 BMW M3, 2022
Just wondering why you wouldn't connect directly to the battery in the trunk and keep the connector tucked in under the floorboard when not in use.
      08-29-2022, 04:48 PM   #6
GixY2K
I believe I read/heard that they rather have you connect inside the engine bay so that the circuit can go through a form of ecu as a safety net in case of someone causing a reverse polarity or something stupid like that, while keeping your electronics (which is now, arguably 99% of a BMW) safe.
2014 BE GTR FBO/e85
      08-30-2022, 08:38 AM   #7
nearwater4me
It's probably the IBS (Intelligent Battery Sensor) they're referring to.
      08-31-2022, 01:59 AM   #8
davidmct-M3
Drives: BMW 440i with MPSSK
I suspect the cables you are seeing are ground connections for some of the electronics/engine.
      09-03-2022, 04:44 PM   #9
GregM4
GregM4's Avatar
Australia
1317
Drives: VERDE ERMES G82 M4 Xdrive
This is my setup.
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange
SOLD - G01 X3 White
SOLD - E93 Burgundy
M4Tejas788.00
harperium1313.00
Limegrntaln13475.00
      03-04-2023, 01:13 PM   #10
myfirstbimmerM4
Drives: 2023 M4 Competition xdrive
i just set up my ctek and have noticed that my hazard light stays on....anyone else notice this issue?
      03-04-2023, 02:22 PM   #11
MinMax
MinMax's Avatar
228
Drives: G80
I have noticed if you left your door opend for a period of time the hazard light will automatically turned on. Maybe just a safety feature. Just flip the light switch to turn it off.
      03-04-2023, 03:31 PM   #12
myfirstbimmerM4
dont think thats the issue,...the hazard light turns off after some time when the ctek is not connected/charging but when i connect it the hazard light stays on while charging.
I had it connected for an hour and it doesnt turn off. If the light just stays on whats the whole point of keeping it on a trickle charger, right? its just draining the power from the battery
all these new cars with technology and random electrical stuff is kinda of annoying hahaha
      03-04-2023, 03:36 PM   #13
MinMax
MinMax's Avatar
228
Drives: G80
Oh you mean the hazard light…weird, mine does’t do that when charging.
      03-04-2023, 05:39 PM   #14
myfirstbimmerM4
thanks for the reply, thinking about leaving it on for a whole day to see if it fully charges
      03-05-2023, 12:46 AM   #15
myfirstbimmerM4
so for some weird reason when I use the alligator clips the hazard lights stay off, im not sure what it is, guess I solve my own problem somehow
      02-05-2024, 05:33 PM   #16
farishat
farishat's Avatar
Drives: 2004 E46 330i ZHP, 2024 G80 M3
Originally Posted by GregM4 View Post
This is my setup.
Hey, how did you attach the + end of the comfort connector? That terminal nut is Very tight, not sure how to unscrew and not cause damage.
Also, ctek has two sized connectors for these comfort cored, which should I buy?
      02-05-2024, 05:48 PM   #17
GregM4
GregM4's Avatar
Australia
1317
Pretty sure the size was M8. I did not have an issue with the positive terminal. Just loosened it and unscrewed it then refitted.
Hope this helps.
SOLD - G01 X3 White
SOLD - E93 Burgundy
      02-08-2024, 11:28 AM   #18
geko29
Drives: 2023 M3 6MT
You can absolutely stack rings on a post, as long as you get it good and tight.
Mine is connected directly to the battery. I back into the garage and it would be too much of a pain to connect under the hood.
Needsdecaf6606.00
      02-12-2024, 12:01 AM   #19
farishat
farishat's Avatar
Hi guys,
I have one of these I want to hookup the same way, but how did you get the Positive Red Cap back on after connecting the red cable under there? Seems like the Red cable end is quite thick and prevents the cap from snapping in place, it is made very tight indeed.
Thanks
      02-12-2024, 12:03 AM   #20
farishat
farishat's Avatar
Hope this helps.
Got it, I tried that, but the red cap can't be put back in place. The cable end is pretty thick and prevents the cap from snapping back in place, it is pretty tightly made.
      02-12-2024, 12:11 AM   #21
GregM4
GregM4's Avatar
Australia
1317
Strange. I did not have the issue. Maybe they change the size. Not sure.
SOLD - G01 X3 White
SOLD - E93 Burgundy
      03-25-2024, 05:55 PM   #22
Mike02z
Mike02z's Avatar
Drives: 2024 BMW M4 Base
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
You need to cut the back of the red cap. Don’t worry, it’s a $16 part. Just don’t drop it when trying to reinstall…Don’t ask me how I know.
