Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      01-30-2024, 09:05 AM   #133
SoCalDrummer
SoCalDrummer's Avatar
Drives: 2023 M3C, 2020 M4 Heritage (re
Originally Posted by G80indy View Post
Competition?
Yes, ‘23 M3 Competition
      01-30-2024, 09:18 AM   #134
SoCalDrummer
Originally Posted by beamlord View Post
Can you please elaborate as much as possible on the fuel tank breather valve issue, what exactly it was and what they told you, what it would cause?
Also I see they replaces the fuel pump as well?
Very curious about this part.
It regulates pressure inside the tank - symptoms can be a bouncy / rough idle. This was an incidental finding as they ran additional fuel system tests before diagnosing the leaking injectors (see full notes below)
      01-30-2024, 07:08 PM   #135
beamlord
Drives: 2023 m3c
Nice detailed report.
Did you notice improved idle i.e. is it steady as a rock or some slight movement as "usual"?
      01-31-2024, 10:36 AM   #136
SoCalDrummer
It’s definitely a smoother idle than before, with slight movement.
PipeM3196.00
      02-04-2024, 06:52 PM   #137
mdr955
Drives: M4
For those following along can you comment on this thread for me?
https://g20.bimmerpost.com/forums/sh....php?t=2080171
      02-05-2024, 06:51 AM   #138
beamlord
Drives: 2023 m3c
Originally Posted by relubwu View Post
Update 11/17: dealer replicated the issue, speculated fuel problem. Awaiting BMW engineer to check on 11/20.
This is NOT a fuel issue.
It's a leaky injector, have them pull the spark plugs, insist this is 100% correct diagnose with a lot of evidence and use this thread and reports of mine and others.
      02-11-2024, 05:16 PM   #139
mdr955
Drives: M4
Do you know how they check the injectors? Going back Wednesday to push the issue a bit.
      02-13-2024, 06:14 AM   #140
beamlord
Drives: 2023 m3c
I understand they pull the plugs and almost certainly see one or more that are fouled.
How did it go?
      02-13-2024, 07:58 AM   #141
mdr955
Drives: M4
How did it go?
First try they found no codes, said they checked the plugs and all looked fine. Told me to keep the car until the break in and get more videos. I got a video of the slow start / extended crank so going back tomo for the break in and hopefully resolve this….
      02-14-2024, 11:19 AM   #142
mdr955
Drives: M4
beamlord they pulled the spark plugs again and sure enough now 6 was starting to look burnt. Confirmed leaking injector and will replace and button back up tomor!
Really appreciate the folks who posted their work orders as I think my SA was able to fast track things for me.
      02-14-2024, 11:36 AM   #143
Berzerker
#5 isn't looking too good either, glad you got it resolved finally
      02-16-2024, 07:21 AM   #144
beamlord
Drives: 2023 m3c
Glad you pushed through and got it sorted.
My overall dissatisfaction with the fact that so many injectors are defective from factory persists. A decent car manufacturer like we want to hope BMW still is would have at least stored a TSARA case on the subject so that us customers don't have to go through all loops of hell and convince/beg SA to fix this.
      02-16-2024, 08:39 AM   #145
mdr955
Drives: M4
Agree but that’s actually an understatement. Totally bonkers - there must be tons of this on G8x all over … I wonder what the long term damage is if you leave this unattended for 20k miles.
beamlord431.00
      04-03-2024, 03:51 PM   #146
emstan
Switzerland
Drives: '24 Alpina B3S Touring
Wow, thanks God for this thread... Got a very similar issue on a new G21 LCi Alpina B3, thought I was going crazy. So far it happened twice within 500 miles of mileage and haven't been able to reproduce it for a video, but as soon as I manage to do so, I'll start a case with our dealer. There are A TON of M2/M3/M4s around, so I certainly hope they are already familiar with the issue...
EDIT: Got it on the video - https://share.icloud.com/photos/028u...Klx8PakTO-9QlQ
      04-03-2024, 07:58 PM   #147
mdr955
Drives: M4
I took screenshots of the dealer notes listed in this thread and highlighted the info. Video every start ideally from outside with remote start which captures the slow start/ false start much better than from in the car.
      04-05-2024, 10:38 AM   #148
emstan
Switzerland
Got it! https://share.icloud.com/photos/028u...Klx8PakTO-9QlQ
      04-05-2024, 11:51 AM   #149
mdr955
Drives: M4
Yea that’s a bad one lol. None of mine were that long. Make sure they check your plugs. Mine were no bad at 700 miles but by 1100 it was showing signs of being burnt
      04-09-2024, 09:03 AM   #150
zmaknojia20
Drives: 2024 G87 M2
Another +1, I have 135 miles on my G87 and I have this issue. It is a hit or miss. Anyone have any go-to dealerships in Houston?
