09-14-2022, 06:35 PM | #1 |
Rep 7,002
Pressure Washer Talk
Finally, after waiting all year for this to be released, they started shipping about a week ago. Mine got delivered, today.
Active 2.0 Electric Pressure Washer. A real world 2.0GPM flow rating. Rated at 1,800 PSI, but for washing cars, that shouldnt matter. What we want is 1,000PSI, and over 2gpm of real world flow, not what the box says the pump is rated at. At $350 (US) this is going to be the best pressure washer, under $1,000. Open discussion for higher end pressure washers. I'm not talking about KÄRCHER, or RYOBI, or SunJoe. I mean Krānzle, Comet and AR Blue Clean AR-630, Active, etc.
YT: G Dubyou |
09-14-2022, 07:34 PM | #2 |
Rep 620
Thank you for this post!
I've been wanting to upgrade from my 4 year old electric Ryobi, 1700 psi, 1.2 gpm. Just need to figure out how to give my wife hints before Christmas… |
Limegrntaln13560.50 |
09-14-2022, 07:46 PM | #3 |
Rep 472
Drives: '23 M4 CompX; '98 m Roadster
Been waiting on this one with baited breath!
'23 G82 M4 Comp X, Toronto Red, Silverstone Full Merino
'98 M Roadster, Estoril Blue Metallic, Estoril Blue & Black |
09-14-2022, 08:23 PM | #4 |
Save the Manuals
1714
Rep 2,937
Man that thing is small!
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
09-14-2022, 08:38 PM | #5 |
Rep 3,998
Looks awesome!
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
09-14-2022, 10:48 PM | #6 | |
Rep 7,002
I didn't get it until later in the day. It was already too hot to wash cars. I'll be using it in the morning. I'll definitely report back. Small and mighty. Over 2gpm, it's powerful. 5 piston axial pump. It's the shit.
YT: G Dubyou |
09-15-2022, 11:06 AM | #7 |
salty cowboys fan
6191
Rep 3,420
Been eyeing one of these as well. Only problem I have with my Comet is that it’s loud as f. Hopefully this is a bit quieter, otherwise I guess it’s Kranzle time
Limegrntaln13560.50 element561092.00 |
09-15-2022, 11:22 AM | #8 |
Rep 188
I tried sun joe, ryobi, karcher, and active (VE52) pressure washers which all died or had severe issues within two months. I finally just waited it out and got a Kranzle and after 3 months of use so far I am very happy with it.
The Kranzle is built like a tank with replaceable parts, and is also significantly quieter than the other options. My .02, skip the ones made in China and go straight to Kranzle. |
Limegrntaln13560.50 Asmedbeats370.50 |
09-15-2022, 10:59 PM | #9 | |||
Rep 7,002
YT: G Dubyou |
09-16-2022, 06:49 AM | #10 |
Rep 370
The wheels take the longest time. I tried pressure washers before and not much luck. How strong can you go with the pressure without ruining the rims.
09-16-2022, 08:27 AM | #11 |
Rep 7,002
It doesn't have enough power to take the paint off the rims with a 40° nozzle. And it's more about gallons per minute that actually does the cleaning work. You can run this thing at 700psi by changing the nozzle size and it has so much car pressure washing powers, the extra water flow, will feel stronger than if the pump was running at 1,200 psi. To change pressure you change the nozzles. Nozzles go from about 2.0 to about 7.0 orifice size. The unit comes with a 3.7 orifice nozzle, which supposedly rates the machine at 1,800 psi at 1.8 gallons per minute. Bump the nozzle orifice size to a 5.0 or a 6.0 and you get down to 1,200 and 1,050 psi. But at 2.1gpm and 2.3gpm. Less pressure more water flow. The pressure isn't blasting the dirt off as much as the gallons per minute are doing more cleaning at a higher gpm rate. Putting a higher gpm nozzle on the pressure washer. Also lowers the amperage draw and makes the motor work less, which in turn, makes it last longer.
YT: G Dubyou |
09-16-2022, 05:54 PM | #12 | |
Rep 370
Wow thank you. Great info! |
09-16-2022, 06:05 PM | #13 |
Rep 7,002
You're welcome. I hope it helps a future decision.
YT: G Dubyou |
09-16-2022, 08:44 PM | #14 | ||
Rep 65
Alvinmark12668.00 Limegrntaln13560.50 |
09-16-2022, 09:11 PM | #15 |
Rep 370
09-16-2022, 09:15 PM | #16 |
Rep 218
Drives: 2023 M3 Comp Xdrive
Love my kranzle. I bought the kit from obsessed garage. I signed up for their membership which made it cheaper with the discount. Totally worth it.
09-18-2022, 04:08 PM | #17 |
Save the Manuals
1714
Rep 2,937
I got CCBs
To avoid some of this
2023 G80 6MT, CCBs
CCM11285374.00 Limegrntaln13560.50 |
09-18-2022, 04:20 PM | #18 |
Rep 3,998
This is literally half the reason I opted for CCBs.
Once you've had them it's hard to ever go back to steel.
09-18-2022, 05:28 PM | #19 | |
Rep 1,661
Like I say, "If you're going to do it, do it right!" |
09-19-2022, 03:31 AM | #20 |
Rep 701
Kranzle every time. Brass lumps make them heavy but they are bomb proof. Anti tangle hose, short trigger with quick release attachments, job done.
Wo-Wo Detailing Accessories
www.wo-wo.co.uk |
09-29-2022, 11:25 AM | #21 |
Rep 221
I also recommend putting one of these on the supply hose.
https://www.amazon.com/Camco-Sedimen...25750607&psc=1 Helps reduce/eliminate water spots. |
09-29-2022, 05:24 PM | #22 | |
Rep 617
You will still get water spots with one of these inline. |
SetAlias223.50 |
