Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      05-09-2022, 09:32 PM   #1
Celticsfan34life
Drives: 2021 BMW M3 Comp
2021 BMW M3  [0.00]
Liqui Moly in G8X
Anyone using Liqui Moly in these cars yet? If yes, what are you using? I just finished my first track session and want to change the fluid before my next. I was thinking of just going with Top Tec 6600 0W20 but was hoping for other input!
      05-11-2022, 12:28 PM   #2
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
0W20 is too light, stock oil is 0W30 and Liqui Moly's oil finder only has recommendations for their 5W30 oils (e.g EU recommendation - Top Tech 4200 5W30).
For the US market M3/M4s, LM recommends only SPECIAL TEC B FE 5W-30.
I would stick with the stock oil.
M4Tejas788.00
      05-26-2022, 12:20 AM   #3
rmeitz167
bmw tech
rmeitz167's Avatar
473
Drives: g80 m3
I will be going to the 4200 here shortly. This is a great oil and option
Lehigh Valley Motors
193 Front Street
Hellertown, PA 18055
484.214.6464
Mainentance-Repair-Performance
      05-29-2022, 11:14 PM   #4
edycol
Drives: 2011 328i xDrive
Unless you guys are doing lifetime warranty through FCP, Pennzoil Platinum Euro L 5W30 is much better oil than Top Tec 4200 and dirst cheap in Wal Mart.
Also, if going through FCP, I would go Pentosin Super Performance III.
But, doesn't M requires LL01 FE? 4200 and oils I mentioned are ACEA C3 oils. LL01 FE is high SAPS oil.
Under warranty I would personally go Motul Specific LL01 FE 5W30.
After? Pretty much anything LL01 but my choice: Motul X-Cess 5W40 GEN2 or Pennzoil Platinum Euro 5W40.
M4Tejas788.00
evidence202.00
      05-30-2022, 12:58 PM   #5
Celticsfan34life
2021 BMW M3  [0.00]
I went with SPECIAL TEC B FE 5W-30
      06-20-2022, 08:28 AM   #6
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Hi Edycol,
Why do you say that under warranty use LL01FE, then out of warranty use LL01?
Side question, if someone was to apply a tune on their S58 - they should assume warranty is out the door. So is using Motul X-Cess 5w40 the best available for a tuned S58 considering warranty would be null.
      06-20-2022, 08:46 AM   #7
edycol
Hi Edycol,
I would definitely go LL01 FE during warranty and not any FE, but Motul Specific 5W30 LL01 FE. Reason is that Motul specific has HTHS of 3.4cP. That is right on borderline of LL01 which has minimum HTHS of 3.5cP. HTHS is what matters protection wise, not grade per se. Though thicker KV100, higher HTHS, all things being equal. But really good oils will have lower KV100 but high HTHS. Not to add to confusion, you don't want to go too high of HTHS as it will create drag. 3.5-4cP is perfect for these engines.
After warranty or if you tuned your S58, go LL01. X-Cess GEN2 is excellent choice.
evidence202.00
      06-20-2022, 10:23 AM   #8
Dawgz
2022 M4 Comp Xdrive
1016
Ok thanks.
Lastly, very interesting comment you had made about LiquiMoly. I used LM LL 5W40 on my e70 X5M and then had sent the oil sample in to Blackstone after just ~2k miles. Looks more like a high end 5W30?
M4Tejas788.00
      06-20-2022, 02:28 PM   #9
edycol
Ok thanks.
That oil is obliterated.
Here is where the problem is. You don't have TBN and TAN measurements. That is the key.
If TAN is high, eventually oil would start to thicken again, but that is oxidative thickening=sludge.
Personally, the way that oil looks after 2k, I wouldn't touch it again with 10ft pole.
Next time you do UOA do TBN and TAN measurements. Don't forget, UOA is not analysis of engine condition (although it can show for example unusual wear to point to for example rod bearing failure) but analysis of oil. Wear numbers are very elusive and won't tell you anything about oil.
      06-20-2022, 03:04 PM   #10
Dawgz
2022 M4 Comp Xdrive
1016
Yea, understood. I have since sold the x5M to jump into the X3MC. I did the oil analysis just because I never did it for that car - However after doing that UOA I was surprised by the hyped up LiquiMoly LL 5W40.
I am just about to order the Motul 8100 X-cess Gen2 5W40 for my X3MC. I saw others using LiquiMoly for these S58 engines and that got me to question it again lol.
      06-20-2022, 05:00 PM   #11
edycol
Quaker State Euro 5W40 $18 on Wal Mart web site. Repackaged Pennzoil Platinum Euro.
      06-23-2022, 10:06 PM   #12
Dawgz
2022 M4 Comp Xdrive
1016
Just as a follow up, ended up ordering Specific LL-01FE 5W30 for now as I dont know where I want to go with tuning - Maybe go with Dinan until my factory warranty is up? Until I figure that out - I'll just go with what the specs say since the car has 6.8k miles on it.
Had to order (two) 5L jugs on FCP euro since the 1L bottles were out of stock and buying it elsewhere the prices were close to just getting a 5L when you factor in shipping. (I know the fill capacity is only 7).
      06-23-2022, 11:30 PM   #13
edycol
I don't think Dinan is covered under BMW warranty anymore.
      06-24-2022, 06:41 AM   #14
Dawgz
2022 M4 Comp Xdrive
1016
Ya but Dinan matches the warranty
https://www.dinancars.com/products/s.../D900-S58-S1-W
      06-24-2022, 08:11 AM   #15
edycol
Ok. I know that BMW dropped them. I think Dinan ownership changed. Not sure really.
      06-24-2022, 09:14 AM   #16
forcefed
forcefed's Avatar
Drives: .
https://www.dinancars.com/products/software-tuning/engine-tuning/engine-software/dinan-plus/parts/D900-S58-S1-W
That's for the x3m's prior to 2020 my, unless you get someone to unlock your ecu.
      06-24-2022, 01:38 PM   #17
Dawgz
2022 M4 Comp Xdrive
1016
Ya, mine is a 2020 (12/19 build)
      06-25-2022, 12:53 AM   #18
rmeitz167
bmw tech
rmeitz167's Avatar
473
Drives: g80 m3
but not a fan of leichlauf 5/40 which is also ll01?
193 Front Street
484.214.6464
      06-25-2022, 05:01 AM   #19
edycol
No. I mean, it is approved oil, it will cut it. Would I buy it next to all these other choices? No.
      06-25-2022, 07:31 AM   #20
Dawgz
2022 M4 Comp Xdrive
1016
Check the oil analysis I posted, it's for the LL 5w40 from LiquiMoly.
      06-25-2022, 04:59 PM   #21
santox
Ing.
santox's Avatar
356
Drives: BMW M4 Comp G82 xDrive
Before talking about ll-01, fe and other stuff , ask your dealer if in case of warranty for the engine , do they check the oil . No . In my country i asked 3 dealerships where they do the analysis , and they don't have any agreement . Also i have had 2 engines replaced in warranty . Nobody checked the oil . One was a M2 F87 with Motul 300v . Replaced engine (which had also stage 1 ).
IG : FrozenBimmer
      07-12-2022, 12:36 PM   #22
Dawgz
2022 M4 Comp Xdrive
1016
First oil change (in my ownership) done!
