      09-02-2023, 05:55 PM   #45
Mrrcman
Mrrcman's Avatar
85
Drives: X5
Originally Posted by Aalfred View Post
Thank you. I'll keep looking at the classifieds soon. That is a good deal for ur RD with mirror tap. GLWS
This is what I will be selling
AFE air intake
Visconti flex fuel with gauge
Mad down pipes catless
Bootmod3 transfer license with BM3 Wi-Fi adapter
Aalfred2607.00
      09-03-2023, 02:38 PM   #46
ItsConnor
ItsConnor's Avatar
Drives: 2024 PB M4 Comp xDrive
Checked out his pic and that’s definitely a clean setup. It could make the R8 arrows pointless (don’t know the view from drivers seat or if you care about that).
Adding quick pics of the blendmount incase you’re still wanting. From the pic you can see it would be in your view a lot more than the permanent method but I still don’t ever notice it when driving, only occasionally in a parking lot when I’m looking 2 o clock
Aalfred2607.00
      09-03-2023, 02:50 PM   #47
Aalfred
Drives: 2023 M3CX, 2018 X3 M40i
Thanks. It does looks pretty clean and sleek. I'll try the permanent one and if not happy will get the Blendmount. They look great.
ItsConnor232.00
      09-03-2023, 04:08 PM   #48
modat
Drives: 2022 IOMG M3 Xdrive
Uniden r8 paired with the new r8 companion app has made this the best detector ever. Amazing range and super quiet
Aalfred2607.00
      09-03-2023, 04:17 PM   #49
Aalfred
I was going with the R7 and once I found out about the R8companion app for iphone, made me go with the R8 !!! Cant wait to install mine soon.
      09-03-2023, 04:59 PM   #50
Berzerker
You can try mount it comes with, the one with the 2 smaller suction cups. I find it actually works quite well. I did end up installing the blendmount anyway.
Aalfred2607.00
ItsConnor232.00
      09-03-2023, 05:42 PM   #51
Aalfred
Does it have any issues in colder climates? I read a thread of someone whose RD fell off due to the suction mount and he lost power in his mirror as the mirror tap wire got yanked and had to take it to the dealer to have it repaired.
      09-10-2023, 10:00 PM   #52
Aalfred
Got my R8 and installed it via mirror tap and permanent mount. Slowly getting to learn all the settings of the R8but so far pretty good at picking up Ka bands !!!
      09-11-2023, 07:41 AM   #53
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Boy that is quite big looking up there....makes me want to stick with V1...
      09-11-2023, 09:46 AM   #54
Aalfred
Lol. It’s true. It’s a bit more wider and taller than the R7.
      09-14-2023, 07:42 PM   #55
Tobstertx3
218
Drives: 2024 BMW M3
Agree, although think the photos make it look bigger than it is.
How was the WireTap install?
      09-14-2023, 08:56 PM   #56
ItsConnor
ItsConnor's Avatar
Wiretap install required taking off plastic trim or mirror, tap with included prongs into mirror plug (I didn’t even take it out but others choose to).
Took ~10 min going slow and there’s a couple other threads on the topic I read first
Aalfred2607.00
      09-15-2023, 10:21 AM   #57
Aalfred
I did take the mirror plug out and it was not easy. I tried to use needle nose pliers and the plastic edges of the mirror plug broke off in many places as it takes a good amount of pressure to remove it. I think the prongs can be inserted only one way which is beneath the wires (if u look at the pic above) but having the right diameter prongs is the key. Plus removing the plug gives u a bit more room to maneuver but I dont know if I will do that again. I was sweating bullets trying to get it out and the plastic tabs kept on breaking
ItsConnor232.00
      09-15-2023, 10:58 AM   #58
ItsConnor
ItsConnor's Avatar
I’d of given up so fast upon breaking any of the plug. Thankful it worked out for you, I used needle nose pliers to hold the prongs and used the 2nd smallest size (kit came w 4) then pushed them in, again using pliers as it’s probably impossible without them.
Aalfred2607.00
