02-28-2023, 05:22 AM | #46 | |
Rep 255
Note when this happened to me, I reluctantly made arrangements to get the car towed by BMW roadside assistance to my dealer. However, The very idea of them having to extract my brand new car from my tight garage caused my anxiety to go off. Turns out, after I read suggestions from those who responded to my post, I chose to try boosting the car first (my wife’s Ford Escape was parked next to the M3 in the garage). It started immediately. I then took it for a long enough drive to bring the voltage back up. After a 30min boot around my local streets, I attached it to the charger and it began charging normally. Have not had a problem since then. However, like I mentioned in my previous post, while the car is back in storage (winter is back in Toronto ,) I don’t let it “sit” on the CTEK charger. I don’t trust it. Now, once a week or so, I’ll connect the charger, let it charge the battery to full capacity, then disconnect it. Cheers |
02-28-2023, 06:18 AM | #47 | |
Rep 1,806
02-28-2023, 06:28 AM | #48 | |
Rep 255
02-28-2023, 09:05 AM | #49 |
Save the Manuals
1714
Rep 2,937
Someone please get one of the Bluetooth battery monitors I mention above so we can discuss ! 🙏🏻
What I have found is the car sits for long periods and it maintains 13.3 V without dropping! The nature of lithium batteries, holding voltage until it absolutely, let’s go. I am wondering what your readings would be right before the batteries are disconnecting with UVP kicking in—- at what voltage level… and how fast that decline in voltage occurs. I am very curious.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
02-28-2023, 02:31 PM | #51 | |
Save the Manuals
1714
Rep 2,937
This is the one you want CTEK 56-926 LITHIUM US | Fully Automatic Lithium Ion Phosphate LiFePO4 Battery Charger | 5.0Ah - 60Ah | Maintenance Charging up to 120Ah https://a.co/d/gjcPzUi
2023 G80 6MT, CCBs
vinha91652.00 |
02-28-2023, 06:33 PM | #52 |
///M ♥ Recycled Dinosaurs
3213
Rep 1,782
Drives: BMW M4, BMW X5 45e
Saw M3 CX and “completely dead” in the title and knew instantly what was up.
It’s the power draw from the ultra-wide screen TV on the dash. I kid. I kid. Carry on. |
mathys213.00 Limegrntaln13616.00 |
03-01-2023, 12:46 PM | #53 |
Save the Manuals
1714
Rep 2,937
Haha
My CTEK makes my M3 a plug in hybrid 😜
2023 G80 6MT, CCBs
vinha91652.00 Limegrntaln13616.00 |
09-28-2023, 10:51 PM | #55 |
Rep 56
Battery low start engine
it might be self explanatory but just wanna check in. I drove my car last Friday and today I uncocked the car to get something out of it and locked It back. later on I checked the bmw app and it showed the status as "unlocked" still. later on at night I sat in the car and the message came up on the dash "start engine low battery. Is the battery supposed to be going low after a week of not driving etc? Taking it to the dealer in the am. might need to get a battery charger.
09-29-2023, 07:05 AM | #56 |
Rep 1,312
Drives: 2024 BMW M4 Base
I’ve had multiple BMW’s and never trickle charged them from the battery. Works just fine connected to the jump point and a ground. I use the comfort connect and hardwire to the jump points.
09-30-2023, 10:52 AM | #57 |
Rep 165
So heading into my first winter and I won't drive my car in the salt.
I have a Noco Genius 10 charger, sounds like it would work fine for top off charging during the hard Utah winter. Will it be fine or do you really need a CTEK charger? |
10-03-2023, 05:16 AM | #58 |
Rep 998
Drives: 2024 M4 Comp X-Drive
I think the best solution to this predicament is a set of winter tires and wheels and enjoying the car year round
(That’s what I do)
10-27-2023, 06:42 AM | #59 |
Rep 474
Just get yourself a cheap digital multimeter and monitor the battery voltage with the charger disconnected. See the attached chart for state of charge info.
davidmct-M3235.50 |
10-27-2023, 07:04 AM | #60 |
Rep 1,439
It claims to support Lithium Iron Phosphate batteries, as long as there's a Battery Management System, which our cars have. So I think you're good, as long as you hook it up such that the BMS is in the circuit (which is probably the same for the CTEK).
AWDSOME631.50 |
10-27-2023, 07:16 AM | #61 |
Rep 474
I have to wonder is after the charger goes into the maintenance step if it will revert back to supplying steady full charging voltage to replace the energy lost with opening the doors (and having every thing power up) numerous times while in storage. If it doesn't then each time the door is opened the battery will drain further and further.
Another thing of interest is that Lithium Ion batteries in long term storage should be kept at about 60% - 80% charge rather than full charge. My new Apple Macbook only charges to 80% and if I am going to use it heavily that bay on battery I need to finish off the charge to 100% before disconnecting it from the charger. |
10-27-2023, 07:34 AM | #62 | |
Rep 1,439
Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged. The voltage for this step is listed as 13.4-13.8V. |
10-27-2023, 07:55 AM | #63 | |
Rep 7,018
YT: G Dubyou |
01-22-2024, 04:17 PM | #64 |
Rep 19
Connection to the negative post there is easy (if you have the correct size Torx bit to loosen it). Is there a similar sized post at the positive terminal? I pulled the plastic cover off and see a post which also has Torx style drive, that's larger?
01-22-2024, 05:30 PM | #65 |
Rep 1,312
It’s a T45 or T50 as I recall. Just like the ground it simply unscrews.
01-23-2024, 06:44 AM | #66 |
Rep 474
Before you fuss over setting to .1 psi accuracy you should check the accuracy specs on the digital gage. A lot have an accuracy of ½ psi despite their reading in .1 psi increments.
