05-01-2024, 08:33 PM | #1 |
Rep 3
Drivers side door clicking sound
First time posting on here, I have a 2022 G82 M4, about 17,000kms on it. And started to notice last week a clicking sound in the drivers side door around the hinge. Clicking Sound Video.
Video is attached, I can’t see any visible loose or damaged parts. Anyone else have this issue or know any solution without going to bmw first? They charge $313 just to check it out and they say creaks and rattles aren’t covered under warranty, (Past experience with a rattling noise from the dash). Thanks |
05-02-2024, 07:36 AM | #2 |
Rep 1,018
Find a new dealer. Creaks and rattles are definitely covered under warranty and there is no diag charge you pay to have an issue looked at while under warranty. Why do you guys let dealers pull this sort of shit on you? Report their bs business tactics to BMWUSA.
Limegrntaln13665.50 |
05-02-2024, 08:02 AM | #3 |
Rep 7,023
Definitely covered under warranty, but, from past experience, the door hinges are usually made of plastic, I don't have a bus, so, Im not sure how they are on the M3 rear doors, but, the plastic hinges crack in the eyelet, and if you look close enough, and sometimes the crack is on the back side of the eyelet, and you cant see it, but, as you open and close the door, it pops, expands, and the crack closes, again. This sounds exactly like that.
Heres an extremely lame example of what Im talking about. Dont do this stupid fix, its ridiculous. But, someone got a little wild with your rear door, and broke the check strap. Just watch the problem, and don't hang around for the solution, just get yours replaced. If this is broken, it was self inflicted, and the dealer is probably going to charge you to replace it. But, you have to remove the door panel to get to it, so, unless youre willing to do it, yourself, and save the money, you may be spending.
YT: G Dubyou |
05-02-2024, 08:17 AM | #4 | |
Rep 3
05-02-2024, 08:22 AM | #5 | |
Rep 3
