08-20-2023, 04:32 PM | #45 | |
Rep 1,334
The 3rd setting is OEM, yes. |
kgelfen3602271.00 |
08-20-2023, 06:47 PM | #46 | |
Rep 2,712
I found this thread as well, but it still doesn't make it completely clear. It looks like both cables are routed through that one grommet, is one of the cables then routed in that heat shielding to the other side? |
08-21-2023, 01:17 AM | #47 |
Rep 710
The grommet that I used is inside the battery compartment on the driver side.
You will need to remove about 10 screws and 2 plastic nuts holding the metal and plastic covers next to the rear driver's wheel. Once you move that out of the way. You will see the grommet from the outside. The hard part is removing the aluminum sheet and plastic cover. I routed the SST cables following the original valve controller cables.
Bostro532.50 anthony412159.00 |
08-21-2023, 11:11 AM | #48 | |
Rep 191,249
docjavier1111.00 |
08-23-2023, 09:09 AM | #49 |
Rep 191,249
50 controllers on the way to our Las Vegas warehouse
08-23-2023, 09:25 AM | #50 |
Rep 2,712
Is this the correct product?
I'm definitely looking forward to your writeup, still a bit confused on which panels I should be removing for access to the grommet and then how to route it to the other side. |
08-23-2023, 12:15 PM | #51 |
Rep 13
08-23-2023, 12:29 PM | #52 | |
Rep 1,334
I ordered a couple identical extra remotes from Amazon for like $10, they are easily programmed using the original and I just have them as backups. |
Sleepy_M3C4.50 forcefed2580.00 |
08-23-2023, 12:41 PM | #53 |
Rep 13
08-23-2023, 12:42 PM | #54 |
Rep 1,334
Sleepy_M3C4.50 |
08-23-2023, 12:49 PM | #55 |
Rep 191,249
08-23-2023, 12:57 PM | #56 |
Rep 710
I ordered 2, not that expensive. Better save than sorry.
08-24-2023, 10:39 AM | #57 |
Rep 191,249
Cant disagree with that
08-24-2023, 06:39 PM | #58 |
Rep 75
Drives: 22 G80 M3, 19 488 Pista
Just got mine today and installed it. Works great. Instruction says the controller unit is waterproof so I mounted it outside with 3M tape.
08-25-2023, 11:03 AM | #61 | ||
Rep 191,249
Dm sent
08-25-2023, 01:13 PM | #63 |
Rep 84
Installed today in under thirty minutes. Was super easy. 3M’d the box behind the black plastic (as shown in many YouTube videos) where it will be out of the elements. Sounds amazing!
PeteTheMailman141.50 |
08-26-2023, 10:23 AM | #64 |
Rep 191,249
dm sent
08-26-2023, 11:15 AM | #65 |
Rep 17
08-26-2023, 12:30 PM | #66 |
Rep 2,712
