02-23-2023, 02:44 PM | #24 |
Rep 25
I just ordered the adapter for bimmercode because even though I have an exhaust that's a bit louder than stock (Schnitzer back box- can't go full system cuz stupid EU emission and noise regulations), the ASD is so loud that unless I have all 4 windows down I have trouble distinguishing between what's real and what's not. I'll let you guys know if coding it off normally through BimmerCode works
02-23-2023, 02:46 PM | #25 | |
Rep 298
G80 ///M3 XDRIVE
02-23-2023, 03:30 PM | #26 | |
Rep 2,303
2001 330Ci (sold)
02-24-2023, 06:38 AM | #27 |
Rep 25
02-24-2023, 06:40 AM | #28 |
Rep 25
Yeah I find it so weird that we don't have an option to turn off ASD (without closing the valves that is). I don't mind it being 'less loud' as long as I can hear real sound and not having to doubt what's real and what's fake
02-26-2023, 05:38 AM | #29 |
Rep 140
Thank you for posting this. It worked. It is odd that you need to take this extra step, ie that just toggling it off isn’t enough. But now that embarrassing artificiality is finally where it belongs: gone!
Current: 13 X5 Diesel, 991 Carrera S 50th Anniversary Edition Gone: 11 E90 M3 ZCP, 07 328i ZSP, 05 330i ZHP, 04 996 GT3, 02 525iA, 02 996 C2, 01 Boxster S |
jimbethesda1856.00 TENPIN330.50 |
02-27-2023, 05:48 AM | #30 |
Rep 25
jimbethesda1856.00 |
02-27-2023, 07:16 AM | #31 |
Rep 941
This works for idrive 8 as well?
02-27-2023, 02:37 PM | #32 |
Rep 140
Exactly my impression as well. Just what I was looking for.
Olddirtytshirt26.50 |
03-01-2023, 03:22 PM | #33 |
Rep 298
Finally had to chance to try and code it with the instructions given by jimbethesda -thank you. I did notice it did something and hear less of the fake speaker noise. I can’t tell if it’s still there or my car sounds louder because of the catless downpipes!
G80 ///M3 XDRIVE
03-02-2023, 06:00 PM | #34 |
Rep 156
Drives: 2023 M3 Comp. x Dravit/Fiona
Yes. I did it a couple of weeks ago and would not go back.
The ASD downshift noise was driving me nuts.
Now: 2023 M3 CX Dravit Grey/Fiona Red-Black
Past: 2021 X3MC Donington/Black-Beige Past: 2016 M4 Silverstone II/Sakhir Orange (ED) Past: 2012 335is Black Sapphire Metallic/Black |
mirob3039.50 |
03-02-2023, 06:22 PM | #35 |
Rep 941
03-04-2023, 04:03 PM | #37 | |
Rep 47
https://g80.bimmerpost.com/forums/at...1&d=1677081138 And you don't hear in sport mode the fake/amplified sound anymore ? I'm asking because most people who have tried in ID8 said they had to use the expert mode (example: https://g80.bimmerpost.com/forums/sh....php?t=1996298 ) Going to order an adapter to try it too. |
03-04-2023, 04:28 PM | #38 |
Rep 17
I followed the directions in the first link. Now there is no difference in the cabin going from efficient to sport. With my windows down, I can still hear the exhaust flaps open. It definitely worked. Took literally 2 mins.
03-04-2023, 05:55 PM | #39 |
Rep 47
Found my ODB2 Ethernet from my older 435i and used iit with bimmercode.
Tried first the 1st (simple) method as described in p1 to turn ASD off. Went on a test drive, I didn’t hear any difference compared to before the coding. (In both comfort and sport ). Then did the coding in the expert mode (all ASD deactivated individually). Now I can definitely tell the difference. The sound (drone, fake burbles , fake upshift , etc) is no longer enabled in the speaker. Looks like ID8 ASD still requires going in the expert mode, at least in most 2023 M3s. |
vmalho2702.00 sbgolfer222195.50 |
03-04-2023, 06:38 PM | #40 | |
Rep 17
03-04-2023, 07:03 PM | #41 |
Rep 47
Don’t remember the numbers but was the latest one last time I checked. I saw multiple reports of ASD that needed to be turned Off in the expert mode, in ID8 . Not an issue anyway, now at least I’m sure there is no generated sound in the speakers.
07-25-2023, 07:44 AM | #42 |
Rep 90
So I have ID8 and "disabled" ASD via Bimmercode in both options; standard AND expert mode. I have an exhaust valve controller independent of the ECU. If at idle when I push "on" the exhaust button in the center console (not the valve controller) I can faintly still hear the sound change which means to me the sound I'm hearing is fake...
I really don't think Bimmercode 100% turns ASD off. Has anyone else experienced this? |
07-25-2023, 08:08 AM | #43 | |
Rep 1,257
If you have a valve controller set to open and ASD off then the only thing the exhaust button should be doing is turning burbles on and off. |
The_RGNBULL132.00 |
07-26-2023, 09:31 AM | #44 | |
Rep 90
