Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      01-27-2024, 09:58 PM   #1
Jax327
Jax327's Avatar
436
Brake fluid level?
Guys,
I just replaced my brakes pads with ebc reds. My car only has 600 miles so I didn’t have to compress the pads at all. I did forget to open the brake reservoir. Anyways, I took a look at the level and it seemed very high, actually it was above the max level. I took a syringe and removed a bunch. Wanted to get your take on this. First pictures are when I first looked and second ones are after. It’s real hard to tell the level from the lighting.
      01-28-2024, 07:04 AM   #2
turbojg
Drives: 2024 G82 M4 Comp. X-Drive
Both sets of pads are basically new and if they are the same thickness you should be right on with the original amount of fluid. I wouldn't remove or add anything unless there is a difference in the pad thickness.
stormlv932.00
      01-28-2024, 07:09 AM   #3
Jax327
Jax327's Avatar
436
It just seems like a lot of fluid and it was above the max line. The was concerned it would overflow.
      01-28-2024, 09:36 AM   #4
Drives: S4
You’re gonna end up below the min line as your pads wear.
Skyscraper2196.00
      01-28-2024, 10:08 AM   #5
kgelfen360
kgelfen360's Avatar
I don’t think u needed to remove anything. Especially if pads were essentially same thickness.
I don’t think opening master cylinder is needed for what u did.
      01-28-2024, 10:51 AM   #6
Jax327
Jax327's Avatar
436
I put the fluid I took out back in. Sometime I overthink things haha
