01-12-2022, 11:27 AM | #1 |
Rep 241
F80 acceleration noise
Question for you guys. I have a 2018 f80 and for some reason while I'm driving i get this whine noise from the inside of the car. It kinda sounds like when you put a music system in your car and you get that feedback noise. Has anyone else had this problem. Only when I step on the gas tho. Thanks in advance
01-12-2022, 01:18 PM | #3 | |
Rep 696
Drives: 2015 f80 M3
Is the sound system on or off? Does it go away when you are coasting or holding speed? Does it correlate to RPM or road speed? DCT or manual? It could be a few things really. But these cars make all sorts of noises so maybe if you can help us drill down with some more info we can help ya get close or send you in the right direction. josh |
01-12-2022, 01:25 PM | #4 | ||
Rep 241
Hey
01-12-2022, 03:08 PM | #5 | |
Rep 696
Drives: 2015 f80 M3
Hmm. That is odd. As when you are shifting I would think any driveline whine would go numb as you let off the gas and the gears have less force on them. Does it come from one spot or direction? Like behind you or right next you or in front of you? I am sure others will chime in soon. josh |
01-12-2022, 03:15 PM | #6 | ||
Rep 241
Hey
01-12-2022, 03:49 PM | #7 |
Rep 138
Do you have anything plugged into the aux. input on the car? I only bring this up because I used to get a whine in my VW golf. I found out this was noise from my phone plugged in and charging. The charger was a cheap one that resulted in feedback through the output jack. When I got a better charger this went away. It's a stretch I know but worth asking.
01-12-2022, 03:52 PM | #8 | |
Rep 241
Hey
01-12-2022, 04:05 PM | #9 |
Rep 6,733
If you want to isolate audio (ground loop) you can try unplugging the amps (audio and active) and see if the hum goes away.
Could be driveline noise from axle/ rear diff. You can search as I believe this has been discussed prior. A lot of rabbit holes you can go down though lol. |
spidy512502.00 |
06-13-2022, 03:14 PM | #11 | ||
Rep 47
IG: jmw_m2
07-25-2023, 10:24 AM | #13 |
Rep 78
Is this happening at freeway speeds? At 70mph under light/med acceleration I can also hear what sounds like speaker whine coming from the rear.
My guess is that it's a loose ground somewhere in the speaker system. Haven't yet had a chance to dig in. |
05-03-2024, 03:58 PM | #18 |
Rep 290
I just hit 40k miles in my 2019 DCT - I don't have this noise
in a previous car, it was Alternator Whine - which when I turned up the sound, you couldn't hear it so every time I drove my FIL somewhere, he would say - Man that is annoying - how do you stand it?? I would reply - it only happens when you are in the car..... because the sound level was sooooo low
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition 2015 BSM M4 Convertible - 2018-2019 2016 228Xi - 2017-2018 2003 Acura RSX Type S 2003-2017 |
