Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      12-10-2022, 09:23 AM   #23
FLOSS M
///M3
FLOSS M's Avatar
Drives: 22 M3 X-Drive
After reading this .... I just let the dealer do the swap for SRF
Nothing like the F8x - that was easy
      12-11-2022, 10:39 AM   #24
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Here’s the procedure from TIS
https://g80.bimmerpost.com/forums/at...3&d=1648490317
      12-18-2022, 07:32 AM   #25
Dabeamerking
Dabeamerking's Avatar
Drives: m4
Learned your lesson. Ista is always MVP
      01-19-2023, 12:30 PM   #26
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
Huh. I had momentarily forgotten that we had the DBW brakes on these cars, although I don't think it's as complicated as it was on the servo system on the motorcycles. Those were a pain to bleed, at least on my R1150RT anyway.
I don't use the vacuum method, rather I put positive pressure (about 1 bar) in the reservoir to push the fluid through. I also (as others noted) siphon out most of the fluid in the master cylinder reservoir first, just to shorten the time required.
Hopefully doing it this way (like a vacuum bleed but opposite) with no pumping, ignition off, etc., won't cause the computer to freak out.
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
FISH225404.50
      01-20-2023, 06:53 AM   #27
FISH22
FISH22's Avatar
Drives: G80 M3 Competition
2021 BMW M3C  [10.00]
2011 BMW M3  [10.00]
There are a few of us that are thinking a pressure bleed with the car completely off, maybe even battery disconnected shouldn’t raise issues. Mainly because the pressure being applied to the MC is downstream from the pedal servo. Worst case, faults can be cleared with Bimmerlink.
      01-22-2023, 12:14 AM   #28
Hawkdog
Drives: ‘22 M4 Comp xDrive
So…has anyone had the cojones to try a pressure bleed with the battery disconnected and not using ISTA? Had a lot of folks on this thread and others pontificating that they think it would work, but have not seen a single post from anyone that has actually tried it and their result.
      02-21-2023, 10:57 PM   #29
Hawkdog
I’ll take that as a no.
stormlv932.00
      03-03-2023, 09:21 AM   #30
B_davis
Drives: M4
Kies recently did a video where they swapped pads and brake lines. They did a pressure bleed with no mention of any triggering any faults. The only thing they showed on the video was using protools to put the rear brakes in service mode so that they could change the pads.
The pressure bleed with the battery disconnected was also the same method that is used on Alfa QV with bbw.
zero213253.00
      04-23-2023, 04:24 PM   #31
BrendanZ0402
BrendanZ0402's Avatar
Drives: G80 M3 GTP 6MT
2023 BMW M3  [0.00]
FWIW I did a pressure bleed (motive bleeder) on my buddy's QV with the battery connected and no faults were displayed as well. Will report back once I bleed my car!
RACE M3548.50
Jon H391.50
      04-29-2023, 12:30 PM   #32
Jon H
Drives: 2015 911 GT3
Keep us posted. I have new brake pads coming in on Tuesday. I may attempt to do a pressure bleed at the same time as pad change. This really shouldn't be that complicated but here we are.
M3Cx, E92 M3 6MT
Previous cars: '21 Supra, '17 GT-R, '15 GT3, '13 GT-R '09 GT-R, '06 Z06, '06 Evo MR, '05 M3, '03 Evo, '00 Miata.
      05-03-2023, 05:38 AM   #33
ginohhh
ginohhh's Avatar
Drives: 2022 BMW M3 Competition Xdrive
Any brave souls take a plunge in testing the theory of having the car off/battery dc’d and pressure bleed it with a motive bleeder?
Any info/update would be appreciated! I got an upcoming track day in a few weeks and I’m trying to prep my car. Not sure if should just cough up $ and take it to the stealership and have them do it.
      05-03-2023, 07:40 PM   #34
Curious41
Curious41's Avatar
66
Drives: '22 M3C, '23 330e
I used the motive bleeder without disconnecting the battery and had no problems.
      05-03-2023, 08:07 PM   #35
ginohhh
ginohhh's Avatar
This is refreshing to hear. I’ll probably try it out this coming weekend.
