      03-19-2021, 03:38 PM   #23
vcx
vcx's Avatar
83
Drives: 340 xdrive MPPSK 6-manual
Originally Posted by bjcarls View Post
The standard M3 runs a max of 18.9 psi compared to 24.7 psi in the Competition
I wonder how such an important difference in boost results in only marginally more hp.
When I put my b58 engined car in stage 1, I saw a much more dramatic change in power while the boost didn't increased that much.
Does anyone have an explanation ?
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07
      03-19-2021, 04:00 PM   #24
SickGTR
1082
Drives: 1000whpGTR/ F-82 YAS
Just cause you are dumping more PSI in doesn't always mean you get every HP you think. It's all about the Air temp, fuel, tuning and other factors. It's factory, so the turbo will be in a happy place. If someone cracks the ECU and you go E-85 with some injectors, now you are talking.
      03-19-2021, 06:03 PM   #25
Bahamut
Bahamut's Avatar
Drives: G80 6MT
So pretty safe to say both the 6MT and ZF8 are easily putting down higher numbers than rated from BMW. Amazing! So can I claim to rock a 500hp manual BMW upon delivery?
      03-21-2021, 09:41 AM   #26
2011ninja
2011ninja's Avatar
Jamaica
3396
Drives: 2022 G80 6MT
Originally Posted by giphlag View Post
Originally Posted by AlterZgo View Post
I know one cannot directly compare different dynos on different days and areas with different weather locations, but comparing this M3C dyno to Autocouture's M4 base 6MT dyno gives me hope that these cars have very similar power levels rather than the 30 hp and 73 lb/ft of torque disadvantage officially listed by BMW.
You know I was wondering about the differences in output between comp and base model. Is it simply a tune difference? And therefor one could assume the base model can be brought up to comp-level performance?
I've found that the driver skill of a manual driver off sets the power difference of the competition package.
Manual driver skill is equivalent to +30 HP
Well that's been my experience on the streets...
      03-21-2021, 10:31 AM   #27
OSee
Drives: M2 Sold
Don’t forget the 10hp you get by switching out the shift knob.
      03-22-2021, 04:20 PM   #28
Ilikemike
Ilikemike's Avatar
Drives: E92: F82: M2C: M2 CS (Now)
Originally Posted by M3AWD View Post
Appreciate posting this!
I'm afraid until we see dyno runs on the same dyno & under the same conditions of G8x vs. F8x I don't think we can draw any conclusions.
Exactly! If you don't have a baseline with which to compare the data it's potentially all placebo...
M3AWD3181.50
      03-14-2022, 04:03 PM   #29
0Camus0
0Camus0's Avatar
154
Drives: BMW M4 2021 Base / Supra 2020
Do you have a source for this? it's from logs? I can't find this info anywhere.
I have a base and stock the max boost target is about 17 psi.
      03-14-2022, 04:09 PM   #30
ROBERT1183
ROBERT1183's Avatar
Drives: 2021 BMW M3 DRAVIT GREY 6SPEED
I dont doubt it one bit. On paper my G80 6speed isnt much of a difference from my f80 6 speed comp 473hp to 444hp. But from the seat it definitely fees like more than a 29hp difference.
