01-11-2024, 04:46 PM | #1 |
Rep 230
Drives: '24 M4 Comp xDrive
What would you do if you were me?
I was doing some work under the hood and dropped a magnetized Torx T30 bit into the depths of my engine bay. I am 99% sure I heard it ding when it hit the bottom panel underneath, but:
All I have here is a low-profile floor jack and 2 jack stands. I do not want to start the car just in case the tool is stuck somewhere that will jam something up. I am considering trying to access the front jack pad position from the front of the vehicle if the jack will reach: I would chock the rear wheels and get it as high as felt comfortable doing from that position, then hope the damn thing just rolls out of the engine bay, or put jack stands on both sides and then get under there and go to work... What would you do? |
01-11-2024, 04:55 PM | #2 |
Rep 273
Drives: 2023 M3 Comp
I would try using a long flexible magnet tool. I dropped the metal paper thin baffle disc that goes in the turbo inlet when installing my eventuri intakes. It took some fishing around, but magnet picked it after blindly fishing around. Similar to this.
jmg18708.00 M4ROLLIN20182.00 |
01-11-2024, 04:56 PM | #3 |
Rep 1,929
Take one of the wheels off and take the wheel liners off and try to reach for it with a magnetic pickup tool.
01-11-2024, 04:57 PM | #4 |
Rep 853
Jack it up, put it on stands and take the panels off under the engine to get it. FYI, you can just pull the parking brake to keep the back wheels locked, but that’s your call on that or chocks.
In the end, it depends on where you dropped it up to as to where it went. |
01-11-2024, 05:10 PM | #5 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
Ive done that so many times now. Magnet on a stick and GO FISH! You'll find it.
01-11-2024, 08:51 PM | #7 |
Rep 230
01-11-2024, 08:51 PM | #8 |
Rep 853
01-11-2024, 08:52 PM | #9 | |
Rep 230
I just need suggestions for magnetic 'find the sh** you dropped' tools. |
01-11-2024, 09:04 PM | #11 |
Rep 230
01-11-2024, 09:09 PM | #12 |
Rep 1,929
That's just the plastic cover that you take off for an oil change, just twist and it pops off.
01-11-2024, 09:10 PM | #13 |
Rep 230
01-11-2024, 09:22 PM | #14 |
Rep 397
01-12-2024, 07:54 AM | #15 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
when that happens I trade the car in on one with no bits in the bay.
aremmell123.50 |
01-12-2024, 08:19 AM | #16 |
1919
Rep 1,889
Drives: E92 M3
If you're going to use any magnetic tools to poke around the bottom of the engine bay from the top, disconnect the battery. The battery charging post is the mostly likely item to make some sparks, but better not to find out what else can do it.
01-12-2024, 11:04 AM | #17 | |
You got my money?
3156
Rep 4,646
Yea dude. Ive dropped my intake clips many times now and had to hunt them down with something like this. https://www.amazon.com/NoCry-Extenda...zcF9hdGY&psc=1
01-14-2024, 10:00 PM | #18 |
Rep 230
Got the bastard. I went with removing the passenger side wheel, and actually it was within view from there using a bright light. Getting it out was a different story but I won in the end.
Thanks for the input fellas. |
01-16-2024, 07:51 PM | #19 |
Rep 230
01-16-2024, 09:52 PM | #20 |
Rep 230
OP Update:
I just had a very scary incident. The car was on two jack stands using polyurethane jack adapters for BMW, plus a low-profile floor jack as an emergency backup barely sitting beneath the front jack point indicated in the OP. Rear tires were chocked (one on both sides, one just the rear), in park, parking brake engaged. I was done doing what I had the car in the air for, so I jacked it up a couple inches and slid the jack stands out, then began to slowly let pressure out of the jack to lower the car... To my dismay, as I lowered the jack as I have done countless times, the jack and the car started rolling toward me. I had to think fast because I was imagining what could happen if the car slipped off the jack while still in the air: nothing good! I decided to just fully open the jack valve as quickly as I could and it made a terrible sound (that jack is probably kaput and no longer trustworthy) but as far as I can tell, it stayed in contact with the jack point on the bottom of the car all the way down (the jack point is surrounded by either solid aluminum or very thin plastic sheets). There is now a hole in my drywall because I had to flatten the handle quickly too as to not damage the bumper as the car came down quickly... but I guess that beats paying for a new bumper. Anyway, I needed to post this, both as a form of release, and to warn everybody that the jack point indicated in the OP is likely designed for emergency use only, and that it is not a stable point from which to lift the car much higher than needed for say, changing wheels out. Definitely do not lift the car several feet in the air to get jack stands under the jack pads behind the front wheels!!! Now comfort me and tell me everything's gonna be all right... |
01-16-2024, 10:01 PM | #22 |
Rep 230
