06-23-2022, 05:30 PM | #1 |
Rep 10,878
IND | AutoTecknic G8X M3 / M4 Dry Carbon Podium V1 Front Grille
Luxury, performance, and style; what more could you want for your BMW? Stand a head above the rest with the full replacement AutoTecknic Podium V1 G8X M3/ M4 Front Grille in Dry Carbon Fiber. This grille will make all the difference to your BMW. In a striking twill weave carbon fiber, this front grille will transform the exterior of your ride. Your G8X is already a game-changer, so why not amp it up as much as possible? Make even more of a statement when you pull up equipped with high-quality parts from AutoTecknic. The AutoTecknic Dry Carbon Podium V1 Front Grille is equipped with unibody carbon mounting tabs on the grille to ensure you a secure installation not seen by other manufacturers. Dry carbon is the highest-quality version of carbon fiber products that are produced. Dry carbon fiber's name comes from its manufacturing process. Dry carbon fiber is formed by using a "pre-preg" or impregnated piece of carbon materials. This piece of carbon is first placed into a mold and then into a sealed vacuum (autoclave) to cure appropriately. This method creates the least amount of waste and forms a lighter version of carbon than the "wet" method. The autoclave vacuuming process of making dry carbon means fewer pinholes and virtually no air pockets in the carbon. Product Details:
The AutoTecknic G8X M3 / M4 Dry Carbon Podium V1 Front Grille may be viewed at the following link to our online store: https://ind-distribution.com/product...1-front-grille Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
06-24-2022, 07:09 PM | #2 |
Sith Lord
3452
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
Can the bottom right part of the grill not be modified / cut to fit the ACC sensor? I like this grill a lot more than the one that has the bottom parts open. Is this a modification that A&L could possibly do?
Always two there are.
06-29-2022, 02:55 PM | #3 |
Rep 374
07-27-2022, 05:34 PM | #4 |
Rep 10,878
AutoTecknic also has their Motorsport V1 Grille Set inspired by the M4 GT3 which is compatible with ACC and doesn't have the bottom bars.
