Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      11-30-2021, 07:48 AM   #1
GixY2K
Drives: '19 GLA45AMG(his) / '21 X3M40i
G80 G82 G83 Engine (S58) Main Bearing Shell Recall (cont...)
This is just a continuation thread from the original posted by Sbm007 regarding the recall of certain production group S58 engines and their main bearing shells.
Most of the details are on the first page of the link below.
https://g80.bimmerpost.com/forums/sh....php?t=1865201
More info as of 2Dec2021 (apparently affecting MT only?): https://g80.bimmerpost.com/forums/sh....php?t=1880062
Note: the above link is currently dead; don't know if temporary or long term. I'll leave it here for a while just for awareness of the MT discussion, and in hopes that it will come back to life.
I feel that BMW is trying to fly under the radar with this issue, which could very well be nothing more than a cautionary measure.
However, it would not hurt to keep it on our radar just in case.
Thanks to Sbm007 for initiating this post.
Note: this thread was being buried daily in the "Purchasing, Delivery" forum. Traffic is not so bad here in the "Mech. Maint.... Recalls" forum, so it'll be easier to keep an eye on this topic.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior
2014 BE GTR FBO/e85
M4Tejas788.00
      11-30-2021, 09:52 PM   #2
Mjanisse
Drives: 2018 BMW M3 CS
Thanks for keeping this alive and posting in the right category. I'm one of the affected. Car runs strong and no performance issues or weird noises at 1700 miles. I'm driving it pretty hard when I take it out. I gave up on looking for a solution as BMW won't give a straight answer. More will be revealed....in the interim I'm really enjoying the car.
GixY2K517.00
      12-01-2021, 10:58 AM   #3
KnightedBMW
Drives: 2022 M3C
Same. I don't baby my car at all. Drive it like its meant to be driven. If/when BMW contacts me, I'll worry about it then.
GixY2K517.00
M4Tejas788.00
      12-01-2021, 03:08 PM   #4
GixY2K
And same here. I'm affected based on dates, but not on recall search tools, but doesn't stop me from putting the M4 through its paces.
2014 BE GTR FBO/e85
      12-02-2021, 06:45 AM   #5
Tdubb88
Drives: Future M4C
New info on the crank bearing recall https://g80.bimmerpost.com/forums/sh....php?t=1880062
GixY2K517.00
      12-02-2021, 08:17 AM   #6
KnightedBMW
Drives: 2022 M3C
Hmm...manual only? I have a comp and still show affected.
GixY2K517.00
Limegrntaln13475.00
      12-03-2021, 09:46 PM   #7
freshxdough
freshxdough's Avatar
3513
Drives: 2024 iX 50 | 2020 X3 M40i
Whoever posted that it only affects manual cars is misinformed and posting false information. The recall has become ready and released as of 12/3
M4Tejas788.00
      12-05-2021, 05:23 PM   #8
GearRex
GearRex's Avatar
Drives: G80 M3, E46 ZHP, 991.2 Cabrio
New post is a dead link. At leas the one talking about the Bearings Recall for manual only.
What happened?
      12-06-2021, 08:08 AM   #9
GixY2K
What happened?
Duly noted.
2014 BE GTR FBO/e85
      12-09-2021, 02:09 PM   #10
KnightedBMW
Drives: 2022 M3C
So as we all know, the poster stating this was only impacting MT cars is not correct. I just got off the phone with my SA who called to schedule the service for the recall on my M3 comp.
He was looking at the diagnostic while on the phone and his words were "surgery, but it doesn't look to be too bad." From his understanding, its not a full engine pull. His review indicates its an oil pan drop which will make the inspection (and repair if needed) possible.
He also stated they inspect first as not every car identified by BMW will need to be fixed.
The tech will be a BMW M certified master tech (whatever that means I know it shouldn't mean a low level tech).
He also said he expects me to have my car back within a week.
My car is set to go in for surgery on 12/27/21. I'll keep everyone posted.
Limegrntaln13475.00
M4Tejas788.00
      12-09-2021, 07:42 PM   #11
Limegrntaln
Limegrntaln's Avatar
Im not sure how theyre going to change the Thrust bearing without removing at least the crank shaft. I guess they could remove the pan, and pull the crank down to remove and replace the thrust bearing. Unless they have some special process, the bearings are locked into the block, to keep them from spinning. So, you cant just hammer them out.
YT: G Dubyou
M4Tejas788.00
      12-10-2021, 10:43 AM   #12
GixY2K
Don't know much about mechanics, but based on what you just mentioned above, wouldn't be more cost effective to just replace the engine and re-sell the old updated engine in the market? (if it comes to that)
2014 BE GTR FBO/e85
      12-10-2021, 01:27 PM   #13
savi01
savi01's Avatar
Drives: 2022 BMW M3C
I'm not super knowledgable about engine mechanics, nor do I know the specifics regarding this recall, but since an oil pan drop was mentioned, this video came to mind. Maybe the work is something similar to this?
(Since I'm sure someone will comment, yes, I know it's not the same engine and possibly not the same issue addressed in the video, but maybe it's a similar approach to access the necessary components)
Limegrntaln13475.00
GixY2K517.00
M4Tejas788.00
      12-10-2021, 06:50 PM   #14
Limegrntaln
Yes, I'd imagine it's going to be something similar to this process. This is exactly what I had in mind. Now, I would have zero issues if the shop performing the "surgery" was as skilled as this shop. It looks like their process is very well organized.
YT: G Dubyou
GixY2K517.00
      12-27-2021, 09:29 AM   #15
KnightedBMW
Drives: 2022 M3C
So I dropped my car off this am for the main bearing shell recall. Apparently there are 6 possible bearing shells that need to be replaced, but my car only has 1 that appears to be impacted. They will be inspecting all others however.
He said they have a list of VINs. He didn't tell me how many cars are on it, but he said its quite extensive.
SA confirmed my parts are in and he anticipates having my car back to me this week. He said he'll get me an update as soon as he has one and he hopes its before mid-week. The only thing he guaranteed me was that I will not have my car back today (obviously).
I'll update once I know more.
GixY2K517.00
      12-27-2021, 01:13 PM   #16
GixY2K
On the bright sight, you'll get an early change of fresh motor oil.
How many miles did you have? And what state are you in, if you don't mind asking. Also, build date.
And thanks for the update. Hope for the best outcome.
2014 BE GTR FBO/e85
      12-27-2021, 01:16 PM   #17
KnightedBMW
Drives: 2022 M3C
2,500 miles. South Florida, but car was bought through an out of state dealer. Not sure of build date. Build week 31.
GixY2K517.00
      12-29-2021, 10:54 AM   #18
KnightedBMW
Drives: 2022 M3C
Here's my Wednesday (non)update for you.
Checked my 360 remote cameras. Car is still sitting in the parking lot at the dealer.
I reach out to SA. He texts me saying "good news...the car is being worked on, bad news...it won't be ready by new years."
I respond and let him know I know that's not accurate and the car is not being worked on as its sitting in the parking lot and I send a screen shot back of the camera picture. I also tell him I want a better loaner (which he promised) as I'm in a base 3 series.
He says he misspoke as they had to open a TSARA case for the tech, which is in process and they're waiting on the TSE to come in. He did say he'll swap my loaner.
I'm not annoyed I won't get my car back this week (well slightly) since I expected that. What I am annoyed about is the bullshit. Don't lie dude - just give me the correct info. I'm not some idiot that doesn't know what's what.
That's all for today folks.
EDIT: no less than 2 minutes after posting this, the SA texts me letting me know the TSE is at the dealer and the car is being pulled in! Lol.
      12-29-2021, 02:17 PM   #19
uncboysetsfire
Drives: 2022 BMW X3M
Did they say how they determined whether any of yours needed to be replaced? My X3M has been at the dealer since 12/16 and has been inside with the last activity per the app being on 12/22. I was told they were waiting for the engineers to analyze data and get back to them. Not sure if the holidays and vacations are at play here or what but the lack of information and transparency has been very discouraging.
      12-29-2021, 03:31 PM   #20
KnightedBMW
Drives: 2022 M3C
Nope. Was yours scheduled to go in for the recall on 12/16?
      12-29-2021, 04:23 PM   #21
uncboysetsfire
Originally I reached out because I wanted someone to ride with me to hear the odd noise I am getting at low speed braking (15-25mph) that they had told me was normal but i am not convinced. This was around 12/2 and my SA booked me for 12/16 so I could get a loaner. When I showed up 12/16 and waited they told me the foreman was too busy but that they had the parts and were going to handle the recall while I had the loaner. It didn’t move from 12/16 to 12/21.
So the SA did make the 12/16 appt to handle the recall. Not going to be happy if after all this time nobody bothers to deal with noise at braking. I miss my car.
They said they had to inspect and determine whether they need to be replaced but that it was mainly the manuals that were impacted. I know this forum has something about that mentioned and indicating it wasn’t true so who the hell knows what or who to believe.
      12-29-2021, 06:26 PM   #22
KnightedBMW
Drives: 2022 M3C
The manual only thing was BS and that post removed.
My car is a comp fyi.
Hope to know more tomorrow.
