02-16-2024, 05:07 PM | #1 |
Rep 1,663
Should I go lower?
I’ve had my car since Christmas. I got the port installed HAS. The rear looks spot on, but I’m thinking the front could go a bit lower. I’m a little concerned about the ride quality by going much lower. It’s already firm.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
02-16-2024, 05:18 PM | #2 |
Rep 2,617
Any spacers? Add some 12s or 15mms and you may not want to go lower after that.
02-16-2024, 05:32 PM | #3 |
Rep 1,663
Yep, already running 12’s in the fronts and 10’s in the Rears
02-16-2024, 05:35 PM | #4 |
Rep 497
I would dump it. I have my fronts max low and no issues on 15mm spacers with the same tires.
02-16-2024, 05:50 PM | #5 |
Rep 1,663
Do you get any scraping or bouncing in road dips?
02-16-2024, 05:59 PM | #6 |
Rep 497
I don't have a ton of time driving it but I've taken it for some aggressive rips and it's been issue free. I'm adding a lip next week so we'll see if that changes but without a lip, no issues at all. Your car looks great and I think lowering the front will better match what you have going in the rear.
02-16-2024, 06:09 PM | #7 | |
Rep 1,663
02-16-2024, 06:21 PM | #8 |
Rep 497
02-16-2024, 06:27 PM | #9 |
Rep 1,663
Will do. Is it very hard or take long to adjust them?
02-16-2024, 06:31 PM | #10 |
Rep 497
It’s super easy, especially the fronts. Did they leave the spanner wrenches in the trunk? You just dial down the blue collar. Here’s a pic of mine from taken all the way down.
02-16-2024, 06:37 PM | #11 |
Rep 1,663
Cool, thanks. Yep, got the spaners in the trunk. I’ll give it a shot tomorrow. I’ve read I’ll need an alignment afterwards.
02-16-2024, 06:41 PM | #12 |
Rep 497
02-16-2024, 06:47 PM | #13 |
Rep 1,663
Yeah, had it done last month. Funny thing my dealer said they couldn’t do the adjustment and I would need to go to a “performance shop”.
02-16-2024, 07:51 PM | #15 |
Rep 122
02-16-2024, 07:55 PM | #16 |
Rep 497
One additional thought is you might want to consider moving your 12mm spacers from the front to the rear and getting a set of 15mm spacers for the front. I have no issues with the 15mm up front, max low and 12's in the rear. I misspoke earlier when I said that I had 12mm in the front, I have 15f/12r with the Michelin PS4s and no rub at all.
Adcampo885.00 |
02-16-2024, 08:04 PM | #17 | |
Rep 497
Try to find a local spot that does one of those lifetime alignment deals, it's well worth it. And thank you for your service! |
02-17-2024, 10:02 AM | #18 |
Rep 1,663
Well, I just checked and it looks like it’s already at the lowest setting. That’s how it came from the port. I’ve read they set it at 10mm drop at port.
02-17-2024, 01:25 PM | #19 |
Rep 267
Mine measures the same as yours. For some reason mine looks lower than yours but it’s not. Perhaps my tires having dressing on them and looking blacker makes it blend better? Not sure. Ride on mine is perfect and I’m pleased with the HAS kit. I had heard from someone else that the NJ port was dropping the HAS kit all the way. I checked mine previously and it did look like it was maxed out.
02-17-2024, 01:47 PM | #20 | |
Rep 497
02-17-2024, 01:52 PM | #21 | |
Rep 497
I will measure mine just to confirm when I get my car back next week. |
Adcampo885.00 |
02-17-2024, 01:56 PM | #22 | |
Rep 267
Going back and looking at photos of my car, then just looking at the real car, I think it just looks better in real life than in photos. The photos do exaggerate the gap a bit IMO. |
