01-07-2022, 07:05 AM | #45 |
Rep 1,682
I'm trying to code Easy Entry and Brake Force, I don't see these options in the app. On Bimmercode's website it shows Brake Force is supported, but nothing for Easy Entry. Has anyone been able to successfully code these? If so, can you please provide the steps?
01-10-2022, 07:57 AM | #47 |
Rep 739
Does coding affect warranty at all? I've done coding in my X5 because that when I first heard if it. my service center never said anything about it. On the X forum someone made a excel sheet showing everything you can code…. Anything like that for the M models?
01-10-2022, 08:41 AM | #48 | |
Rep 2,135
I've had - RR chime - angel eye brightness - seat belt warning disable for the passenger - brake force - iDrive warning delete - video in motion - welcome light on reverse I guess it all depends on what dealer you work with. Most don't seem to care. |
bimmermann88310.50 RichardGM4527.00 |
01-10-2022, 09:03 AM | #49 |
Rep 482
Which apps do you folks recommend for this sort of coding? I'm new to this discussion, I see references to Bimmercode, Bimmerlink and Carly. I sure don't want to mess up my car system, so I guess I'm a bit cautious. Any advice?
01-11-2022, 09:35 AM | #50 | |
Rep 399
01-11-2022, 07:19 PM | #51 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
Are there any coding options for easy entry where the seat moves back for you to get in?
01-11-2022, 08:47 PM | #52 | |
Rep 1,682
I would like to configure Brake Force, but seems like you can configure part of it, but not the entire thing where the brake lights flash when you press on the brake pedal. |
BIGW0RM3156.00 |
01-11-2022, 09:14 PM | #53 |
Rep 300
01-11-2022, 09:46 PM | #54 | |
You got my money?
3156
Rep 4,646
Didnt the F80 have easy access? And didn't the steering wheel move up too? Or am I confused?
Tdubb88188.50 |
01-12-2022, 02:28 AM | #55 | |
Rep 542
Drives: 2022 G83 M4
You could code in Easy Entry/Exit on the F8X cars but for some reason this was either removed or coding parameters have yet to be figured out for the G8X. Hoping someone comes out with coding sheets/values for Esys like we've had on the prior generations of BMWs
01-16-2022, 08:52 AM | #56 |
Rep 121
I've just enabled the door handle lights to illuminate when reverse is selected on my F31, love it, lights up kerbs at night when parking.
330e, awaiting delvery of G80 M3 comp
01-16-2022, 11:09 AM | #57 |
Rep 2,368
Bimmercode, if so please share
Formerly Wyndi335I
01-17-2022, 03:00 PM | #58 |
Rep 121
Yes using bimmercode following path
- front electronic module - lighting - door handle lights when reverse engaged - enabled.
01-18-2022, 12:52 PM | #59 |
Rep 2,135
01-18-2022, 11:50 PM | #61 | |
Rep 300
01-19-2022, 09:57 PM | #62 |
Rep 957
I'm not seeing this in BimmerCode at all. I don't even see front electronic module much less door handle lights when reverse engaged? What am I missing here?
[/SIGPIC]
01-20-2022, 08:48 AM | #63 |
You got my money?
3156
Rep 4,646
Anyone else run into video in motion repeating its setup when you code? I enabled it once and it appears it took. I then found another coding option I forgot to enable. Went to do so and video in motion setup popped up again. I found that odd.
01-20-2022, 08:52 AM | #64 |
You got my money?
3156
Rep 4,646
The other key has its own profiles doesn't it? Couldnt she just use the other key? That or use profiles with one key? If you have drivers assistance, I think you can set it (the camera in the dash) up to where it uses facial recognition to select the correct profile too.
01-20-2022, 10:21 AM | #65 |
Rep 2,135
01-20-2022, 03:06 PM | #66 | |
Rep 2,163
Thanks. Simple pleasures. |
