10-18-2023, 07:55 AM | #89 |
I'd hit it
1065
Rep 1,106
Usually 24 hours or so. Got in to the 5s for my 60-130 with cooler weather. 7.0 was the fastest before on the straight it’s e30 map
I’ll be at the 1/4 track on Saturday… did 10.2 last time in 104° weather… should be a little cooler
2023 M4 xd BSM IG: MFor_YourPleasure |
M2GUY51.50 |
10-18-2023, 08:03 AM | #90 |
Rep 87
I seem to be getting responses (once every 48 business hours)… how many revisions before you were complete?
10-18-2023, 08:18 AM | #91 | |
I'd hit it
1065
Rep 1,106
May 28th through July 20th… there were times I wasn’t the fastest at getting logs back because of work trips. I usually got a revision around 10:30a CST and sent over the log by noon then got the revision the next day around the same time
M2GUY51.50 |
10-18-2023, 03:33 PM | #92 |
Rep 241
I'm in Orlando as well, my shop is working with Paul on my E tune. In the same boat as you, waiting for revisions after logging. Hope to have a good file by the end of this week.
12-13-2023, 03:24 PM | #93 |
Rep 109
Can anyone who has done this post a pic of the wire they depinned on the 2nd BMW harness for the ignition? Some say it's blue and other's green.....
12-15-2023, 12:04 AM | #94 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
Jasinedward64.00 |
12-22-2023, 06:06 PM | #95 |
Rep 652
For those who installed the flex fuel engine bay version of the BM3 kit did it include the hpfp fitting shown below? My kit is missing this piece and when I reached out to pro tuning freaks they said the s58 engine version doesn’t include a hpfp fitting but their instructions and video all show the fitting for the engine bay version so
02-07-2024, 06:54 PM | #96 | |
60-130 Enthusiast
1397
Rep 739
I just got my BM3 Flex Fuel Kit (I have a G87), and I'm confused as to how this installs. As others have said, the Supra is vastly different from my car and this kit has one fuel line with two female ends and the sensor body which has two male ends. Every video I've seen on installing a sensor shows two male fuel line ends in the car with female pieces attaching to both ends. This kit only has one female end piece. The other thing that strikes me as weird is that all of the marketing claims that the logic board has an aluminum enclosure with 4 screws. Mine came with a plastic enclosure that just clips together. I can't even really tell if I have all the parts I'm supposed to have. Are there any instructions anywhere on the internet for installing the engine bay kit in a G8x car? proTUNING Freaks Can you guys help? |
02-08-2024, 08:57 PM | #97 | |
Rep 652
02-12-2024, 05:48 AM | #98 |
Rep 45
How are you guys depinning that wire? The video doesn't really show what's happening. Do you have to just push down the top of the pin from the top of the connector with a pick tool and pull the wire out the back?
02-12-2024, 09:38 AM | #99 |
Rep 229
Yeah there is a little stopper you have to push down to allow it to slide back and through the connector. You can do it with a pick, just a bit annoying lining everything up. I scuffed up the plastic a bit w a pin, but all went well. Depinning tool makes things easier.
02-12-2024, 07:06 PM | #100 | |
Rep 45
02-12-2024, 09:46 PM | #102 | |
Rep 652
2. Femto unlock - 700 euro plus shipping to/from Finland 3. BM3 Flex fuel kit - $600 You can do all the work by yourself and save a few bucks or pay a shop to do it all. |
Fugazii234.50 |
02-13-2024, 09:57 PM | #103 |
Rep 755
02-17-2024, 06:10 PM | #105 | |
Rep 248
https://youtube.com/shorts/RVgEAoLnvBc?feature=share
IG Perseus_Actual Performance: DP, Intakes, BM3 Flex Fuel tune By Bend Calibrations Cosmetic: CF front lip, Diffuser, and Spoiler |
02-17-2024, 09:03 PM | #106 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
02-18-2024, 06:12 PM | #107 |
Rep 30
If you aren’t using the fitting it seems like there is a lot of extra fuel line now. Just looking for clarification as well. Disconnect the fitting from the hard line coming off the hpfp, installing the provided line, then the sensor, then to the existing one line? |
02-18-2024, 09:16 PM | #108 | |
Rep 931
02-19-2024, 04:53 AM | #109 |
Rep 30
02-22-2024, 02:14 PM | #110 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
Thank you. Your video helped me on the actual positioning of the sensor. It's such a damn tight fit...is this how the g80 install is as well? Its so snug it almost didn't feel like it was going to sit in there at all...then I referenced your video (thanks for that) |
