02-21-2024, 11:11 PM | #1 |
Rep 9
Intakes Hydrolock
Please delete if in wrong place. I recently purchased and installed front mount cold air intakes from RK Tunes. Sounds very good and also looks very nice behind the grill. My question is, should i be concerned about my engine being hydrolocked? Since the intakes are sitting in the front (right behind the grill), can’t water get in easily when it rains?
I’ve heard that there are sock like filters I can put over them but are they effective? If so, if someone can provide a link for one that’ll be great. |
02-22-2024, 12:10 AM | #2 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
Unless the car is in water that is up to the grill (like the shallow end of a lake or something), there is nothing to worry about that. |
02-22-2024, 06:33 AM | #3 |
Rep 1,929
Do you go full throttle for long periods of time when it's raining? Only then I imagine it would suck in water, whether that would hydro lock the engine is another question.
02-22-2024, 07:03 AM | #4 |
Rep 5,155
The F-bodies have run front mounts for years with no probs. Nobody has hydrolocked yet off an intake going “snorkel”.
02-22-2024, 07:03 AM | #5 |
Rep 55
I honestly don't get the fascination with the front mount intakes. Between possible hydrolock and needing to remove the front bumper to clean or change your filters it just doesn't seem worth the "cool looks"
But I'm sure I'll get brigaded here as usual for a logical comment. |
bilal5.00 Needsdecaf6607.50 |
02-22-2024, 09:51 AM | #6 | |
Rep 4,928
Absolutely not and issue unless the water level reaches those intakes. Be extra careful not to drive to fast in deep water and you will be fine.
Rain is a non issue. Quote:
The sounds produced from them is second to none and the intake air temps are excellent.
02-22-2024, 10:27 AM | #7 |
Rep 190,811
not issue as i have never heard of it happening on any BMW platform
02-22-2024, 10:59 AM | #8 |
Rep 256
Drives: '24 M3 Comp X-Drive
I installed mine also, and rain and stuff of the nature has already dwindled from my mind of issues. I’m curious though, going through a touchless car wash, where it power washes super strong, would blowing water directly at the filter as it passes compromise anything?
Haters gonna' hate, ainters gonna' aint.
02-22-2024, 11:10 AM | #9 | |
Rep 1,929
02-22-2024, 11:13 AM | #10 |
Rep 256
Most likely I am going to manually wash in a wash bay or other options, but figured I would ask the question out of curiosity
02-22-2024, 11:29 AM | #11 |
Rep 5,554
You’d want to search for car air filter pre-filters. They come in different shapes and quality. Higher quality ones are definitely waterproof and will keep the actual filter dry. They also extend the life/cleaning time of the filter because it minimizes the amount of dirt that gets imbedded in the filter.
02-22-2024, 12:41 PM | #12 |
Rep 569
02-22-2024, 12:55 PM | #13 | |
Rep 4,928
Either way the motor doesn't have much of an issue ingesting water many people use water injection as a form of knock reduction. Flooding a cylinder to the point it cannot compress the the piston is where you have an issue aka hydro lock. This happens on factory airboxes as well if the water is high enough.
yeetyeet391.50 |
02-22-2024, 12:58 PM | #14 | |
Rep 256
02-22-2024, 01:02 PM | #15 | |
Rep 4,928
Check out this post I made earlier. Front mount tends to be a few degrees cooler than the stock intake 60-130 https://g80.bimmerpost.com/forums/sh...3&postcount=47
02-22-2024, 01:26 PM | #16 |
Rep 687
You can smile driving in the rain knowing your cleaning the carbon off the pistons.
02-22-2024, 02:56 PM | #17 |
Rep 4,928
Thought that was only with meth injection.
02-22-2024, 03:03 PM | #18 |
Rep 687
02-22-2024, 03:19 PM | #19 | |
Rep 9
02-22-2024, 04:36 PM | #20 | |
Rep 4,928
Things to consider though - oiled filters will eventually need reoiling as the water washes it away. -a wet filter won’t flow like a dry filter will
02-22-2024, 04:40 PM | #21 | |
Rep 4,928
When people are worried about a little water in their intake I have to chuckle thinking back at how many gallons of water I shot into my engine on a weekly basis on purpose.
Skyscraper2202.00 |
02-23-2024, 07:44 AM | #22 | |
Rep 858
