06-14-2022, 03:40 PM | #662 | |
Rep 1,682
Did they install the spring correctly? When installing you need to have the valves open so it can line up properly. |
06-14-2022, 04:31 PM | #663 | ||
Rep 354
06-14-2022, 08:18 PM | #664 | |
Rep 374
06-14-2022, 08:20 PM | #665 |
Rep 374
I guess I didn't know what angle/angle meant before I said yes (didn't want to wait any longer)... so put preference aside, what it is designed for or meant for - logo centered or logo tilted?
06-14-2022, 10:43 PM | #667 |
Rep 453
06-15-2022, 09:59 AM | #668 | |
Rep 190,807
06-17-2022, 06:17 PM | #669 |
Rep 453
So today was install day for the AA catted X-pipe and Remus race axle back … O M G. I was expecting to love it - but the actual results are all that and then some!
Deeper than a twin-turbo 3L 6 has ANY right to sound. Loud, but in comfort mode it’s not obnoxious (after cold start settles down - which, in any mode, is rather epic, even outside in an open parking lot). In a garage, cold start shakes the building. And even blipping revs to 1,500 shakes everything. In a fantastic way. Everyone who heard it today was blown away. Videos don’t even CLOSE to do this system justice. Epic. Thank you for the above-and-beyond customer service and the fantastic deal, Mike!!!! |
06-17-2022, 11:52 PM | #670 | |
Rep 381
Drives: 2022 G82 Xdrive
can you post a picture of your angled carbon tip installed on your vehicle? I have the same installed by my mechanic but somehow doesn't quite look right as it seemed tips are out further than what they should be. I may be wrong but wanted to see how others have their tip installed. thanks in advance. |
06-18-2022, 12:04 AM | #671 | |
Rep 453
TillyM158.00 |
06-18-2022, 11:00 AM | #672 | |
Rep 190,807
HorsePower434.50 |
06-18-2022, 09:26 PM | #673 |
Rep 381
I think I'm running into the same issue.
found out after installing VSC-2, that neither open nor close is not working at all. You mentioned spring needs to be put in while the valve is open, but how do you keep the valve open manually? please advise. thank you. |
06-18-2022, 09:31 PM | #674 | |
Rep 1,682
You'll have to start the car up and make sure everything is in sports+ mode to align the valve controller with the springs. |
06-18-2022, 09:40 PM | #675 |
Rep 381
thanks but I have to do this while car is running ? or can this be done while engine off ?
06-19-2022, 01:43 AM | #676 |
Rep 1,682
You can try to do it with the engine off and see if the valve controller turns when in sports+ mode. If not then start up the car and then do it. I did it while the car was running.
06-19-2022, 01:28 PM | #677 |
Rep 453
So one quick minor negative. From about 2,000 to 2,300 or so under load, DRONE. And it’s NOT subtle. With windows down, it makes you shift quickly.
In my 6MT, on the highway, you can easily adjust speed (and/or gear) to get away from it. So far, with about 100 miles since install, I can still live with it and it’s not cutting into my grin |
06-20-2022, 12:02 AM | #678 | |
Rep 381
The whole afternoon inspecting what the issue was and found out that on the left side, the spring was not installed correctly on the left side. I got it reinstalled, and now I can see how loud this is.. I LOVE IT However, I did not stop there and went on to install VCS-2, but when I started the car, CEL came on and said that the drivetrain malfunctioned. I got terrified and took it right off. CEL stayed on, but no issue was found on the Idrive. said everything was ok. now in trying to figure out how to delete CEL light. very disturbing keke. |
06-21-2022, 11:24 AM | #679 | |
Rep 501
06-21-2022, 11:43 AM | #680 | |
Rep 453
At least it saves money on doing audio mods (which would now be rather pointless!) Definitely happy I did the catted X. Pretty much no rasp, and very, very deep tone. Surprisingly so. |
Froz3n_M399.50 |
06-22-2022, 12:10 PM | #681 | |
Rep 1,160
Do you have any video clips of your set up you can post? |
