12-17-2021, 06:03 PM | #68 |
Rep 2,373
I ordered 15, 13 and 10 spacers. I just found out I have Michelin tires and I also ordered AST springs. Can't wait to see the outcome. I understand if you lower car with Michelin tires and 12 spacers, you will get a slight rub.
Formerly Wyndi335I
12-18-2021, 10:59 PM | #69 | |
Rep 341
I know turner sells 7.5mm spacers for the F8x, need to check if they have updated ones. For a subtle look at stock height, 10/7.5 or 7.5/5 might be a good setup. |
12-19-2021, 08:40 AM | #70 |
Rep 897
If you find 7.5/8mm ones that have the lip (hubcentric) pls post it here. I've looked and havent been able to find.
01-01-2022, 12:25 PM | #71 |
Rep 279
Drives: G80 M3 Comp xDrive
Forgive my noobness as I've never really messed with wheels but am loving what I'm seeing the photos - what are the benefits of wheel spacers other than the apparent stance upgrade? Are there any notable cons?
01-09-2022, 06:03 AM | #72 | |
Rep 597
The cons are noted quite extensively in this thread. The most obvious con is that your tires can rub against the fender lining and/or wheel well which is not only audible from the cabin, but can cause unnecessary and unsafe tire degradation. You can resolve these issues by reshaping (using heat) or cutting into the fender lining, but this is not recommended. Aside from that, if not installed properly with a lubricant, the spacers might adhere to the hub resulting in a more difficult and delicate disassembly. All of these scenarios are easily avoidable if you do your homework and stay within the recommended spacer sizes identified herein. I received the Pirellis from factory but will eventually switch to the Michelins. I have done a ton of research on this topic and listed my preferred setup below for convenience. Both setups should result in no rubbing issues or the need for cutting/heating the fender linings. Pirellis (with KW HAS) 10mm front 12mm rear Michelins (with KW HAS) 15mm front 13mm rear Last edited by spicoli024; 01-09-2022 at 06:08 AM.. |
02-14-2022, 07:47 AM | #73 |
Rep 59
Sorry for duplicating my question from another thread. My upcoming Marina Bay Blue M3 Xdrive will be my daily driver including wet and snowy roads, it will never be tracked though. I don‘t plan to lower it but would love to add some conservative spacers to the Front axle only while maintaining steering feel and driving dynamics close to oem. Has anyone tried front only 5mm spacers with stock height on the M3? Future Classic seem to have a quality product. (I‘ve used H&R spacers for years with no issues on many sport cars).
02-14-2022, 08:18 AM | #74 | |
Rep 597
2021 ///M3 Competition
2018 BMW M3 Competition | 2009 BMW E60 M5 | 2008 Audi B7 RS4 | 2006 BMW E46 M3 ZCP | 2003 BMW M3 CP |
02-14-2022, 09:40 AM | #75 | |
Rep 59
02-19-2022, 02:17 PM | #76 | |
Rep 59
Which brand of spacers are you using? Thanks! |
03-09-2022, 02:50 AM | #78 |
Rep 817
Just installed Future Classic Spacers on Michelin. F15/R12 and zero rubbing. Thanks for all the advice here, it is my first experience with spacers.
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange SOLD - G01 X3 White SOLD - E93 Burgundy |
03-11-2022, 02:20 AM | #80 |
Rep 542
03-11-2022, 09:21 AM | #82 |
Rep 10,168
I have tried them and there are NO issues... the only problem was my shop had a set of used ones so I need new ones.
No rubbing at all.
03-11-2022, 09:34 AM | #83 |
Rep 991
03-13-2022, 07:59 AM | #84 |
Rep 597
Did you have to cut into or mold the front fender linings?
03-13-2022, 10:47 AM | #85 |
Rep 10,168
No because I have the PS4's; you most certainly will with the Pirellis.
03-13-2022, 01:05 PM | #86 |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Ok, I have a couple DIY spacer install questions. My M4 arrived last Fri, but bc of snow I couldn't pick up until tomorrow. My CA txt me pics however, and I hit the tire lottery with PS4, so I'll be going with FC 15f/12r.
Now I swap out my summer/winters seasonally myself on all my cars, so I'm somewhat knowledgeable enough to think I can install these spacers myself. I just have few quick questions from watching various IND videos. -I've noticed some of IND videos show applying anti-seize to the hub screws and some videos that don't apply the anti-seize, so yea or nay? I don't plan on removing the spacers frequently as I do with my seasonally wheel changes. -Watching the videos, obviously you would apply anti-seize to the original hub before installing the spacer, but why isn't anti-seize then applied to the spacer hub before mounting the tire as one would do without a spacer? Am I missing something here? -And do you guys just use hand pressure to mount flush the spacer to the hub, or I have seen others use a rubber mallet to knock flush? Thanks
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
04-19-2022, 06:33 AM | #87 | |
Rep 817
I used anti-seize on the hub screws. Only used hand pressure as the fit was perfect. Love the look after fitting these.
Kief4440.00 |
04-24-2022, 03:36 PM | #88 |
Rep 655
well having had 963Ms + michelin all seasons on until today, i put my 826M + pzeros (what came with the car) and with 12mm future classic spacers on all wheels, 100% rubbing on the front when turning the wheels 100%, like backing out of a parking space, etc. No rubbing with the all seasons setup. About to swap the all seasons for cup2s for track season on the 963Ms, hopefully they don't rub.
