01-28-2022, 09:24 PM | #1 |
Rep 14,134
Drives: G82 M4C X-Drive
What did you discover about your G8X today?
Forgive me if this thread already exists, I'm carrying this over from other forums. What cool or not-so-cool thing did you discover about your G8X today? It could be a feature you never knew about, some strange aspect of the car, some weird label you found on some random part in the engine bay, a new quirk that you like/don't like etc... anything!
I'll start: If you hold down either the M1 or M2 button, it will reprogram to the current settings!
9
jas1651452.50 Custom Install2232.00 Patton2502939.50 jocamero48.50 BIGW0RM3190.50 Scorp!on1514.50 farfugnugen66.50 Aalfred2626.50 dynebolik30.00 |
01-28-2022, 11:21 PM | #2 | |
Rep 482
01-28-2022, 11:26 PM | #3 |
Rep 1,740
I'll play. If you hit the Start/Stop button three times in diagnostic mode, you can open/close the valves with the VCS-2 controller without starting your engine.
mikezmoney81.50 Yuvi2004300.00 Limegrntaln13565.00 farfugnugen66.50 M3LISSA808.50 AlpineWhiteG80m3147.50 ThirstyX3M105.00 |
01-29-2022, 06:22 AM | #4 |
Rep 753
Drives: G82 M4 Comp X-Drive Individual
If you wake the car up by pressing the start button without your foot on the brake (auto trans) you can pre select one of your M drive modes and then start the car up in sport plus if configured. Your neighbours will thank you for this 😊
You can programme the window to go down at a specific location, so I have my drivers window drop just as I reverse into the garage. It helps when getting out of the carbon buckets. I have programmed the heated seats and steering wheel to auto start below 9 degrees C. EDIT: On the Gxx you can select without having to wake the car. Just press and start
E30 325i Sport: E36 318is: E36 328i Sport:
E46 330Ci Sport: E86 Z4 3.0i F82 M4: F82 M4 Comp Individual LCI G82 M4 Comp X-Drive Individual FDG |
12
Ocho3.00 BardG212.50 _E90S65_739.00 annual18.50 Mamba283.50 SaMaster144467.00 BMWM4CX281.50 m.dreamin1614.50 farfugnugen66.50 element561092.00 ThirstyX3M105.00 dynebolik30.00 |
01-29-2022, 07:52 AM | #6 | |
Rep 317
01-29-2022, 07:55 AM | #7 | ||
Rep 753
01-29-2022, 08:18 AM | #8 | |
Rep 2,538
01-29-2022, 08:23 AM | #9 | ||
Rep 753
Patton2502939.50 |
01-29-2022, 09:00 AM | #10 | |
Rep 482
01-29-2022, 10:34 AM | #11 | |||
Rep 482
01-29-2022, 10:36 AM | #12 | |
Rep 482
01-29-2022, 11:37 AM | #13 |
Rep 1,683
You can power off the gauge cluster/infotainment by holding down the mute button if you're sitting in your car while the engine is off or simply wait 10min for it to auto shutoff.
Holding down the mute button for 20 secs restarts the infotainment system. This was helpful when my android auto stopped working unexpectedly. |
AlpineWhiteG80m3147.50 harperium1319.00 |
01-29-2022, 12:46 PM | #14 | ||||
Rep 753
01-29-2022, 01:39 PM | #15 | |
Rep 14,134
01-29-2022, 02:32 PM | #16 |
Rep 754
Drives: 2022 M3 Competition
It's costing me a ton of cash in mods.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
9
jmg18831.50 chicagofan0019258.50 Dhillon63141.00 JDUNITNOW3579.00 Limegrntaln13565.00 farfugnugen66.50 element561092.00 e46grk27.00 dynebolik30.00 |
01-29-2022, 02:34 PM | #17 | |
Rep 754
01-29-2022, 02:37 PM | #18 | ||
Rep 753
01-29-2022, 04:01 PM | #19 |
Rep 247
01-29-2022, 04:11 PM | #20 |
Rep 753
Are you on the Gxx platform?
01-29-2022, 04:25 PM | #22 |
Rep 753
I found it quite confusing at first. The cars control system is fragmented. You have all the ID7 settings within the cars IOS and then if you go to installed Apps you have additional settings that are app based but are also integrated to id7.
