05-10-2022, 09:46 AM | #45 | |
Rep 672
Realtor, Architectural Engineering
Remax 200 Realty Winter Park, FL |
05-10-2022, 08:55 PM | #46 |
Rep 1,773
Nope. I would never let anyone remove the front axle aside from the dealer. There is no need to remove the entire axle. You can detach the struts, install the new springs and adjusters and re-install the strut. Unless they are confusing strut with axle. Which would worry me tbh.
M4Tejas788.00 |
05-11-2022, 01:42 AM | #47 | |
Rep 672
05-13-2022, 12:42 AM | #48 |
Rep 1,773
05-17-2022, 08:55 PM | #49 |
Rep 352
I was quoted for MSS HAS installed.. price includes parts, alignment, and labor for install.. $2500 total. Unsure how to feel about this.
Means roughly $1200 for the HAS kit. $1300 between tax, alignment, and labor. |
Limegrntaln13469.00 |
05-19-2022, 11:56 AM | #50 |
Rep 75
550, SoCal OC area
05-19-2022, 08:45 PM | #51 |
Rep 1,382
I paid $250 originally for MSS install.
Just went back to have the lower MSS kit fitted on the front and it was $120 and that included fitting my Unit 17 splitter. All was done in less than an hour. This was in Queens in NYC Some of these quotes are absolutely absurd. This is a quick and easy job to do if you know what you're doing. |
05-19-2022, 10:30 PM | #52 |
Rep 156
Anyone in the Las Vegas area that needs work or
Modifications done let me know. Prices will be a lot less than what you’ll be normally paying and work will be top notch. |
05-20-2022, 02:50 PM | #53 |
Rep 249
Anyone know a reputable shop in the lower CT/Westchester area to install KW HAS and adjustable arms?
/// Santorini G80 6MT
Pics and stuff |
05-21-2022, 07:38 AM | #54 |
Rep 1,382
BMWRacer5232519.00 |
05-25-2022, 02:35 AM | #56 |
Rep 234
05-25-2022, 03:03 PM | #57 | |
Rep 672
05-25-2022, 10:35 PM | #58 |
Rep 234
lots of f8x on his site , he didn't mention any issues when i asked for a quote
https://www.facebook.com/rogueworks |
JoNaH279.00 |
05-25-2022, 10:51 PM | #59 | |
Rep 672
canigetaxm377.00 |
05-26-2022, 08:00 AM | #60 |
Rep 263
06-01-2022, 07:14 AM | #61 | |
Rep 224
He is charging me $65 more for the spring set than I can purchase it myself. Labor cost $1,009 to install including the install of spacers and alignment. (installing spacers should be nothing really, wheels are off and your just putting in a plate). Alignment is $200 I plan on calling a few more shops in the Houston area. Hell, may call dealership and see what their labor cost is to install. |
07-20-2022, 09:48 AM | #62 |
Rep 179
07-20-2022, 09:53 PM | #63 |
Rep 25
07-22-2022, 08:19 AM | #64 |
Rep 110
Install on the springs on the G8X platform is similar to the F8X,that is If you ever have installed springs on a F8X! I just installed mine and going to align it today
07-22-2022, 09:25 AM | #65 |
Rep 86
The Xdrive fronts are 10x more of a pain the the RWD. Did the install myself on my new M4 in about ~2 hours for all 4 corners. On my lift and I'm very familiar with working on BMWs.
Removed the nut for the front axles to give me enough room to swing the strut out without binding up the axle. I was able to compress the strut by hand enough to swing out like on the RWD, you need some muscle though as the strut isn't easy to compress. Strut only needs about an inch of compression to clear the fender liner.
~2022 M4 Comp Xdrive - Bm3, KW V3s, Downpipes, E50 Custom Tune
D///M31.50 |
12-06-2022, 03:47 PM | #66 |
Rep 19
Got quotes ranging from $700-$800 to install the M Performance HAS. I'm thinking about putting that money towards a Quickjack and doing the work myself based on tdott's DIY write-up. It'll probably take me twice as long as everyone else here, but it'll be satisfying and I can use the Quickjack in the future for wheel swaps and height adjustments based on season.
tdott3942.50 Limegrntaln13469.00 |
