02-24-2024, 12:38 AM | #1 |
Rep 5
Problems about OPF delete
Hi guys!
I recently installed the akrapovic midpipe on my EU version G80 and got the check enginel light. The opf delete cable already installed. Did i miss something? ----------- Just checked the thread https://g80.bimmerpost.com/forums/sh....php?t=1966161 Both the delete cable and the CAN module are needed to eliminate CEL? |
02-24-2024, 02:55 AM | #2 | |
Rep 72
Yes both needs to be installed And then you have to program the module. It's fairly easy. Look at the instructions on leib website and you will figure it out |
02-24-2024, 03:47 AM | #3 | |
Rep 5
https://www.leib-engineering.de/leib...ll-g-modell-en Well, it says it's a plug&play stuff, no need for programming? |
02-24-2024, 07:22 AM | #4 | |
Rep 72
Download and read the instructions before you install it. |
02-25-2024, 03:05 AM | #5 | |
Rep 18
I would expect that all needs doing is for ‘OPF replacement’ to be registered in ISTA. You don’t need the CAN delete. You can flash factory BMW software for the ROW model to completely eliminate the OPF as well. DM if you need help. |
