03-10-2023, 07:38 PM | #1 |
Rep 401
bm3 flash help
Hi everyone. I just received my dme back from femto and tried to flash for the first time today. Tried the csl map since I haven’t installed my downpipes yet. The write got to 100% but then I started getting malfunctions on the dash. Tried to reflash my stock map, but now it won’t even write. Just keeps failing. I’m getting this on the screen now. I’ve tried to reflash with my laptop and my iPhone. Same message for both. Please help if anyone has ran into this.
03-10-2023, 07:42 PM | #2 |
Rep 5,155
Did you try Force Flash?
If that doesn’t help you have to email Dzeno at PTF support…
03-11-2023, 01:26 PM | #4 |
Rep 191
03-11-2023, 02:02 PM | #5 |
Rep 332
Make sure you have the car on a battery charger when flashing. After it finished it should have told you to shut everything off, wait 30 seconds, then turn the car back on. Usually once it comes back up the errors will be gone.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
03-11-2023, 02:03 PM | #6 |
Rep 401
03-11-2023, 03:03 PM | #8 | |
bmw tech
473
Rep 365
Lehigh Valley Motors
193 Front Street Hellertown, PA 18055 484.214.6464 Mainentance-Repair-Performance |
03-11-2023, 06:56 PM | #9 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
I always triple tap the start button to make sure it's in diagnostic mode so it doesn't turn off before the flash finishes.
03-24-2023, 03:01 PM | #11 |
Rep 401
Hi guys, sorry about the late reply. I just wanted to get everything resolved before I post. So basically what happened was, I purchased bm3 license and registered my car to it about two months ago. During the time I was waiting to do the femto unlock I received an ota update. Basically when bm3 registers your car it takes a snap shot of the “ID” of your dme. When the ota update happened the “ID” changed. So when femto received the dme, they unlocked it with the current “ID” from the ota update I had. When my dme came back and I downloaded a map, it was building the stage 2 map based on what was on record from BM3, which was the old “ID”. So when I flashed it there was a mismatch, which caused the dme to brick. My solution was to have the dme relocked and flashed to stock. And then I had to send it back off to Femto.
I received my dme back yesterday and protuning freaks made sure everything matches before I flashed. So everything is great now. Big thanks to Serge and the guys at femto. They were awesome to work with. Serge followed up with every step and even contacted Femto regarding the situation. Femto themselves were able to do the second lock quickly and send it back quickly as well. Kudos to both companies for awesome customer service!! |
03-24-2023, 04:08 PM | #12 | |
Rep 87
MIM5219.50 |
03-24-2023, 04:37 PM | #13 |
I'd hit it
1065
Rep 1,106
That's wild... Thank you for the update. I have a feeling you aren't he only one this is going to happen to. Good to know there's a resolution, even if it is a pain in the butt... couldn't imagine the initial headache.
2023 M4 xd BSM IG: MFor_YourPleasure |
03-24-2023, 04:51 PM | #15 |
I'd hit it
1065
Rep 1,106
I registered my BM3 license a while ago and just had the ECU sent out. A little nervous now lol.
03-24-2023, 07:18 PM | #17 |
Rep 401
03-24-2023, 07:23 PM | #18 | |
Rep 272
Sorry you had to go through all that man |
MIM5219.50 |
03-24-2023, 09:02 PM | #19 |
Rep 295
Contact FEMTO and see if there's anything they can do prior to them flashing on it. Maybe you can check on the BMW app? Not sure if it'll come up on the idrive with no DME.
M3Cx, E92 M3 6MT Previous cars: '21 Supra, '17 GT-R, '15 GT3, '13 GT-R '09 GT-R, '06 Z06, '06 Evo MR, '05 M3, '03 Evo, '00 Miata. |
2Times1064.50 |
03-24-2023, 11:53 PM | #20 |
Rep 401
The only way to know is to plug into your obd port and open up bm3. Once you do that, you click on your vin in blue. The next screen will show your “registered vehicle software details” on top, and “current software ID Details” on the bottom. 4 lines of ID that must match. Then before you flash you click on the map your about to flash and there should be 3 lines of ID that should match ur first 3 lines of the previous 4.
2Times1064.50 |
03-25-2023, 09:53 AM | #21 | |
I'd hit it
1065
Rep 1,106
I registered BM3 to my car as soon as they announced multimap and said it had to be registered to vin before sending to Femto… but then I did the break-in service and I think service did the software update.
MIM5219.50 |
