      08-05-2022, 10:48 AM   #89
Team Tonka
Drives: 2022 G80 M3 xDrive Comp.
So anyone else noticed the below yet? Or is it just me? Maybe its hitting the bump stops? Notice it mostly when going over little bumps in the road or even road cracks the most. On the highway and smooth surfaces I don't hear it....
Photos are drivers side spring, raised up on a floor jack. If I grab the springs they are solid, no moving them or wiggling them around!
Originally Posted by Team Tonka View Post
For those with the Eibach Front Springs only, I have one thing I'm curious about - I seemed to have noticed it more recently that it sounds like when driving over any cracks in the road or bumps like something is loose under the car (more chassis noise) - almost like exhaust is bouncing around or springs - but I don't think its that. It's also hard to decipher if coming from the front of the car or rear. More of something I hear vs. feal.
This simply could be that I'm getting more miles on the car, around 2300mi, which means around 700ish on the front lowering springs. It's not something I noticed prior to the front spring install, nor right after, but only as of more recently.
Anyone else noticed anything similar after the front only lowering springs install?
      08-05-2022, 12:15 PM   #90
Chad11491
Drives: 21 IOMG M3 6MT
FWIW I had an aftermarket rear shock mount bearing go bad on a car once and it sounded like something rattling around on rough surfaces. replaced the shock mount and it went away for good. Is it both sides? If it's one side maybe something is loose?
      08-05-2022, 01:39 PM   #91
Team Tonka
Impossible to tell if its from one side or both, or even from the front of the car for that matter...
      08-05-2022, 04:16 PM   #92
evoi19
evoi19's Avatar
Drives: 2022 G80C
So I've had mine in for 2-3 weeks now and I haven't experienced any out of the ordinary noises. I'll keep an ear out and report back if I do though. Maybe it's a loose screw or nut that wasn't tightened all the way and it's backed out enough to rattle on bumps?
      08-05-2022, 04:46 PM   #93
DoubleDave
Drives: 2022 M3 6MT
I had my AST springs removed and went to stock rear and Eibach front.
The car doesn’t feel broken anymore and it looks better too. Also no scraping even on speed bumps.
pinky_chi173.50
BIGW0RM3171.00
Nado230.00
M4Tejas794.00
venox22132.50
      08-05-2022, 06:57 PM   #94
provenflipper
Drives: Garage is currently empty
Originally Posted by Southern View Post
Adding to the mix. Eibach springs with 15/12 spacers. Love the drop and rides like stock (although I only put 50 miles on it stock lol).
Which front lip or splitter are you running? Looks great.
      08-05-2022, 07:27 PM   #95
Southern
Southern's Avatar
327
Drives: G80 M3
2022 BMW M3  [0.00]
Alpha N splitter, love the subtle look. And thanks!
      08-05-2022, 09:12 PM   #96
JDUNITNOW
JDUNITNOW's Avatar
Drives: BMW 335I, 750li, X5 G80
I'm getting a noise in the rear passenger side. It's intermittent and mostly at parking lot speed or pulling out driveway. I didn't have new bolts replaced when installed and wondering if this is the case. My fronts were making noise and had them reinstalled and now no noise.
Formerly Wyndi335I
2009 BMW 750li sold
14 BMW X5
04 BMW X5
11 BMW 335i convertible (sold, sellers market
      08-08-2022, 11:34 AM   #97
Team Tonka
What bolts up front are meant to be only a one-time use?
      08-08-2022, 12:00 PM   #98
JDUNITNOW
JDUNITNOW's Avatar
I'm sorry, it's for the rear and it's actually a nut.
Formerly Wyndi335I
2009 BMW 750li sold
14 BMW X5
04 BMW X5
      08-15-2022, 07:16 AM   #99
Phobidden.M
Drives: 2022 M3 Comp Xdrive
Originally Posted by evoi19 View Post
Here's a pic from today. Running 15mm spacers all around on ps4s.
Any other angle pics of the wheels. Trying to see if I should go 15mm spacers all around. I’m on same wheels with ps4s and thinking of dropping the front only.
      08-15-2022, 10:14 AM   #100
csayad
csayad's Avatar
Drives: BMW M3 xDrive
2023 BMW M3 Competi ...  [8.57]
  [0.00]
@Southern
Do you with the 15mm in the front at all? With the pzeros and on the front springs?
      08-15-2022, 01:43 PM   #101
Southern
Southern's Avatar
327
Drives: G80 M3
2022 BMW M3  [0.00]
Originally Posted by csayad View Post
@Southern
I had the 15mm on for a few weeks, no rubbing whatsoever with Pirellis. I ended up switching to 12mm square about a week ago.
      08-15-2022, 04:05 PM   #102
evoi19
evoi19's Avatar
Drives: 2022 G80C
Here's a few others. I don't have a close up but let me know. The front is now a 2 finger gap in the fender.
      08-15-2022, 05:42 PM   #103
csayad
csayad's Avatar
  [0.00]
How much did this cost everyone who did it?
      08-15-2022, 07:11 PM   #104
evoi19
evoi19's Avatar
Drives: 2022 G80C
It's gonna vary depending on how much your shop charges per hour but mine took 2hrs.
      08-16-2022, 01:32 AM   #105
Asmooth0101
Drives: Lexus rx350
Can someone provide the name/part number of the one time use bolts that should be replaced when installing eibach front springs only?
      08-27-2022, 06:59 PM   #106
Phobidden.M
No rubbing with the 15mm spacers all around? Even with full turn of steering wheel?
      08-27-2022, 08:20 PM   #107
evoi19
evoi19's Avatar
Drives: 2022 G80C
None whatsoever
      09-03-2022, 02:13 AM   #108
Solodoloo
Drives: 2022 G82 M4 COMP
Pretty sure this is it
https://parts.bmwnorthwest.com/p/BMW...306787062.html
      09-12-2022, 09:22 PM   #109
Phobidden.M
Do you pics of how much the wheels stick out with the 15mm spacers all around?
      09-12-2022, 09:24 PM   #110
Phobidden.M
Do you have a pic of the front end? Have the same splitters on order. Want to see how much clearance on the front with the front springs lowered.
