02-22-2024, 03:00 PM | #2 |
Rep 4,923
Is it a comp?
02-22-2024, 04:24 PM | #4 |
Rep 6,962
I think its 24.7 for the Competition, and the Manual is 18.9.
YT: G Dubyou |
02-22-2024, 04:26 PM | #5 |
Rep 4,923
Thats what car and driver stated but I’ve seen seen logs of around 22 psi in the upper gears. It all depends on the temp and altitude . Lower temps and sea level will run less boost.
02-22-2024, 04:32 PM | #6 |
Rep 284
Wow I'm running JB4 and I'm not even close to those numbers. I just had gauge installed and haven't given it a real good pull yet but i think im around 18 psi. I actually just check one of the logs on my JB4 and highest boost was 24.9. Looks like the average from the 3 pulls I did is around 22-23 psi. I see ECU__PSI column and boost column. For turbo boost its the boost column correct?
02-22-2024, 07:35 PM | #7 |
Chief Petty Officer
645
Rep 517
Like MAD said, its dependent on many factors. These cars don't have static boost tables anymore, they use volumetric efficiency and fill tables based on requested torque.
Map 2 is +5 psi to whatever the ECU is requesting. Personally I like the absolute maps on the JB4 compared to the additive. Map 2 has a tendency to overboost and cause throttle closures at mid rpm wot.
Limegrntaln13476.00 Info@mad-us.com1925.00 |
02-22-2024, 07:41 PM | #8 |
Rep 6,962
I haven’t looked any boost tables for these motors. Have you noticed any spike and drop off? Or can the turbos hold the same or full boost, until the car stops making power? And the 24.9 seemed high to me. I remember back in the day, even trying to get 21 out of a car, would start pulling the timing on pump gas.
YT: G Dubyou |
02-23-2024, 09:42 AM | #9 |
Rep 190,807
I have a competition, and my boost was 19-25
For piggyback users, including the JB4, note that piggybacks trick the ECU its making stock boost, so if you are checking the gauges, the power and boost will look identical to stock. To measure the real boost, datalog and you have a column that says boost, which is your actual boost, and another column that says stock boost, which is what the car stock would be targeting if it was not tuned.
Limegrntaln13476.00 |
02-23-2024, 04:45 PM | #10 | |
Rep 284
02-24-2024, 10:45 AM | #11 |
Rep 190,807
Which map were you on?
02-25-2024, 10:45 AM | #13 |
Rep 190,807
Thats +4 so your stock boost is 18-19, similar to what my stock boost was
