      11-14-2021, 09:32 AM   #67
RogerM_vrt
RogerM_vrt's Avatar
76
Drives: 2021 bmw m4, 2021 bmw 228i
Originally Posted by PLife View Post
Wow you ran 28 psi kn pump gas only?!! Was it 91 or 93? Man be careful youre gonna blow a rod or something I dont think pump gas is safe for 28 psi. Also, this map should be in the 6s with some e85 or race gas for sure! Regardless nice run and great shifting.
Oh.. lol just read the first page, technically it’s pump gas, vp in Miami has a pump station this is on 1/4 tank of 93 and 5 gal e80 5 gal of ms109
      11-14-2021, 01:26 PM   #68
PLife
PLife's Avatar
Drives: X5 M50i, G80 M3 xdrive
Thats what i figured. 7.2 with a manual is crazy fast plus 28 psi is kablooie sauce without high octane
      11-14-2021, 04:52 PM   #69
RogerM_vrt
RogerM_vrt's Avatar
76
Well I beat my buddy’s 660whp zl1 on a 50-180mph roll and he does 6.78 60-130 I fell back a little bit then reaped him back in and put a car on him, I need sticky tires then I shoul hit a low 6
PLife647.50
      11-14-2021, 05:30 PM   #70
PLife
PLife's Avatar
Yeah the G8x is a beast. You need a heavy hitter to beat it like 720s or F8 tributo.
      11-25-2021, 01:26 PM   #71
GabbyChaves
GabbyChaves's Avatar
Drives: Bmw M4
Little update with much nicer temps and dialing in midrange. Interesting note. Once I started adding a bit of boost in the mid range 4-5500rpm the car is absolutely much slower in "sport mode" engine setting. Log confirms crazy amount of throttle closures. When running in "comfort" engine settings it has a couple closures but consistently much higher throttle values across the entire range. Still peak boost target at 22psi
PLife647.50
02M3ForMe4261.50
      12-03-2021, 07:34 PM   #72
M3AWD
M3AWD's Avatar
Drives: 2022 G80 M3 AWD
I tested my new dragy tonight and here are a couple of runs. There were more cars in the area than I'd like so I gave up before setting any records
The VALID run shows a big difference vs. 1 ft roll-out. Is this because the car moved slightly before releasing the brake?
The INVALID run apparently was due to a negative slope, which I believe was mostly towards the end of the run based on the height line on the chart (correct me if I'm wrong!) Can I assume that the 0-10mph time from the INVALID run is realistic under my conditions?
If so there's potential for 0.25sec improvement over my VALID run. Is this how it works?
M3 Comp xDrive, Stock, 93 Oct, asphalt street
2022 G80 M3 Comp M xDrive
PLife647.50
      12-04-2021, 04:22 PM   #73
PLife
PLife's Avatar
new runs for me. 24.4 psi pump gas 93 much better DA.
Y@nnick51.50
DimM3302.00
      12-04-2021, 05:10 PM   #74
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
That's pretty beast! I believe that's about what a GT500 runs so very fast considering that's a 760hp car
I'm curious if a full tune and exhaust (aka Stage 2, when tunes become more available) will run faster than the equivalent piggyback + exhaust as we're seeing here.
PLife647.50
      12-05-2021, 07:40 AM   #75
PLife
PLife's Avatar
If the torque limiter is removed it can 100% go faster. The car is limited to around 620 ftlb for the zf auto. It will not exceed it and will partially close the throttle intake flap to keep the tq constant. A tune that just ups the limit by 30-50 ft lb will make this car insane
      12-05-2021, 05:18 PM   #76
Odinsrighthand
Drives: E36 M3, G80 M3C
Stock 2022 M3C RWD, cold day, Pirelli tires. 92 octane fuel (Idaho) please add me to the list.
PLife647.50
Patton2502939.50
      12-05-2021, 06:27 PM   #77
Sbm007
Sbm007's Avatar
United Kingdom
614
Drives: G80 M3CX (Oxide Grey)
Stock M3 Competition M xDrive (AWD). 95 octane fuel (99 RON)
100-200:
Gone:
2011 E90 318d (Alpine White) • 2016 F83 M4 (Mineral White) • 2019 F83 M4 Competition (Sapphire Black)
Current:
2022 G80 M3 Competition M xDrive (Oxide Grey)
PLife647.50
      12-05-2021, 06:40 PM   #78
PLife
PLife's Avatar
You guys are killing me with the work keep it up
Sbm007613.50
      12-05-2021, 06:41 PM   #79
PLife
PLife's Avatar
Lets see some race chip times.......
DS_BMW1603.00
      12-06-2021, 03:40 AM   #80
Sbm007
Sbm007's Avatar
United Kingdom
614
Also would like to see some stock M3 RWD 100-200 times for comparison! Should be a 0.5 sec quicker, maybe 7.8?
Gone:
Current:
      12-06-2021, 02:06 PM   #81
M3AWD
M3AWD's Avatar
which explains why you missed my 0-60 run posted a few posts above (one is valid, 0-60 3.39s)
      12-06-2021, 09:55 PM   #82
PLife
PLife's Avatar
If u think thats the best you can do Ill put it up. But im not doing it every time you do a dragy run LOL
      12-07-2021, 05:46 AM   #83
M3AWD
M3AWD's Avatar
No man was messing with you... I'm waiting for the rain to move and will go out for a few runs.
PLife647.50
      12-07-2021, 06:58 AM   #84
PLife
PLife's Avatar
I know im paying too I know you can do better and you/ll be back with a 3.1
M3AWD3181.50
      12-08-2021, 06:09 PM   #85
G80_Soom
Freude am fahren
G80_Soom's Avatar
Drives: '21 G80 M3 6MT IOMG/KO
2021 BMW M3  [0.00]
Pump gas means 89-93 haha. E85/Racefuel doesn't count in for this thread haha
      12-08-2021, 06:11 PM   #86
G80_Soom
Freude am fahren
G80_Soom's Avatar
2021 BMW M3  [0.00]
93 oct - JB4 - Catless DP - Mid-Pipe - Intakes
Now driving: '21 G80 M3 Isle of Man Green 6MT
Also driving: '16 340i M-Sport Estoril Blue 6MT
Retired: '01 E46 325xi
'13 F30 Estoril Blue 335i 6MT
#savethemanuals
      12-09-2021, 06:01 AM   #87
PLife
PLife's Avatar
Originally Posted by Y@nnick View Post
definitely Plife your map 6 is strong ,instantly gain 1mph trap speed and PB everywhere except 0-60, 38F cold and spinning at launch, I believe 10.4 is achievable with your map6 and better condition(traction) and perfect launch! thx
I forgot to ask what octane gas were u using for these runs. These are the numbers i normally get for e25 on this map
      12-09-2021, 09:04 AM   #88
Y@nnick
Drives: 2017 m240i white
I thought it was a map for gas pump, i use petro-canada 94 octane, we do not have acces to ethanol here! but petro94 can contain up to 10% ethanol! but log look good!
DS_BMW1603.00
