03-23-2024, 02:12 PM | #1 |
Rep 188
Orange Engine Coolant Light
Is the orange engine coolant light safe to drive on and red engine coolant light would not be safe to drive on?
03-23-2024, 03:05 PM | #2 |
Rep 989
Engine coolant level is LOW, that’s what it means. You’re losing coolant somehow, either a leak due to a core penetration from a rock or something up front or I/C core leak in the intake system, but those are rare for this platform. When did this happen and why aren’t you just checking the level and topping it off? If you’re not mechanically capable, then take it to the dealer to diagnose and fix before more severe problems happens. I guess I’m having a hard time grasping why you’re asking if it’s OK to drive on a low coolant level warning light? More context please… either stop driving it or top it off monitor the level and if it drops again, you definitely have a leak you need to address.
kgelfen3602271.00 |
03-23-2024, 04:06 PM | #4 |
Rep 65
Drives: BMW M4 Competition
Do you feel sweet smell from engine bay or inside the car? I had 540 on long trip around west coast where I got coolant level low notification, checked both expansion tanks and one of them was below normal level but nothing too crazy, I stopped by nearest store and got coolant, added to the car. Earlier b58’s were known to loose coolant a bit. Now temp gage newer went above normal operating temp, and I continued my trip for another 2k miles after that with no issues. There was no smell or visible leaks, I think it was due to faulty coolant cap.
03-23-2024, 04:44 PM | #7 |
Rep 989
If you’re in a hot climate you could also just throw in some distilled water (MUST BE distilled) and you’ll be fine. You don’t have to be at a perfect 50/50 mix, especially in hot areas of the country.
03-23-2024, 07:21 PM | #8 | |
Rep 65
But to the point I was sharing personal experience when I got coolant low warning without any major issues. From previous b48, 2 b58s, and s58 that I currently own, only one car did it, and it happened to have b58. |
03-25-2024, 08:41 AM | #10 |
1951
Rep 1,910
Drives: E92 M3
Mine needs coolant added every year and I take it into the dealer to do it. They've done two pressure tests so far with no leaks found. I'm told it's working as expected and we should expect to lose coolant over time.
This must be the cool, new thing as engines consuming oil isn't cool anymore.
03-25-2024, 03:36 PM | #11 | |
Rep 188
M4Tejas808.50 |
03-25-2024, 03:44 PM | #12 | |
1951
Rep 1,910
Drives: E92 M3
However, mine never got to the low coolant warning stage as I've caught it early. I had a thermostat fail in first few months and we've had to add coolant once a year since then. I bring it in each time to establish history with the issue because I'm assuming they'll announce a fix for some defect causing this while I'm just out of warranty.
03-25-2024, 10:18 PM | #13 | |
Rep 989
