03-20-2024, 03:37 AM | #1 |
Rep 16
KW V3 vs. Ohlins Road & Track - xDrive Fitment Comparison
Interesting video I saw uploaded comparing the fitment of Ohlins and KWs. I'm sure others have also seen that thread of the M3 CS installing Ohlins and the wonky fitment that resulted. It steered me away from considering the Ohlins and more towards the KW V3s. However, in this video the KWs are maxed out and the Ohlins still have plenty of room to go lower, which is notable since both cars have similar ride heights.
If you're seeking a high-quality street performance coilover in the $3k price range with maximum ride height adjustability, Ohlins looks like the best option. Comparison starts at 4:54 |
03-20-2024, 11:12 AM | #2 |
Rep 190,807
+1 for Ohlins, in my opinion, its the best coilover kit on the market
azonis202121.00 BimmerFix1390.50 |
03-20-2024, 12:55 PM | #4 |
Rep 869
Bit of info below for those that are going the Ohlins route.
The height adjustment for Ohlins is on the bottom of the shock. The top part you see in the video with a lot of remaining threads is for spring preload. You can lower that a lot to get the height you desire but it would cause the spring to be loose. This could potentially damage your top mounts causing a creaking noise and your car will not pass safety inspection in some states. The solution we landed on for the M3CS customer to achieve his ideal stance safely was maxing out the bottom height adjuster, lowering the preload adjuster, and then add a set of helper springs to keep the main spring in place. TL;DR: get helper springs if you’re going for stance. Also side note: For those who plan to pair their coilovers with camber plates - some plates have stock spring stack heights but have taller strut stack heights which will add additional height.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) Last edited by Luc@Speed&Tech; 03-20-2024 at 01:07 PM.. |
azonis202121.00 MaC-N54-E82464.00 |
03-23-2024, 03:02 AM | #5 |
Enthusiast
370
Rep 293
Drives: 2025 M4 Comp xDrive
I was going to do KW HAS but now im leaning more towards coilovers. My 25 M4 comp x drive should be ready for pickup next month
2025 M4 Competition xDrive
IG: Automaz_ |
03-23-2024, 10:53 PM | #6 | |
Rep 190,807
if its strictly a street car, i would save the money and get a HAS system
03-23-2024, 11:55 PM | #7 | |
Enthusiast
370
Rep 293
Seems like for a g82 the rear sag factor is no longer a concern and MSS extra low corrected any issues. Would you recommend MSS extra low or KW HAS in terms of being able to keep the original feel of the car quite similar after changing out the springs
IG: Automaz_ |
JGreen4.50 |
03-29-2024, 05:01 PM | #8 | |
Rep 185
BSM G80 XDrive
03-29-2024, 06:11 PM | #9 |
Rep 18,823
Also note that KW now includes Code Isolators in their kits, so the kits are pretty evenly priced when you factor in what's needed. Ohlins R&T do not include code isolators (available separately), but the KW code isolators are slightly less expensive and can be used if you want to save a little extra scratch.
That being said, the Ohlins R&T is a pretty awesome street package, you'll be hard pressed to find anyone disappointed in how they feel.
azonis202121.00 |
03-31-2024, 11:28 PM | #10 |
Rep 843
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
ohlins went low enough for me
azonis202121.00 |
03-31-2024, 11:47 PM | #11 |
Rep 16
Wow, that's low!
How's the comfort at that ride height? From my initial reading on the forums, I've seen people highlight the comfort of the Ohlins while still improving upon the factory suspension when it comes to handling. It would be interesting to know if they still offer a good level of comfort when adjusted to the lowest possible ride height. |
04-01-2024, 12:34 PM | #12 |
Rep 1,105
Sheeesh I'd go mad daily'ing that . And a front lip ..
Balls of steel
///M3 2024 G80 Competition - Starting Lineup
///M4 2019 F82 Competition , 2019 G30 540i , 2008 E92 335i - Retired |
