02-10-2024, 12:42 PM | #1 |
Rep 230
Drives: '24 M4 Comp xDrive
Make the S58 NOT sound like a clapped out '95 Accord?
I did my research, for weeks, listened to every YouTube video available, got as much feedback as I could on this forum, then pulled the trigger:
- Supersprint catless downpipes - Supersprint catted single midpipe (j-pipe) - Stock muffler assembly It sounded okay to me at first, but I made the mistake of rolling the windows down and flooring in in Sport+ flaps "open." I literally busted out in laughter at myself and the fact that I spent $6K to make my car sound like a turbocharged tin can. It is so tinny and raspy that it sounds like the cars I used to make fun of as a kid. Now that car is me. Does anyone know how to make these cars NOT sound like s*^%, or is the S58 just beyond redemption? P.S. I have completely disabled ASD, so that is probably a contributing factor–I don't have any fake exhaust sound to drown out the actual completely terrible sound the car is making outside. |
02-10-2024, 12:53 PM | #2 | |
Rep 1,929
Catted midpipe? You mean resonated? Don't think the downpipes help in your situation.
aremmell123.50 |
02-10-2024, 12:55 PM | #3 |
Rep 230
02-10-2024, 01:09 PM | #5 |
Rep 1,929
Interesting, haven't seen those before.
Not sure what to tell you here, majority of exhaust basically sound the same, no one is really prioritizing sound quality. Seems you need to mix/disrupt the exhaust flow from the two turbos at the right spot, this usually takes time and money which most shops don't have. There was one exhaust that had a unique sound, but only a few people have it and its not made anymore. https://g80.bimmerpost.com/forums/sh....php?t=1975034
02-10-2024, 01:13 PM | #6 |
Rep 230
I'm going to turn ASD back on and live in blissful ignorance of what is really going on then.
02-10-2024, 01:19 PM | #7 | |
Rep 306
Drives: BMW M3 G80
R44 full titanium with flaps open sounds incredible - not raspy or tin canny. It produces a very exotic tone. I’d say second in line to the throne is AWE stainless switchpath and maybe IPE. But yea , I always laughed at the Frankenstein pipe mods. It truly does sound horrendous but everyone has different ears. I don’t know for a fact but I suspect that legit CATTED downpipes will truly make titanium exhausts sound even more incredible. |
Weather Man1125.50 |
02-10-2024, 02:18 PM | #8 | |
Rep 230
I am contemplating getting the Supersprint muffler assembly. It can't get any worse than it is, but it can get better... |
02-10-2024, 02:34 PM | #9 | |
Rep 306
Drives: BMW M3 G80
02-10-2024, 02:43 PM | #10 |
Rep 86
I understand what you mean. I recently installed a Valvetronic Equal-Length Midpipe paired with an Akrapovic Slip-on. While there's been a noticeable improvement in sound, I'm still not entirely satisfied. My ideal exhaust tone would be similar to that of the single turbo S58s.
The closest I've seen someone get to that sound is a British youtuber who made an "equal-length" 2-1 custom downpipe for their S55. By far the best sounding setup while still retaining the factory twin-turbos. If someone were to develop a similar downpipe for the S58, I believe the results would be quite similar. |
02-10-2024, 03:11 PM | #11 |
Rep 6,701
You should have left the downpipes alone. Go back to stock there.
adam12hicks250.50 |
02-10-2024, 03:27 PM | #12 |
Rep 1,446
If you wanted a good sounding car, you bought the wrong Car bud. Nothing is going to make it sound “ good”. These are better then the S55’s but not worlds better.
02-10-2024, 09:37 PM | #13 |
i can haz horsepowr ??
3831
Rep 1,927
Sound is always subjective, but there are steps to take to get the S58 to sound decent/good/better. Before I begin, I should note I've invested a heavy amount of time/money in the sound category for the G8X. If you take the following post in steps and in order, you'll have spent the least amount in terms of swapping parts and labour in doing so, and should get the ideal sound.
First off, start off with a valve controller. You can snag a fancy pants one like AWRON or dÄHLer, or you can get an inexpensive one that gets the job done. Either way, you need to ensure that you're hearing valves fully open or fully closed, or maybe 50% if that's what you prefer. Regardless, the car will refuse to open the valves 100% without a valve controller unless at 100% load and under certain RPM. Next, figure out your downpipes situation. Downpipes can be cheap, especially from MAD, and they can be taken on and off pretty easily so you can swap based off your needs after experimenting. Completely catless downpipes will be loud and raspy, will flow best, and are best for big power builds. Catted downpipes will tame both the volume and rasp depending on how many cells (100-400). Resonated downpipes will retain volume of catless downpipes for the most part, but will lower the rasp. Catted dp's may throw a check engine light, and anything catless will definitely do that. The only downpipes out there that will guaranteed not throw a CEL are GESI cats from AA, but they're expensive as hell and are 400 cell so they're not going to increase the volume that much. Next: midpipe. After you've got a valve controller and downpipes that suit your needs, you need to choose midpipes. Many are happy with normal single midpipes and many are happy with x-pipes, but I personally feel the best sound comes from AA's equal length midpipe and Valvetronic's equal length single midpipe. Both provide a smoother sound and eliminate, for the most part, the farty nature of the S58. Choose the AA if you want a raunchier sound that's louder, or choose the VT midpipe if you want a deeper rumble that isn't as screamy/raunchy. Lastly - the back box/muffler/axle back. I am an absolute believer in the OEM axle back. With catless dp's and completely resonator free midpipes, the OEM axle back is able to tame the G8X down significantly and make it sound near stock-like with the valves closed. But with valve open - it's a monster. However, if you've opted to keep your downpipes stock, you get to choose an axle back that suits your needs. However, axle backs are significantly more money and are more for vanity's sake than anything else. Axle backs like Remus' Race, or Eisenmann's Race, are loud and will compensate for catted downpipes to a certain degree. Remus' Sport, R44, VT, etc. sport axle backs are more tame and may provide some volume over the stock axle back, but it won't vastly change the sound at all. The way the car sounds primarily comes from your midpipes, and how loud it is is hinged upon your downpipes/axle back situation. If I'm being perfectly honest, I actually prefer the sound of my car without my Meisterschaft GT axle back and with the OEM axle back. However, it looks too pretty and I can't find someone to give me a free OEM axle back since I threw mine away IMHO, the best setup is catless resonated downpipes -> AA/VT equal length midpipe -> OEM axle back painted black to hide ugliness, alongside some sort of valve controller. Cost effective, relatively simple, very tame when driving around town and not trying to attract attention, but holy shit loud with valves open and your foot down. If the above exhaust combo just isn't good enough for your ears, then just do what I'm doing in a week or two - single turbo
Dakar Yellow G80 M3
forcefed2567.00 aremmell123.50 davisy2k177.50 jamabdi185.50 Dnshift156.50 EatThatLunchBaby386.50 testing02hwr120.50 |
02-11-2024, 09:15 AM | #14 |
Rep 376
I used to work at a recording studio and rule of thumb is no matter what you are not going to make Pink sound like Usher. Doesn’t matter what you do to the EQ. Whatever output is happening can only be enhanced or reduced. There is no changing the voice.
An exhaust is like an EQ. It can bring up certain frequencies and reduce others. This all depends on the tuning of the system as well as the material. Long story short this car will never sound like a cammed Camaro or a Lamb SVJ |
AYounglove10394.50 |
02-11-2024, 06:27 PM | #15 |
Rep 34
Drives: 2019 BMW M850i (Sold) 2022 BMW
Personally, I run Evolution Racewerks catless DPs and everything else untouched. I love the sound but the cabin is pretty insulated. Blessing and a curse. It's def loud, but you can only truly appreciate it with the windows down all the way.
I've been on the fence about doing anymore exhaust work, however I am team x-pipe. It doesn't sound that good on camera, but it sounds amazing in person. I like the raw sound as opposed to a glorified trumpet. I would 100% run the AA Goliath if my G80 was solely a weekend car. I think I just convinced myself to get the AA signature mid x pipe...darn Side note: I also hold the stock rear box sacred. Anything else and it turns it into a civic. Last edited by albion991; 02-11-2024 at 06:36 PM.. |
viciousmo310.50 |
02-11-2024, 07:16 PM | #16 |
Rep 261
Single turbo.... problem solved. End of discussion.
2021 - X3 M40i Phytonic Blue
2022 - M3 xDrive Frozen Brilliant Metallic White |
02-12-2024, 07:53 AM | #17 |
Rep 459
Like others have said, it's never going to be a great sounding car unless you go to a single turbo setup. I've got a Valvetronic midpipe in mine and it definitely helps, but it doesn't sound anywhere near as good as my N55 M2. Even with just a downpipe that car sounded incredible.
02-12-2024, 10:31 AM | #18 |
Rep 190,807
In my opinion, catted downpipes with resonated single midpipe and a decent axle back get the job done.
Skyscraper2202.00 |
02-13-2024, 03:36 AM | #19 | |
Rep 989
Drives: 2024 M4 Comp X-Drive
It’s easy enough to try if you still have your stock mid pipe and a very cheap experiment. (Just a couple of factory BMW exhaust clamps to connect the factory mid pipe back to the stock axle back)
02-13-2024, 07:22 AM | #20 |
Rep 253
I might be biased but I think my setup is about as good as it gets without going the single turbo route.
Bunch of clips of the setup here: Some more on my IG if you feel like digging through there as well: https://www.instagram.com/fl_g80/ |
02-13-2024, 10:46 AM | #21 |
Rep 190,807
Nice setup
static_void965.50 |
02-13-2024, 12:38 PM | #22 |
Rep 4,923
MAD 200 cell downpipes- https://mad-us.com/mad-bmw-s58-catte...-flex-section/
MAD Resonated Midpipe - https://mad-us.com/mad-bmw-g8x-m3-m4...race-included/ Total $1500 From there you can either keep the stock Exhaust or throw on our axle back muffler. Axle Back - https://mad-us.com/mad-bmw-m3-m4-g8x...-back-exhaust/ Add on $1350
