04-13-2024, 10:51 AM | #23 |
Rep 97
I have a manual 24 g80. One of the first things I did was replace the grill with a vorsteiner grill.
I wanted mesh behind it for protection but also I liked the look more than it just being so open. Vorsteiner sells a mesh you can add on but I didn’t like the pattern. I got some automotive mesh I liked off Amazon and cut it to fit myself and epoxied it in. Worked really well. You could do something similar (I also replaced the intakes) |
bri10426088.50 Race_Doc11464.50 |
04-13-2024, 11:29 AM | #24 | |
Rep 551
Drives: 2022 G83 M4
04-13-2024, 12:03 PM | #25 |
Rep 97
AggAuto Universal 40"x13" Car Grill Mesh - Aluminum Alloy Automotive Grille Insert Bumper 10x20mm Rhombic Hole, One of the Most Multifunctional Shape Grids 100x33cm Black
https://a.co/d/idoWcrv Thanks. I think it turned out really well. I got a few different versions of the mesh. Initially wanted it to have a finer mesh but I worried it may restrict air flow so went with the larger rhombus pattern |
04-13-2024, 12:22 PM | #26 |
Rep 207
I think it looks great. Hard to tell from the pics --- how did you secure it? Zip ties?
///M4 (F82) MT - Azurite Black/Full Black Merino, ZCP, ZPX, 248, 508, 5AG, 6CP, 6NW, Z67, ZQ5, 666M summer/437M winter wheels
04-13-2024, 12:28 PM | #27 | |
Rep 97
https://a.co/d/g3LeWH2 I cut and shaped the mesh so it hung over the edges about 2 cm. Secured the mesh tightly at the bottom with duct tape wrapped around. Globbed epoxy into mesh and let it run down between the mesh and the plastic/ carbon grill and intakes. Allowed it to cure and removed tape. |
jrhav246.00 |
04-13-2024, 05:29 PM | #28 |
Rep 465
I did the same thing, though I secured mine with black 3M double sided tape. Works great and I wanted something that would be easier than epoxy or glue to remove if I changed my mind down the road.
jrhav246.00 |
