09-23-2021, 01:25 PM | #155 | |
Rep 793
Medal483.00 |
09-23-2021, 02:40 PM | #156 |
Rep 672
Drives: 2021 M3C
I would agree!
Driving: 2021 M3C
Semper FI |
09-23-2021, 02:51 PM | #157 | ||
Rep 672
Drives: 2021 M3C
Does that mean it's always necessary, absolutely not.
Driving: 2021 M3C
Semper FI |
09-23-2021, 08:12 PM | #158 | |
Beware of cheap bait!
709
Rep 715
09-23-2021, 08:50 PM | #159 |
Rep 6,589
Oh my gosh. Stop the alignment talk. It's not necessary. Full stop.
Fuk sake! |
09-24-2021, 11:29 AM | #160 |
Rep 1,250
Alloy wheels direct has the 963M wheel sold as 19/fronts and 20/rears - pardon if this is a dumb question but would it be possible to use the 19s all around as a square set up?
09-24-2021, 11:47 AM | #161 |
Rep 6,589
09-24-2021, 04:46 PM | #163 | |
Rep 6,589
So I just put them on my wife's M2C. |
09-24-2021, 08:03 PM | #164 |
Rep 58
09-27-2021, 02:06 AM | #165 |
Rep 290
Has anyone come up with any other economical solutions for winter wheels? Tire rack is currently showing only 2 remaining of the rims Forza1976 has and not getting more until 1/28/22.
09-27-2021, 07:27 AM | #166 |
5276
Rep 5,378
While it's not my first choice, I'll probably just get Sottozero 3s for the stock 826Ms... I wanted to avoid swapping tires on and off the same wheels but I can't wait until late January for more wheels and I really don't want to pay upwards of $4k for the OEM 892M set.
09-27-2021, 09:51 AM | #167 | |
Rep 1,250
09-27-2021, 09:55 AM | #168 | |
Rep 57
Sorry English is not my mother tongue. I'm here because more active than EU forum. For sure it fit and geometry is ok. What I mean is " does it fit well from a stylistic point of vue" Usually offset is not the same and wheel are "inside" the arch wheel. Last edited by Olivenoire; 09-27-2021 at 10:29 AM.. Reason: typo |
evilalien450.50 |
09-27-2021, 10:24 AM | #169 |
5276
Rep 5,378
IF you check out the sponsored classifieds on this site you'll find a couple of vendors that sell the OEM wheels and the OEM winter wheels & tire package.
I plan on just buying tires and swapping summer rubber for winter rubber and vice versa.. maybe once the car is more popular I'll pick up another set of 19/20 OEM wheels off a member here and mount the winters on them.
09-27-2021, 03:36 PM | #170 | |||
Rep 587
I expect they'll look different, as you say within the wheel arch more than the default wheels. They are narrower, so the correct suspension geometry requires with both directions from where the wheel is attached to the car. The only way to have it look exactly the same in terms of how flush it is with the outside wheel arch is same wheel/tire width or using spacers. Same width isn't ideal for winter traction in snow, and a spacer isn't ideal for maintaining correct suspension geometry.
09-28-2021, 02:11 AM | #171 |
Rep 57
100% ok with you.
I've received a quote from my BMW dealer. I will buy them, it seems more than mandatory regarding the torque on only 2 RWD on wet / cold conditions. Last edited by Olivenoire; 09-28-2021 at 02:40 PM.. Reason: Typo |
09-28-2021, 11:45 AM | #172 |
Rep 134
I picked up the 68mm ones on eBay. They are held onto the plastic disc with 4 metal arms, just remove the metal arms and use double sided tape (built up 4 layers) and place on top of the stock Type 130 center caps. They look perfect on the wheel.
09-28-2021, 01:14 PM | #173 |
Rep 6,589
For sure, I did the same with some cheapies from Amazon too. I cut the edges off however to make them more flush. Only adjustment I made.
10-01-2021, 06:15 PM | #174 | |
Rep 290
10-01-2021, 08:37 PM | #175 |
Rep 10
No, I never got any answers, but I suspect the rears would probably fit all around. I ended up ordering the whole OEM setup just to avoid any possibility of issues. Not sure when they'll come in, but I was tired of thinking about it, and I wanted to make sure I have a winter set before it's too late...
10-01-2021, 09:04 PM | #176 | |
Rep 290
I noticed tire rack now has some 20” square setup options listed under their winter wheel/tire packages for the G80/G82/G83 so I ordered some 20x9.5 MSW 50’s with vredestein 275/30/20 snow tires. I know the 20s aren’t ideal size for winter rims, but they look good and I’m sure it’ll do just fine in 90% of the snowstorms here in CO. Whole thing including TPMS, mount and balance, and taxes was under $2500 shipped to my door. |
