12-02-2021, 02:06 PM | #177 |
General
63062
Rep 24,605
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-02-2021, 02:11 PM | #178 |
General
63062
Rep 24,605
12-02-2021, 02:23 PM | #179 |
General
59588
Rep 19,435
///M Power-Belgium63062.00 |
12-02-2021, 02:25 PM | #180 |
General
59588
Rep 19,435
12-02-2021, 02:42 PM | #181 |
Field Marshal
6726
Rep 1,829
Drives: '08 E92 M3
OMG.. those legs.. Is the guy in the red shirt 'checking out' Bernie?
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
M5Rick59587.50 ///M Power-Belgium63062.00 |
12-02-2021, 02:46 PM | #182 |
Rep 4,445
Track Info
Noticed that Lewis was grinding his teeth during his interview. Has he always done that?
Track map Blind corners Full throttle 75% Walls with new asphalt. Turn 1 prime spot for carnage. Tire blowup will likely end with wall contact. Alonso was the only driver to predict a clean weekend. FORMULA 1 STC SAUDI ARABIAN GRAND PRIX 2021 CIRCUIT: Jeddah Corniche Circuit LENGTH: 6.174km CURVES: 27 RACE DISTANCE: 50 laps, 308.450km RECORDS: / PIRELLI SELECTION: C2, C3, C4 The first sector is characterized by a first extension, final of the last of the 3 DRS zones arranged around the circuit. 2nd sector is a series of medium-speed curves, with the only important braking zone preceding the complex of Turn 1-2. T13 has banking of 12 degrees and considerable lateral forces, which will also put a considerable amount of stress on the tires. After a series of "kinks" at full throttle, a DRS area follows, curiously "wedged" between Curves 20-21 with the premise of bringing the cars closer together before T22-2 for overtaking opportunities. In the last sector, another DRS area is set up from T25-27.
12-02-2021, 02:53 PM | #183 | |
General
63062
Rep 24,605
As for MAX , he always said : I love shaving walls ...
M5Rick59587.50 |
12-02-2021, 03:12 PM | #184 |
General
59588
Rep 19,435
Easily done being where the start is to the first turn on the map, if it's only Alonso predicting no issues at the start then some contact or worse can be on the cards.
12-02-2021, 03:23 PM | #185 | |
General
63062
Rep 24,605
Well... 'Bernie is 90 and she is 44 . As you can see , Bernie needs some help and I'm pretty sure in the bedroom as well .. I'm so sorry Bernie !
DrFerry6725.50 |
12-02-2021, 03:25 PM | #186 |
Rep 1,785
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Max has said that in previous races that he has overheated his tires...which when it happened, he said it forced him to go wide and off course. His not being able to control his car and stay on track certainly creates a problem for him at this venue.
12-02-2021, 03:28 PM | #187 | |
General
63062
Rep 24,605
Spanish b@lls , you know what I mean !
12-02-2021, 03:30 PM | #188 |
General
59588
Rep 19,435
I must say it's good that Bernie is not wearing flip flops there!
///M Power-Belgium63062.00 DrFerry6725.50 |
12-02-2021, 03:36 PM | #189 |
General
59588
Rep 19,435
12-02-2021, 03:46 PM | #190 | |
General
63062
Rep 24,605
HAM was going extremely wide (with cold tyres) at Silverstone in the Copse turn while he rammed MAX in the wall . HAM's dirty tricks , he even pushed Checo into the pitlane ..
12-02-2021, 03:48 PM | #191 |
General
63062
Rep 24,605
I was thinking about a tow ...
12-02-2021, 03:48 PM | #192 |
General
59588
Rep 19,435
The track will be cooling down when race starts at 20:30 their time.
12-02-2021, 03:52 PM | #193 |
General
59588
Rep 19,435
12-02-2021, 03:54 PM | #194 |
Rep 4,445
Lighting seems to be lacking around the track, shadowing, hot spots and dimly lit areas are noticeable. Promoter needs some axillary lighting and glare shields ASAP.
///M Power-Belgium63062.00 M5Rick59587.50 |
12-02-2021, 04:03 PM | #195 |
Rep 1,785
Drives: E86 3.0si
12-02-2021, 04:07 PM | #196 |
General
59588
Rep 19,435
12-02-2021, 04:22 PM | #197 |
Rep 1,785
Drives: E86 3.0si
12-02-2021, 04:33 PM | #198 |
General
59588
Rep 19,435
