12-22-2023, 09:49 PM | #1 |
Rep 17
Disappointed in M3 Comp?!
A couple weeks ago I drove a M340i. It was fun. Put it in sport mode and even with traction control on it was spin the tires and torque was great off the line. No noticeable turbo lag. Today drove a 2021 M3 comp. Both autos. Going from 20mph and up the car was crazy. From a stop it just wasn’t there. Severe lag up to about 10mph. I put it in M mode. Was it possible there was another setting I needed to put it in? The torque from stand still was much less than the m340 I and a 2017 911. All auto. The M3 is the most powerful but least aggressive off the line. The 340i and 911 both had a physical sport button. I assumed the M button on the m3 was the same. Does the g80 have a sport option to keep the turbos spinning at idle (like a waste gate valve or something). Wanted to love the car but I need some push agains the seat feeling from a dead stop. Thanks.
12-22-2023, 10:25 PM | #2 |
Rep 1,393
In addition to the properly set-up M mode, you also need to put the car in 'Sport' mode out of the 3 drive settings. I can assure you if you thought m340 was fun, the M3 Comp will not feel how you describe.
12-22-2023, 10:32 PM | #3 |
Rep 1,922
Drives: 2021 G80 M3
Yeah, M mode doesn't really mean M mode. It just changes the cluster gauge set up and the lane change assist intervention. You have to push the set up button to change to sport/sport+ on the engine, dampers, and the transmission.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
'Cane8517.50 |
12-22-2023, 10:47 PM | #4 |
Rep 5,380
Go back and drive it again, press the M2 button twice and see what the difference is.
Autoaddict302.00 showmatic152.50 |
12-22-2023, 10:56 PM | #5 |
Rep 1,052
It's a low compression motor with big turbos, there's only so much you can do before they spool. Also traction control on the RWD models is fairly aggressive off rip.
12-22-2023, 11:14 PM | #6 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Ya you didn't have it in the right setting. A comp xdrive in sport+ in launch control will make the blood rush out of your head. An m340i isn't comparable at all.
12-22-2023, 11:55 PM | #7 |
Rep 5,380
Forzanerazzurri6918.00 |
12-23-2023, 12:27 AM | #9 |
Rep 2,370
Buy a Hell Cat... you are looking at the wrong car. I have a RWD m3 and never had anyone ride with me and say it's not fast enough.
Formerly Wyndi335I
12-23-2023, 12:38 AM | #10 | |
Rep 208
forcefed2567.00 Needsdecaf6603.00 |
12-23-2023, 06:02 AM | #11 |
Rep 439
You cannot drive a turbocharged car the same way you would a normal aspirated engine car. Turbocharged engines generally have lower compression ratios so that more boost pressure can be run. Generally the higher the boost pressure being run the lower the compression ratio. That makes the lower compression turbocharged car even lazier from a dead stop (or at low RPMs) until the turbos spool up and start producing boost. One way to run a higher compression ratio with a turbocharger is to run higher octane fuels such as racing fuel. But that has it's costs.
That is why the M cars have launch control which loads the engine up against the torque converter so the turbos are producing boost and the engine is in the torque producing RPM range the instant the brakes are released. Another side disadvantage of lower compression is less engine braking when downshifting. There are always compromises. The correct setup depends on what your priorities are. |
Skyscraper2202.00 eugenebmw1482.00 |
12-23-2023, 07:27 AM | #13 |
Rep 1,064
The nature of the B58 turbo is that it is a twin-scroll. This means it has TWO fans. A small one, that spools up quickly giving you low RPM power, and a big one, that spools up more slowly, giving you power at high RPMs. Both fans feed all 6 cylinders.
The S58 has two single-scroll turbos. They are both large fans that spin up slowly, so there is less boost at low RPMs, but a lot of boost at high RPMs. Also, each turbo feeds 3 cylinders, so there is more boost all around. The S63 and S68 have two twin-scroll turbos... that's why the M5 and M8 are so good at low RPMs... |
12-23-2023, 08:42 AM | #14 | |
Rep 1,279
Drives: 2024 BMW M4 Base
If you have a Hellcat the fun part is roll racing like me and my son did back in 2018 my son won the below race as I missed 5th https://youtu.be/YABHt3Ke2yk?si=kOjk5x_nl_72yXwM |
12-23-2023, 09:18 AM | #15 |
Rep 5,155
Once you know what to set…then you’ll know.
His rank is 0 guys…don’t beat him up toooo much.
12-23-2023, 10:02 AM | #16 |
Rep 467
Mike02z1979.00 kgelfen3602217.00 |
12-23-2023, 10:22 AM | #18 |
Rep 989
Drives: 2024 M4 Comp X-Drive
Try with the following settings:
Engine: Sport plus Transmission: S3 DSC: off Chassis 4WD Suspension: Comfort Stomp the brakes, push the throttle hard to the floor, launch control will prep, side step the brake and you’ll rocket off the line. If you’re in an X-drive version you’ll do 0-60 in ~3.0 seconds and a low 11 second quarter at 122-124mph.
MT6722.00 |
12-23-2023, 10:31 AM | #19 | |
Rep 1,369
Drives: 2020 X3MC
https://www.motortrend.com/how-to/mo...system-design/ |
12-23-2023, 11:03 AM | #20 | |
Rep 855
Needsdecaf6603.00 |
12-23-2023, 06:27 PM | #21 |
Rep 17
Thanks everyone for the responses. I guess my question is, is a rwd automatic ‘capable’ of smoking the rear tires from a stand still by just punching the gas? Not that I want to do this often but maybe occasional I just want to blow off some steam!! If so, what settings would permit this type of juvenile (lol) behavior. Thanks!!!
Jimjamz4583.00 |
