01-04-2024, 07:56 AM | #2 |
Rep 110
I just installed the project gamma front mounted intakes - very happy with them. However, almost zero sound from inside the cabin (which was expected) - unlike the MST intake I had in my previous m340i.
That said with the windows rolled down and doing a few pulls, you can def hear them and the sound is perfect (for me). I also have it paired with a MAD midpipe and dahler valve controller. I need to take more pics but here are a couple :: |
F90jay28.00 |
01-04-2024, 08:22 AM | #3 |
Rep 5,176
I put a set of ARM shorty silicone intakes on the G80 and you definitely hear the whooshes and pews inside the cabin with windows up. It’s not a true front mount, but because it has good sound I posted.
…and I run the Goliath exhaust, and still hear the ARMs. I do have a set of silicone RK front mounts but will use those for racing needs (coolest air). I haven’t tried those yet since the bumper has to come off.
01-04-2024, 10:09 AM | #4 |
Rep 508
BMS top mount sounds awesome. I still don't think the front mounts are worth all the extra work to install and remove.
FSociety3812.50 Skyscraper2220.00 |
01-04-2024, 10:27 AM | #6 | |
Rep 5,011
Some light acceleration (no brake boosting)
01-04-2024, 11:56 AM | #7 |
Rep 1,935
If someone comes up with a grill without the top slats then the front mount intakes will be serviceable and easier to install
01-04-2024, 12:07 PM | #8 | |
Rep 5,011
01-04-2024, 01:37 PM | #9 |
Rep 191,093
We used different front mounts on the shop's car, MAD is the loudest.
01-04-2024, 09:08 PM | #10 |
Rep 380
01-05-2024, 04:12 PM | #11 | |
Rep 21
Very interested in the ARM intakes, however I cannot find anything regarding the ARM short intakes and you're the only post I have seen with them haha. Do you have experience any heat soak with no heat shield? They look awesome and I bet the sound is amazing.
01-05-2024, 04:20 PM | #12 | |
Rep 5,011
I would definitely look into a semi shielded into at the very least. I agree they do look awesome though.
01-05-2024, 04:24 PM | #13 |
Rep 83
Drives: 2021 M340ix
Maybe this is a stupid question but isn't heavy rain an issue for the front mount intakes? I'm sure I am overthinking this but at speeds it would seem that these would be getting wet.
Maybe it's just not enough water to matter? |
01-05-2024, 04:47 PM | #14 | |
Rep 5,011
No, many people run water and or water/meth injection to help with detonation and that's a hell of a lot more than a wet filter. I ran maybe 2-3 gallons through my motor a week. Wet filters probably aren't the most efficient thing ever but I have done track days in the rain without issue or noticing any power loss. Only issue you would have with water is fully submerging your filter completely as you could hydrolock the motor. They do make dry socks for filters but I've never had to use one. https://www.knfilters.com/blog/kn-re...d-air-filters/
01-05-2024, 05:10 PM | #15 |
Rep 21
That is what it would seem like, however I would think the design and maker of the intake would have put that into consideration right? haha
I have been searching high and low someone's video haha ARM has a video however very low quality doesnt sound like anything which is doubtful! |
01-06-2024, 09:31 PM | #16 | |
Rep 83
Drives: 2021 M340ix
When I was 18 I had a 1997 SVT Cobra. I installed a ram air intake which had a scoop near the bottom of the front bumper. Ended up shorting out my mass air sensor two months later due to heavy rain. So I still get nervous when water can get into my intake, lol. |
01-06-2024, 09:54 PM | #17 | |
Rep 5,176
I’m thinking if the car is moving that the separate intake air temps at the cone filters should be very close. They both pull air from the same zone (yes, one is in front with access to cooler air when at a standstill), and both silicone tubes are short and likely to soak nearly the same amount of heat. Since one silicone also tube sits in front of the other (regardless of brand) I think the front turbo will always receive slightly cooler IAT than the rear. For the low price, super-easy installation, and high quality double-cone filters, I’d say the ARM shorty silicone setup is a great deal. If I were doing track laps and really heating things up, or when I go for a drag record and need that extra 0.01sec shaved with the coolest possible IATs, then I’ll switch to my silicone front mount intakes.
01-08-2024, 10:49 AM | #18 | |
Rep 21
Very interested to see this!
Appreciate you! Quote:
01-08-2024, 11:45 AM | #19 | |
Rep 5,011
That would be cool! I'd love to seem some temp data
01-10-2024, 03:21 PM | #20 |
Rep 5,176
SIGM3 Info@mad-us.com here’s the data collected:
Cold day, 38F ambient temp, car sat in driveway to warm up 10min. Then I cruised easy for 5mi in Efficient to my local Wawa, snapped the BM3 pic as I arrived, and jumped out with my temp gun. First temps, parked after an easy warm-up: 45F Ambient 60F IAT 217F Coolant 55.1F front air cone, middle of top 55.2F rear air cone, middle of top 95.9F front air cone, low edge by turbos 74.8F rear air cone, side edge by turbos Then I put the engine into Sport mode (not plus, in case that triggered fans to Max Cool) and did some highway stuff in S3 to stay around 5K RPM and with 7-15PSI boost on the dash indicator. Second temps, after a little highway fun: 46F Ambient 60F IAT 215F Coolant 55.1F front air cone, middle of top 55.2F rear air cone, middle of top 95.9F front air cone, low edge by turbos 74.8F rear air cone, side edge by turbos I’d say these don’t heat soak too bad.
01-10-2024, 03:59 PM | #21 |
Rep 1,935
The hp loss from heat soak is soooo minimal it makes no sense even talking about it. Plus the intake charge is compressed by the turbo to like 2-300f and then cooled by the charge cooler. You won't notice any difference here.
01-10-2024, 04:00 PM | #22 |
Rep 378
Looks good, I just ordered the ARM intake yesterday so I'm glad they don't appear to heat soak much. I'd be curious to see the IAT delta VS stock intakes.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
