11-23-2022, 11:54 AM | #1 |
Rep 5,011
..::PSI::.. - PSI Stainless Brake Lines (Official Product Release)
When we picked up our G80, one of the main aspects we felt needed work was the brake feel. The standard OEM lines tend to expand under hard driving and ultimately leave you with a weaker brake feel. With the increase in pedal feel and no ability to expand, the PSI stainless brake lines give the confidence to push your G8x M3 or M4 on the track or the road. Our lines are built with the highest of quality 303/304 stainless, meshed with hard drawn tensile stainless steel braided hoses which is all manufactured by the leaders of the industry HEL . These lines incorporate swivel fittings for ease of installation and stainless construction for the best quality materials where it matters most. "HEL Brake line kits eliminate that 'spongy' feeling often found with rubber hoses under extreme braking conditions - the time when performance is needed the most. By replacing the original rubber hoses with our complete system you will remove this sponginess and your braking will deliver new levels of precision. Don't risk using inferior brake lines when you can trust us to improve braking reliability and performance - We use stainless steel in our lines and our fittings. Most competitors use zinc plated fittings which are at risk from corrosion." There is a special Black Friday sale for this release that is $75 off this kit! Click the link here to check it out https://precision-sport.com/products...39912064679999!
Tags |
black friday, brake line upgrade, brake lines, g80, g80 brake lines, g82, g82 brake lines, precision sport industries, psi, stainless brake lines |
