11-24-2020, 01:28 PM | #1 |
Rep 701
Auto start/stop for 6MT?
The 6MT image in the configurator shows an Auto-Start/Stop OFF button on the center console. How does that work with a clutch and manual transmission? I always assumed you couldn't have Auto-Start/Stop if you had a manual.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue |
11-24-2020, 02:57 PM | #2 |
Rep 93
Drives: 2020 M2 Competition
I have that on my 6mt M2c. The engine shuts off when the clutch is out and the cars in neutral... even while still rolling... it's annoying in traffic but apparently is effective at fuel conservation at the 4 second mark...I would guess it's regulations driven as its kind of silly on a car with dual high pressure fuel pumps.
11-24-2020, 03:04 PM | #3 | |
2056
Rep 1,984
11-24-2020, 03:48 PM | #4 |
General
17483
Rep 25,112
Pretty standard stuff here. In neutral and at a stop the engine goes off. Comes back as soon as you depress the clutch pedal or now also when the car sees the one in front move off.
My car made front page of Bimmerpost
11-24-2020, 04:06 PM | #6 |
Rep 3,213
Drives: 2018 BMW 440i GC
11-24-2020, 04:20 PM | #7 |
Rep 238
Drives: '17 M240i 6MT
My M240i 6MT has auto start/stop. When you get down to around 5mph in neutral and off the clutch, the engine shuts off. As soon as you're on the clutch again, the engine starts back up.
Note that if you put it in a gear when the engine shuts off, putting in the clutch won't wake the engine, you have to pop it in neutral then back to 1st. It also doesn't activate if you come to a stop in gear with the clutch in, presumably because you're just coming to a stop sign and need to get moving again quickly. |
mtpope3.00 |
11-24-2020, 04:21 PM | #8 | |
Rep 153
It’d have to be a tanzanite blue Touring for me Upholstery would be a difficult one though. Usually go for black on black, but the yellow/blue upholstery looks so good! |
11-28-2020, 04:27 AM | #9 |
Rep 96
I turn mine off on my 340 Xdrive 6sd most of the time...as I worry about the longevity of it. I know the B58 was designed with this mind..but still.
However, if I get stopped for a training crossing, or Drawbridge going up, I will pop it back on. For me, I don't ride ride the clutch, when a light goes green I quickly clutch, 1st in, blip throttle, clutch out...and the stop start delays it just a little bit to be annoying. |
11-28-2020, 06:18 PM | #11 |
I want to drive a Zamboni
1128
Rep 5,554
Drives: 13 E93 M3 18 F80 M3 16 K71
I turned it off completely on my F80 one less thing to go bad.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
2011ninja3374.50 |
11-28-2020, 07:28 PM | #12 |
Rep 253
It’s so ridicules that they manage to program this auto start stop shit on a manual and yet they can’t give us a simple remote start because the car has to be in neutral... how stupid is that. 🤦*♂️ I really hope someone will be able to code around this problem.
11-28-2020, 08:42 PM | #13 |
Rep 7,037
Yeah, this not a thing to be upset about. If you switch it off, it’s off until you you switch it on. I’ve had my F80 MT for over six years and I had auto on/off on for 5 minutes once just to test it out. Had a good laugh and never turned it on again
11-29-2020, 01:21 PM | #14 | |
Rep 2,557
On the plus side the latest systems are worlds better. I drove 2020 m340 and x5 and it was much smoother. Add fast forward to this year and the 48v mild hybrid in the 2021 B58s and I couldn't tell other than the engine sound it was there. However on my f30 6mt I did find I would just hold the touch down at stop lights more often just to leave the engine running if I forgot to disable |
11-29-2020, 01:23 PM | #15 | |
Rep 7,037
11-29-2020, 03:20 PM | #16 | |
1128
Rep 5,554
11-30-2020, 07:04 PM | #17 |
Rep 3,964
This was standard even on the E9X M3 after 2011, it was set to off by default
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
12-08-2020, 12:35 PM | #19 | |
Rep 751
Even if you don't normally leave it in gear while parked, the fact that you can and if you do it even once, it could be costly to remote-start it. |
rak299597.50 |
12-10-2020, 03:53 PM | #20 |
Rep 1,532
It's actually way better than on an automatic for reasons mentioned above. Only stops the engine when you're clutch out in neutral, starts back up again by the time you can get it into gear to move.
