      12-30-2022, 12:07 AM   #23
wjkalana
Drives: BMW M340 and X5 45e
What is ASD?
      12-31-2022, 10:57 PM   #24
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
Originally Posted by wjkalana View Post
What is ASD?
https://en.m.wikipedia.org/wiki/Active_sound_design
      01-03-2023, 10:42 AM   #25
amrh
Drives: 2023 M3Cx
I "coded" this on my ID8, this weekend. It seems louder in the car, now. Originally, I had inactivated the "main" ASD setting in Bimmercode. I felt it could be quieter and did the expert mode coding provided here. However, I believe it's louder, now. I did use the valve control button and it becomes very quiet - it's very nice. But, I don't want to have to touch that button each time I get in the car.
Seems like the expert coding isn't working as intended, since others aren't seeing (or hearing haha) the results they expect. I'll probably reverse the expert coding and see if it helps. It's unbearably loud with a drone, now.
      01-04-2023, 08:41 AM   #26
m3cs76
Drives: 2023 G80 M3 Comp xDrive
You probably coded the "asd channel in" to 8 ch when stock is at 1. I noticed the same thing that you did when I coded that one. I think it's pumping ASD through all the speakers. The drone was horrible.
amrh296.50
PLF693767.50
      01-04-2023, 02:20 PM   #27
amrh
Drives: 2023 M3Cx
This worked! Thanks so much!
m3cs76120.50
      03-26-2023, 08:52 AM   #28
Kwills3
Drives: DG/FR M3 (patiently waiting)
Any updates to this? I want to install my amp and sub but asd has to be horrible with that set up.
I think I mirror everyone else by wanting just want the sound not to be pumped into the cabin!
      04-30-2023, 08:07 PM   #29
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
Where do you back up the activation codes? I haven’t been able to tell.
      04-30-2023, 09:27 PM   #30
chris3g
Drives: 2023 M3 xdrive
Bimmercode backs it up automatically when you deactivate it. The backup itself goes in the bimmercode folder on your device.
wavyyyy1045.50
T0RM3NT3642.00
      05-02-2023, 05:50 AM   #31
Autoaddict
Autoaddict's Avatar
Drives: 2008 BMW 328xi Sportwagon, G80
I deactivated mine. It really shuts off when you turn the codes off. Now it’s vault like quiet inside. I mean really quiet.
M4Tejas788.00
      05-02-2023, 06:52 AM   #32
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Same here, I will be installing a VSC valve controller I have on the shelf witch did the trick in my past M4C.
The perfect setup for me would be a CSL muffler since I don't like the tip arrangement of the M Performance one and I don't want anything loud, I actually like the silent OEM setup when I am just driving around or on phone calls.
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      05-02-2023, 07:43 AM   #33
GTS Daddy
#Driver
GTS Daddy's Avatar
373
Drives: '23 G80x
I still do not understand clearly if asd can be fully deactivated in ID8. I do not want a valve controller and at this time not interested in aftermarket audio equipment.
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan
insta: gtsdaddy
      05-02-2023, 09:20 AM   #34
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Use the activation code method it worked for me. And what's nice about is it only removes the speaker stuff and leaves the actuation of the valves and burbles intact.
Daily: 2023 X5 45e
      05-02-2023, 03:32 PM   #35
TheFwed
TheFwed's Avatar
24
Drives: M3 xdrive Comp
The only method that worked for me (2023 M3) is the one described in the first post by playswcars
Deactivate in expert all ASD_*
Deactivate ASD in non-expert.
you are still getting the valve controlled by the exhaust button and the engine setting (exhaust is still louder in sport mode)
      05-02-2023, 08:58 PM   #36
VioletBlue_M3
VioletBlue_M3's Avatar
709
Drives: '23 M3 Competition xDrive
This is the only thing I did to code off ASD in my 2023 iDrive8 G80. I have installed an aftermarket amp and subwoofer using the technic pnp harness and I have zero exhaust sounds in cabin.
Using Bimmercode
- Connect
- Select “Receiver Audio Module”
- Select “Activation codes” from the menu in the top right corner
- Select the ASD activation code
- Select “Deactivate activation code”
2023 Violet Blue/Fiona Red Full - M3 Competition xDrive
@violetblue_m3
GTS Daddy372.50
PLF693767.50
bwoodahl235.00
M4Tejas788.00
      05-02-2023, 10:26 PM   #37
PipeM3
PipeM3's Avatar
196
Drives: IS 500, 2024 M3 comp RWD
Using Bimmercode
- Connect
Hi I’ll appreciate your feedback, I’m looking to install JLAudio sub. You have to use Bimmerpost first? And what is a technic pnp? Thank you!
      05-02-2023, 11:03 PM   #38
VioletBlue_M3
709
If you don't code out ASD before you add the amp and sub, you'll hear the exhaust rumble through the sub, very annoyingly.
Search for technic pnp harness online. You want the Top HiFi (Option 688) Add-a-Sub Harness for RAM/Booster audio systems. Get the LOC150i kit option for line level signals and power on trigger to the amp. Then just add any amp and sub sized for your space and taste.
@violetblue_m3
PipeM3196.00
      05-03-2023, 12:22 PM   #39
PipeM3
PipeM3's Avatar
196
Thank you so much! 💪🏻
      10-05-2023, 08:51 AM   #40
Ruebarb
Ruebarb's Avatar
375
Drives: BMW G42 M240i
Has anyone seen any issues with OTA Updates after Deactivate activation code? Did you need to reactive prior to the OTA?
I have mine deactivated, I hate fake noise, plus I added a sub .
Thanks
      10-15-2023, 09:24 PM   #41
Mike02z
Mike02z's Avatar
Drives: 2024 BMW M4 Base
2024 BMW M4  [10.00]
2024 BMW M4  [0.00]
Thanks
All custom coding gets wiped when you do a software update.
kgelfen3602217.00
Ruebarb375.00
      01-22-2024, 10:00 PM   #42
nardobenz
Drives: G80 M3
This way worked on my 24 g80 with Idrive 8. The normal way didn’t work for me.
Thank you sir!
playswcars3633.50
      01-26-2024, 12:04 AM   #43
Mapper
Mapper's Avatar
Drives: M3 Competition
Thank you sir!
What is "the normal way"?
      01-26-2024, 07:48 AM   #44
MBoriPerf
Drives: 2019 Audi Q5
so if I do it in expert mode I have to disable everything?
does this also means I losse burbles?
I want to disable it without losing the burbles, is that even possible?
Tags
active sound design, asd, bimmercode, bmw asd, code, coding, expert, g80 m3, g82 m4
