11-11-2021, 01:07 PM | #1 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
So I was driving the other day back from lunch and I get a check control message noting a drivetrain malfunction. So I turned around and went straight to the dealer. On my way there it went away, oddly enough the power was super limited during that time like your low on fuel (I wasn't). Dealer wanted me to leave it for a few days to which I said no since it seemed fine and has been since. Who has has had this happen? I still need to have them pull the code off it.
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
11-11-2021, 02:25 PM | #2 |
Vault Dweller
704
Rep 577
had this happen once on AWD 335 (F30) when I tried to let it roll down the driveway. It went away after a while, so I assumed it is the car thinking something got messed up based on sensor readings. Maybe something similar in your case!
AndroidRobot4331.50 |
11-11-2021, 04:27 PM | #3 | |
Rep 991
So You went to dealer, refused to leave the car BUT didn’t ask them at least to Scan it while you was there. I’m confused |
AndroidRobot4331.50 'Cane8516.00 |
11-11-2021, 04:38 PM | #4 |
Rep 192
You should leave the car with the dealership to get checked.
Never had this experience before. |
AndroidRobot4331.50 mattburks750.50 |
11-11-2021, 04:56 PM | #5 | ||
Rep 6,121
11-11-2021, 09:55 PM | #6 |
Rep 1,075
Do you have RaceChip installed or messed with any of the sensors? I had this happen when I removed the RaceChip head unit and drove the car.
11-11-2021, 10:11 PM | #7 |
Rep 585
I’ve seen this happen on plenty of BMW’s. Drivetrain malfunction and it feels like your car has absolutely no power. Most times you can turn the car off and back on and it goes away. Even though it’s most likely nothing I would still make an appointment with your service center or you could wait to see if it ever happens again and if it does then take it in.
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
11-12-2021, 07:28 AM | #8 | ||
Rep 6,121
11-12-2021, 07:58 AM | #9 |
Rep 717
Drives: BMW M3 xDrive
This happened to me on my G80 xDrive. The way it turned on was by me turning the car on then off then turning it back on rlly quickly bcuz I was trying to show some buddies how it sounded with the valves open on start up. Then I got that warning but then I pulled into a parking lot. Got out, locked the car walked a little ways away. Then waited 3 minutes then I got back in and it was gone.
11-12-2021, 07:59 AM | #10 | |
Rep 6,121
11-12-2021, 08:00 AM | #11 | ||||
Rep 717
11-12-2021, 08:06 AM | #12 | |||||
Rep 6,121
06-07-2023, 07:02 PM | #13 |
Rep 27
Hi, thank you for the post. I encountered the same issue. It happened to me twice the end of last year and the beginning of this year. I shut it down and restart the error message just disappeared. It did not come back after I switch from Costco gas to shell. Yesterday I drop off my vehicle for service and mentioned the issue. The service guy told me that they found an error message (from OBD, not showing in the infotainment). they tried to figure it out by contacting BMW USA. They want to keep my car for one more day to wait for response.
06-07-2023, 07:59 PM | #14 |
Rep 14,115
Drives: G82 M4C X-Drive
I highly recommend bimmerlink and a OBD cable. Just a good investment for piece of mind when the dealer makes things difficult.
03-18-2024, 01:44 PM | #15 | |
Rep 264
03-18-2024, 02:39 PM | #16 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Good ole limp mode. Hopefully you get it sorted.
