03-06-2022, 03:19 AM | #23 | ||
Rep 374
Limegrntaln13477.50 |
03-06-2022, 07:44 AM | #24 | |||
Rep 72
03-07-2022, 05:52 PM | #25 | |
Rep 6,962
It just makes sense to me. With over 100k driven with Brembos, this is what's worked for me. If you drive it like a commuter, in stop and go traffic, they're going to get gunked up, and make noise. I took a trip to Santa Cruz, yesterday my rotors got a real nice burnishing. Owners, manual? Of course.
YT: G Dubyou |
01-04-2023, 09:30 AM | #26 | |
Rep 245
Drives: MY24 Porsche Taycan
And even if it were all Brembos or high performance brakes then we should all hear squealing when we’re near another high performance car that’s braking and I’ve been around some; Only car I ever hear squealing is our 8. Curious, do you work for BMW??
MY24 Porsche Taycan | Neptune blue | Black |
MY24 Audi SQ5 Prestige | Mythos black metallic | Magma red Nappa Retired: MY23 BMW 840i Coupe | MY21 Audi SQ5 | MY19 Audi A6 |
01-04-2023, 01:40 PM | #27 |
Rep 6,962
If these brakes didn’t “just squeal” you wouldn’t bother reading multiple threads about it. You replied to this thread, and liked a comment on another brake squeal thread.
BMW has already had class action lawsuits on brake squeal from a number of years ago. Type Brembo brake squeal into a Google search, and you will see nearly every manufacturer that produces vehicles that come with Brembo brakes, from the factory, the brakes make noise. Look at previous model years of Mustangs. Brake squeal. 2021 yours don’t squeal. Ok, so, Ford is tired of people complaining about it, so they develop their own pads for the car that give you 90% of the braking with no noise. Straight from Porsches video on noisy brakes. “If you are experiencing brake noise, our professionals at Porsche are more than happy to determine whether it is a maintenance issue or A NATURAL OCCURENCE.” If bmw made a video on brake noise, it would likely say the same thing. Take for example the overall size of a brake rotor. An 8” rotor has far less surface area and the outside edge of the rotor is closer to the inside center of the hub, as opposed to a 15 or 16” rotor. Now you have double the surface area between the outer edge and the inner, center point. Applying a clamping force to the outer edge of the 8 inch rotor is going to be far more controllable than a clamping force out at 16 inches. Transfer this idea into linear feet. An Airbus A380 has a 261ft wingspan. During takeoff the wingtips can deflect up to 13 feet from center. Can you imagine seeing a wingtip deflect 13 feet? How much more wingtip control do you think the plane would have if the wings were only 20 feet long? You wouldn’t get 13 feet of wingtip deflection. Apply the same concept back into brakes. The 16” outer edge of the rotor, is going to deflect more under braking, which in turn, can cause certain harmonics. This phenomenon is known as stick slip. Engineering description Stick–slip can be described as surfaces alternating between sticking to each other and sliding over each other, with a corresponding change in the force of friction. Typically, the static friction coefficient (a heuristic number) between two surfaces is larger than the kinetic friction coefficient. If an applied force is large enough to overcome the static friction, then the reduction of the friction to the kinetic friction can cause a sudden jump in the velocity of the movement. A brake rotor and a pad friction surface, out at 16” vibrating thousands of times per second, causes a harmonic frequency. Alter the friction material, reducing or eliminating stick-slip, and the sound lessens or goes away. I’ve never had an issue with the cars that I’ve owned that have Brembos. And I’m sure it has everything to do with my driving style. If you drive it like you’re wearing high heels, they’re probably going to make noise. Here’s Porsches explanation. Which I know you saw in the other thread I posted in. But you have to watch it to understand. And no I don’t work for BMW. Why would I have to? https://youtube.com/watch?v=fUNHb9O52WQ&feature=shares
YT: G Dubyou |
01-04-2023, 05:39 PM | #28 | |
Rep 245
And all the people who do think that’s okay is likely the reason manufacturers don’t fix it. I wondered about you being employed by BMW because you seem to be vehemently spreading their propaganda of “this is normal” on this issue. If it was actually normal then all cars with Brembos would squeal and I know for a fact that not all do, so it can’t possibly be normal. Also, let’s talk brake rotor size…larger rotor doesn’t stop better. Look it up. They make ridiculously large brake rotors then sell that they stop better so they can charge more money.
Sparky_12362.00 |
01-04-2023, 07:48 PM | #30 |
Rep 6,962
You’re right. You’re getting my definition flipped all around, here. I’m not saying it right, or correct. I’m saying it’s common. Type “Brembo brake squeal” into Google and it’s endless. I eplained the Mustang brakes to you. I already said Ford probably changed the pads, because they were tired of hearing people drive their performance cars as commuters causing the brakes to make noise.
And if it was bullshit, NHSTA wouldn’t have a GM service bulletin, posted, specifically outlining “Brembo Brake Squeal.” Again, it doesn’t affect me, because of my driving style.
YT: G Dubyou |
01-04-2023, 08:44 PM | #31 |
Rep 245
I’ve tried braking my new 8 with every level of brake pressure you can imagine, still squeals on that stop and every subsequent stop regardless. Also, as is mentioned in the TSB you posted (thank you btw) it’s not always possible to drive and brake aggressively due to traffic and as I live in a very large city where there is almost always traffic and a lot of people driving in high heels (I’m a woman and still think that’s hilarious) I don’t have a lot of choice in the matter most of the time so have to listen to this horribly loud, grating squealing.
My dealer has my car and has promised resolution or buy back so we’ll see I guess. I’m really hoping for resolution as I’ve heard from others where certain actions resolved for them. I LOVE my new car and excluding the brake squeal think it’s the best car I’ve ever had.
02-13-2023, 11:47 AM | #32 | |
Rep 6,962
YT: G Dubyou |
BrendanZ0402283.50 |
02-13-2023, 03:58 PM | #33 |
Rep 198
Yeah, I’m right there with you. My brakes sounded exactly like yours. The typical reaction is “You’re not using them like they were designed. Do a couple 80 mph runs and slam on them to heat them up.” That’s all and fine but didn’t work for me longer than a couple days.
I put a set of Carbotechs on my G83 and have heard virtually no noise and very little brake dust. I’m not sure I’d recommend them as there’s a well-documented clicking noise that, I’m told, isn’t a problem but isn’t acceptable to me. I’ll do iSweep for the next go around. Good luck. |
Limegrntaln13477.50 Rodizzle397.00 |
02-13-2023, 04:57 PM | #34 | |
Rep 6,962
YT: G Dubyou |
EatThatLunchBaby386.50 |
02-19-2023, 07:26 AM | #35 |
Rep 984
I had CCBs on my G80 before I swapped them with someone's standard brakes. They were dead silent from the day of delivery to about 800 kms during which at that time I swapped them over for the standard steel brakes. Once I got the standard steel brakes, they started making squealing sounds if I did a lot of heavy traffic rush hour driving. When I went hard on the brakes and did some hard stops as if I'm bedding in new brakes, the squealing completely went away. The squealing comes back when I don't do hard braking anymore. I then switched to EBC Yellowstuff brake pads once I passed the break in service and the squealing has completely gone even if I do bumper to bumper traffic soft braking. I guess the more aggressive compound of the EBC's prevents that glazing from forming. The brake dust is also a little bit less as well which is a bonus. If anyone don't like squealing, I highly recommend the EBC Yellows
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 |
04-14-2023, 08:32 PM | #36 |
Rep 868
This is common complaint with the current generation of M3/M4. Supposedly, compound on brake pads “changed” to mitigate brake dust production, but as trade off is the increased noise. This for me has been an issue from day one even in humidified environment of FL. It’s a terrible sound, but I have noticed decreased incidence with rain and moisture. Plusses and minuses as always.
2022 BSM G80 Comp X-drive |
04-21-2023, 10:20 AM | #38 |
Rep 459
I had this issue on my 1k mile 2023 G80. I would get a high pitched squeal on soft braking. I read another thread on here that suggested finding a back road and doing some hard braking runs. I did that for a couple of minutes and the squeal is completed gone.
06-07-2023, 06:32 PM | #42 |
Rep 73
Drives: '23 BMW G80 M3 Comp
Going to a BMW service center wouldn't be any help I'm assuming. Only solution would be replacing the pads?
06-07-2023, 07:42 PM | #43 |
Rep 2,022
06-08-2023, 11:35 PM | #44 |
Rep 353
kgelfen3602217.00 |
