08-25-2020, 11:50 AM | #67 | |
Plenipotentiary
2614
Rep 3,046
4WD: Bias 0/100 until rear longitudinal or lateral tire slip detected, 20/80 predictive bias based on speed, load, navigation data, KAFAS/LIDAR. Up to 100% can be sent to the front axle as needed. 4WD Sport: Bias 0/100 until rear tire slip or roll axis exceeds a predetermined threshold. Up to 100% can be sent to the front axle as needed. Above 200km/h, front axle is inhibited until roll axis exceeds a pre-determined threshold. 2WD: F/R distribution inhibited unless Pre-Crash is triggered. |
08-25-2020, 02:15 PM | #68 |
Rep 2,559
08-25-2020, 02:19 PM | #69 |
Rep 7,037
08-25-2020, 08:27 PM | #70 |
Rep 1,809
911 is rear engine tho no slip to speak of off the line and 0-60 and 1/4 times are nearly identical in testing between C4S and C2S
2024 Porsche 911 GTS Cabriolet
08-25-2020, 08:32 PM | #71 |
Rep 7,037
08-25-2020, 09:15 PM | #72 | |
Rep 1,809
Only diff obviously is awd and the 7300 cost for it. Never have traction issues didn't think 7300 worth it between the 2 when only diff is awd. C2S is lighter too
08-25-2020, 09:19 PM | #73 | |
Rep 7,037
My dad raced rallye and motorcross when I was small. Watching his motorcross races (dirt track) he always took the start in his crazy beetle |
LSM1118.00 |
08-26-2020, 02:59 AM | #74 |
Rep 3,444
Ah, you noticed the omission. There should be two G83 versions. However, I only see the comp xdrives in actual metal. So it's possible the other version was cut before production. But I just can't prove it yet.
08-26-2020, 11:40 AM | #75 | |
Rep 850
2013 F10 M5 FG, 12.7 E92 M3 ZCP sold
08-26-2020, 09:35 PM | #76 |
General
21131
Rep 20,742
Drives: 2021 911 turbo
I am looking at acceleration above 60mph...
08-26-2020, 09:49 PM | #77 |
Rep 1,809
Yes C2S is lighter so faster slightly. 60-130.
My point was a RWD front engine car vs awd has major differences off the line where 911 does not due to engine in rear.
08-27-2020, 08:14 AM | #79 |
Law Enforcer
25206
Rep 22,306
08-27-2020, 08:21 AM | #80 |
Rep 5,742
Drives: '24 iX50; '23 i4 M50
I might have missed this, but will the AWD version debut next month too along with the base and zcp, or will we have to wait closer to SOP in July to get the details, see the stance, etc??
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
08-27-2020, 08:43 AM | #81 |
General
17551
Rep 25,133
I was messing too...the 'Pure' reference
My car made front page of Bimmerpost
08-27-2020, 10:08 AM | #83 |
Moderator
7525
Rep 19,368
I don't think that's known with 100% certainty, but I would be very surprised if AWD gets anything more than a passing mention as an upcoming feature, if even that. They are going to want to build excitement for what can be ordered and taken home now, not what's coming in the second half of next year.
08-27-2020, 11:55 AM | #84 | |
Rep 2,559
I doubt there will be any way to tell an xdrive G8x from a RWD G8x. -Stance will be the same (all Gchassis bmws have the same ride height for sport suspensions xdrive/rwd) -I think it's possible they won't badge it xdrive, considering the m5 and m8 are xdrive but do not show xdrive badges. (The only difference here is those cars are xdrive only but I think they will keep the cleaner badging) You can read the info on the Mxdrive from the m5 press releases it's more than likely this will be a copy/paste or small evolution of that system |
Kief4465.00 |
08-27-2020, 12:16 PM | #85 |
Rep 7,037
The M5cs should give us who wait for more G8X AWD information a better look at what M Xdrive is capable of in a more track focused car. I’m looking forward to see the usual benchmark number aka ring time for that car. The G8X AWD with track package shouldn’t be that far behind on the ring. I suspect that M5cs M Xdrive tuning efforts has gone into the G8X.
08-29-2020, 06:54 AM | #86 |
Rep 1,809
Why is M xDrive not available until July 2021? I can't figure it out.
I know there are many purists here, but I bet the take rate for AWD will be double that of RWD, especially since M xDrive has a RWD mode as seen with the M5/M8. I know there will be a 100-150lbs weight penalty, but I’ll still take it. |
08-29-2020, 10:26 AM | #87 | |
Rep 2,559
Maybe SCOTT26 can shed some light on the delayed intro... |
