12-23-2023, 07:03 PM | #24 | |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
Forzanerazzurri6918.00 Needsdecaf6606.00 |
12-23-2023, 07:13 PM | #25 |
Rep 17
Thank you. Thats all I wanted to know. Something must have been off on the one I was driving. Also - a couple times when accelerating and letting off gas a little the car shook back and forth pretty violently. The salesman said it was because I wasn’t smooth on the throttle. Does that sound right??
12-23-2023, 07:29 PM | #26 |
Rep 5,383
12-23-2023, 07:45 PM | #28 |
Rep 17
So DTC off
Will allow wheel spin and DSC on Will Stop car from sliding sideways correct? What about DTC on and DSC off - is that even possible. Not sure how u could have wheel slip with DTC on. |
12-23-2023, 08:07 PM | #29 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Not trying to be too judgemental here but I am getting the impression you aren't ready for this car. If you are that insistent why not Google a manual for this car download it and read it. It'll have all your answers there including all the modes and what the safety features do.
GolfCoyote580.00 Mike02z1979.00 BackOnBlack714.00 Delmoney335914.50 VR1638.00 jmg18710.50 samuraifuria50.50 |
12-23-2023, 08:28 PM | #30 |
Rep 1,279
Drives: 2024 BMW M4 Base
Owners manuals. Everything you need to know is here…
https://ownersmanuals2.com/d/95326 https://ownersmanuals2.com/d/94004 |
GolfCoyote580.00 HideOnCat15.00 |
12-23-2023, 09:16 PM | #31 | |
Rep 17
12-23-2023, 09:59 PM | #32 |
Rep 862
M mode, turn off or turn down the TC. If someone had turned that all the way up it'll really cause the car to bog off the line.
2023 i4 eDrive40
2022 Acura MDX |
12-23-2023, 10:08 PM | #33 |
Rep 1,683
Peak torque comes only at 2.7k rpm, so yeah, it feels sluggish below that, but man, the way it pulls up to redline is another world.
Try this from a dig: left foot on brake pedal, push the throttle pedal hard and when rpm goes at 3k lift your left foot and hang on for dear life
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
12-24-2023, 08:39 AM | #35 |
Rep 17
Thanks. Are there levels??? I thought it was on off. I agree if it was at a ‘max’ setting that would def kill power off line. I’d like the option to put it at about 50% to have fun but also be safe.
12-24-2023, 09:47 AM | #36 |
Rep 5,383
There are only differing levels of TC if it has the M Drive Pro package.
12-24-2023, 11:14 AM | #37 |
Rep 6,701
12-24-2023, 11:52 AM | #38 |
Rep 439
I saw a dyno test that was run in sport+ and efficient and the efficient mode produced more horsepower. Interestingly, I always felt my M4 Comp X pulled harder when I was in efficient although throttle response was snappier in sport+.
12-24-2023, 12:22 PM | #39 |
Rep 857
They really all should come with that granular level of TC in all honesty. Setting the level to a level of slip the driver is comfortable with is much better than the predetermined levels they have on the base TC in any of the drive modes. There are times someone might want to run in a higher mode but dial up TC to near max and the different drive modes don’t allow for this. It’s a stupid way to make $900 on something that’s already there software wise, just not unlocked.
12-24-2023, 01:33 PM | #41 |
Rep 2,606
This is actually a thing. If your foot position isn't correct, in D3/S3, the more "jerky" shifts can case your foot to not move correctly in relation to the car shifting, causing you to go back and forth on the throttle, which then causes more jerky accelerations and decelerations.
I remember this happening to me in the early days of sport car driving, you learn to adjust your foot pressure though, but it is definitely a thing for those who aren't used to this kind of power. |
12-24-2023, 04:29 PM | #42 | |
Rep 265
2023 M3 Competition xDrive Edition 50 Jahre (Techno Violet Metallic) August 11, 2022 Production Date
Delivery Date - October 24, 2022 2021 M340i xDrive M Performance Edition 2017 340i xDrive |
12-24-2023, 08:56 PM | #44 |
Rep 687
Lots of good comments from some. The M3/4 is going to have more turbo lag unless you use the launch control.
But you can do better as a driver and not treat the throttle like an on/off switch. The CA was not wrong. You need to roll into it and feel the car pull. When you just open the throttle all the way befor there is any air moving it creates more lag. When you feed the engine the correct amount of air for the rpm and boost it rewards you. To chime in on the twin scroll information. There were a couple correct posts. It’s a split housing to separate the exhaust pulses blowing the fan. But for that split housing to really work 100% the header leading to the turbo should have equal length runners on all cylinders. I’m not convinced all manufacturers do this. I had to buy custom $4k headers to run a GT35R twin scroll on my 930. Twin turbos are easier to accomplish what a twin scroll can do with a perfect header. |
