04-18-2024, 06:46 PM | #45 |
Rep 1,929
Kind of, it can launch the first widget(and i guess the first app all apps/infotainment/vehicle apps) in idrive8 for now, they haven't figured out how to rotate the controller yet.
turbojg341.50 |
04-18-2024, 07:20 PM | #46 | |
Rep 35
As for launching shortcuts, unless there is a way to do so without using the touchscreen, we'll have to do some deeper investigating. Or folks can use the workaround you suggest in the meantime! |
turbojg341.50 |
04-18-2024, 07:41 PM | #47 |
Rep 1,929
Shortcuts can be accessed with the controller up function, but then you need to rotate the controller to access the other 7 shortcuts.
canDO_Stef50.00 turbojg341.50 |
04-18-2024, 10:35 PM | #48 | |
Rep 2,622
04-22-2024, 04:06 PM | #49 | |
Rep 35
Engineering shared this today (see red outlines) Triggers: Actions: They also ask whether you think an "On Boot" trigger would be useful? Please let me know! Stephanie |
04-22-2024, 04:59 PM | #50 | |
Rep 1,929
On boot as in press the start button without starting the car? In that case that would be good to get rid of the "press ok" nag screen with a controller press action, definitely include it. I have it set on engine start now.
04-22-2024, 05:59 PM | #51 | |
Rep 35
My take is: this'll be looked into for sure! |
forcefed2567.00 |
04-25-2024, 08:14 AM | #52 |
Rep 441
This may end up being a 'dumb' question but it's obvious what a "Long Press" is as is a "Press" but what distinguishes a "Touch" from a "Press"? I wasn't aware that there was anything built into buttons to sense a "Touch" of the button rather than it being "Pressed".
04-25-2024, 08:19 AM | #53 | |
Rep 1,264
04-25-2024, 08:58 AM | #54 |
Rep 441
04-25-2024, 09:15 AM | #55 |
Rep 1,264
All of them on the center control module, not all of them are currently available in cando but i believe they will add the rest eventually. From a usability perspective though it is tricky to find good uses for these, since you obviously can't press a button without also touching it and the button still needs to perform its original function as well.
04-25-2024, 10:25 AM | #56 | |
Rep 35
On the second point, I think an earlier version might have had a problem with the Touch events being triggered on Press, but that has been resolved some time ago. A touch is effectively triggered only when the finger is lifted off from the button. If there is a press in between, the initial touch does not fire. Effectively, a touch is a touch, and a press is a press. |
04-25-2024, 10:59 AM | #57 | |
Rep 1,264
oh interesting on the touch function, i just tried it and you're right, except for the DSC Touch. That one triggers on the initial touch and not the release, and it's the one i had tested this on and i just assumed they all worked the same way. |
04-25-2024, 11:17 AM | #58 |
Rep 35
DSC touch is very different from the others. While iDrive buttons fire a single "touch on / touch off", DSC continually fires a touch event. Not sure how that can be used in a good manner, but you guys are so creative!
04-25-2024, 03:49 PM | #59 |
Rep 441
Well that was short-lived! Was playing around associating some different buttons and the app froze. Checked my WIFI connection and CANDO no longer shows up in my available WIFI connections list. Tried another device and it doesn't show up there either. Restarted the car several times and played around for about an hour and nothing.
Put an email into CANDO support but was wondering if anyone else experienced something similar. Update: Talked to Stef and he was a tremendous help. Had to press and hold the 'Option' button on the shift console for 5 seconds to turn on the WIFI again. I believe I may have messed something up when I was trying to associate the option button. Last edited by turbojg; 04-25-2024 at 04:50 PM.. |
04-25-2024, 06:32 PM | #60 | |
Rep 35
Glad we sorted it out! OPTION Long Press is reserved for WiFi toggle. |
04-26-2024, 04:58 AM | #62 | |
Rep 35
Currently no, but we are working on that. The device keeps improving with firmware updates as more research is done and the user base expands. |
04-26-2024, 05:19 AM | #63 |
Rep 441
A thousand apologies! A poor assumption on my part. Doesn't change the fact that you were a tremendous help. I wish all companies were as responsive when it comes to after sales support.
Forgot to mention... but if it hasn't been asked for yet, (in configuring the car for various performance levels) having access to the (3) transmission levels would be great. I would also be one interested in accessing the M1 and M2 buttons separately as triggers. Last edited by turbojg; 04-26-2024 at 05:25 AM.. |
04-26-2024, 07:06 AM | #64 | |
Rep 35
At this point, we think the Drivelogic stuff is not accessible. We can only see its settings, but not change them. This may change in time as more is discovered. |
04-27-2024, 12:40 PM | #65 |
Rep 441
Hi CanDO-Stef, How is the next update coming? I would love to have the Controller CW and CCW for an association I would like to create. I would like to get to the center screen bar graphs in the sport mode. Unless someone has a better way to do that.
04-27-2024, 01:46 PM | #66 |
Rep 1,929
You have to make that the first widget, then use controller right and controller press to start it if you don't have cw/ccw controls yet.
