07-24-2022, 03:32 PM | #705 | |
Rep 736
Well, last night I was doing some highway driving while going up a pretty good long grade and maintaining 2k RPMs under load. The drone was at its worst. I figured it was a good opportunity to reevaluate ASD and engine settings to confirm my previous experience. It was long enough and steady enough that I was able to toggle ASD and engine modes several times in various patterns. There was definitely a decrease in drone for both as each was toggled on/off. With both ASD off and in Comfort mode I would estimated a 15%-20% decrease in drone (subjective, of course). It was still quite oppressive, but much more tolerable. Am I likely to toggle ASD and/or engine settings to reduce drone... probably not. This was while the engine was under load and I don't get as much reduction under normal cruise conditions when the engine isn't under load. I always drive with everything in Sport mode and I'm most comfortable with those settings. But, now, at least, it's a tool in my toolbox.
chicagofan0019224.00 mysticphonk17.00 |
08-22-2022, 11:09 AM | #707 |
Ing.
358
Rep 134
Anyone has switched from race version to sport ? Or anyone with sport version is experiencing drone noise between 2k to 3k rpm ?
IG : FrozenBimmer
08-25-2022, 05:35 AM | #708 |
Rep 321
I finally had my Remus race exhaust installed yesterday along with the midpipe and front cat delete pipe. It is completely unbearable to drive with drone and vibration. Something has to be wrong with this design from the factory or mine was installed improperly. The drone is deafening and the back window of the car vibrates so badly. Exhaust valves sound fine, the car from the exterior sounds somewhat fine, but the interior is unbearable. Any suggestions to fix this drone before I take the exhaust off the car?
I have videos available from the interior if anyone wants to listen.
2022 G80 M3c xDrive
2018 F80 M3 ZCP 2016 F30 340i xDrive |
08-25-2022, 09:35 AM | #709 | |
Rep 191,093
i recommend you put the stock cats back.
08-25-2022, 09:37 AM | #710 | ||
Rep 321
2022 G80 M3c xDrive
08-25-2022, 09:39 AM | #711 |
Rep 191,093
Stock downpipes?
08-25-2022, 09:48 AM | #712 |
Rep 321
Correct. Part of me thinks there's an installation error.
2022 G80 M3c xDrive
08-25-2022, 09:57 AM | #713 | |
Rep 374
08-25-2022, 10:05 AM | #714 | ||
Rep 321
2022 G80 M3c xDrive
santox357.50 |
08-25-2022, 11:40 PM | #715 | |
Rep 191,093
if you are going to remove the resonators and secondary cats, you should keep the downpipes stock
08-27-2022, 02:02 PM | #716 |
Ing.
358
Rep 134
Please help me with a feedback regarding the sport version.
IG : FrozenBimmer
11-03-2022, 01:37 PM | #717 |
Ing.
358
Rep 134
"Thank you" for feedbacks ) . I bought the sport version and the differences is night and day . The car is driveable and without rattles and vibrations inside. And still loud , yet ! With the valves open , you still get little drone , but with valves closed the drone noise is reduced by 90% .
IG : FrozenBimmer
11-03-2022, 03:22 PM | #719 |
Rep 321
No. full remus system
2022 G80 M3c xDrive
11-04-2022, 08:29 AM | #720 |
Rep 426
I had a single midpipe with the remus and it was also ear shredding at 2000-2500 rpm. But I have seen others delete their secondaries, much like your setup and have not reported significant drone.
I am sure iviegatron has this setup, if i am not mistaken. |
RACE M3548.50 |
11-06-2022, 05:47 PM | #721 | |
Rep 1,682
I highly recommend disabling ASD if you haven't with any aftermarket exhaust setup. It makes a huge difference. |
madmedman276.50 |
11-07-2022, 08:17 AM | #722 | |
Rep 191,093
11-07-2022, 07:22 PM | #723 |
Rep 57
just a note here with drone...the remus has no cross overs whatsoever (no X or no H) aaaaaaaannnndd no resonator where the 2 sound waves from the turbos first meet (the resonator closest to the driver on the car). seems like its just 2 straight pipes from the cats and out the back (with valves wide open of course). Thinking that this is a drone recipe.
RACE M3548.50 |
11-07-2022, 09:34 PM | #724 | |
Rep 736
11-11-2022, 11:13 AM | #725 | ||
Rep 1,682
11-12-2022, 12:05 AM | #726 |
Rep 191,093
