01-27-2024, 08:40 PM | #1 |
Rep 5,155
I know I was not impressed when I saw our cars deliver with the PUNY 1-caliper rear brake setup. I looked for alternatives but current offerings from Essex are $5K. Paragon removes the emergency parking brake (EPB) function requiring us to code the EPB out.
BUT FINALLY… Now available from our BimmerPost buddy dentprotony@gmail.com is a custom-made setup that includes: -custom black anodized brackets w/ bolts -4 piston calipers with ceramic pads -EPB calipers with pads -brake lines with banjo bolts You can pick red or blue calipers for the base price, and he offers custom colors for a small upcharge. You reuse your stock BMW rotors and EPB motors for an OEM+ setup. The brake rotor backing plate is removed and not used, same with the EPB cable bracket. The new brake lines route well without touching nearby suspension. I put my 18x10.5 Apex race wheels on to check gaps and I could still fit my fingertips between the barrel and both calipers. I’m not worried about rocks scraping. Go hit him up and get your order placed! The price is sooo nice. Don’t ask me, go ask Tony! Disclaimer: I was offered a nice discount because I spent a full day mocking things up, measurements, tons of photos and FaceTime, and suggesting improvements. Tony was nice to work with, and I hear good things about him from others here on BPost and on IG.
01-27-2024, 09:34 PM | #2 |
Rep 459
Thank you for the shout out Jimmy! A few on here know me from other forums (primarily x5m, f10 m5, e39 m5, e70 and f15), i am well known to offer budget friendly solutions to factory issues (driveshafts on f15/f15), as well as big brake kits that look 🔥🔥🔥🔥, offer excellent and consistent braking performance, as well as great and responsive customer service overall. I started a few years ago when i was able to fit a Porsche Cayenne brake set up onto my personal e70 x5, and I realized that with the help of an excellent machine shop (we have a state of the art facility locally in my town), we have a small rice performance shop that can scan things like spindles and suspension and can do cad projects, top notch paint and restoration shop, and a great cnc facility that does my work in Chicago area, i can make things work.
So over time i expanded into different platforms, took ideas and solutions from other manufacturers, and in the end i can offer some badass kits at a fairly affordable price. Long story short, we did some test fitting and measuring on Jimmys beautiful m3 today, to fit a full size 4 piston bbk with a separate epb (dual caliper set up), so your parking brake still functions as intended, but you get a bigger monoblock 19z brembo caliper with carbon ceramic pads (not a puny floater that came from factory ), and a tesla model S electric caliper that works with the stock actuator via a small adapter. Bracket is milled out of a chunk of 7075 aluminum for sufficient strength and should hold anything you can throw at it. I plan on offering these kits at 1880 shipped, hope this sounds fair to the m3/m4 community. Kit is made to work with the stock rear rotor and should easily clear 18” wheels for thos who track. There is a chance to fit some 17” but that we would need to confirm as we go. Whole set up is made to be a plug and play direct bolt on without any cutting, drilling, or any other bs. Just install, bleed, and ride. Jimmy’s kit should be out of paint in about 1.5-2 weeks, after that i would try to offer these for sale at about 1-2 kits per week rate (takes time to machine, prep, paint, pack, etc). Please let me know if you think i am onto something and there would be significant demand for these in this community, hope i can make you look back at your beast one more extra time while she’s sitting in the parking lot 👍 |
01-28-2024, 11:17 PM | #3 |
Rep 119
Good Luck with sales great idea, quick question why does the main caliper look backwards? Any better designed calipers that match front OEM shape and size?
adam12hicks250.50 |
01-29-2024, 03:34 AM | #4 |
Rep 5,549
Essex/AP Racing g8x brake kit does not require the rear EPB to be coded out. Their rear brake kit is offered with and without a second small parking brake caliper. Brake pad sensors do not need to be coded out.
The caliper and pad combination shown in the OP do a poor job of covering the full swept area of the brake rotor. How do the piston areas compare with the stock piston area? Last edited by M3SQRD; 01-29-2024 at 04:38 AM.. |
TopJimmy5463.00 wowwitsgau180.50 |
01-29-2024, 07:10 AM | #5 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Love what you are doing here, conceptually! I want to ask about how this kit affects the brake bias? Have you done the math? Can you share with us piston sizes for the new and old calipers?
I am curious why the rear calipers are being moved behind the rear axle point? Ideally, the unsprung weight needs to be kept between the axles for better performance. P.S. I was thinking about researching if the F87 M2 rear calipers will bolt up, but haven't gotten the time. |
01-29-2024, 07:23 AM | #6 |
Rep 5,155
Because of where the EPB cable connects the EPB occupies the spot the OEM caliper sits. The Brembo caliper moves to the upper rear where hoses reach, and so no debris accumulates in the calipers.
01-29-2024, 07:27 AM | #7 | |
Rep 5,155
01-29-2024, 07:30 AM | #8 | |
Rep 5,155
01-29-2024, 07:33 AM | #9 |
Rep 5,155
Thank you for correcting. I edited the first post for clarity.
01-29-2024, 07:40 AM | #10 |
Rep 5,549
So the pad currently sticks up beyond the brake rotor OD? The unswept area, and more specifically pad inner radius, is more than 2 mm. Are there pads with different heights (radial depths) available for this caliper? The current brake pad used in the pics, who’s the manufacturer and part number? What car manufacturer and model is this caliper from?
01-29-2024, 07:51 AM | #11 | |
Rep 5,155
Since the caliper is from a common performance vehicle I’ve already seen pads from EBC, Powerstop, Hawk and others. I asked iSweep if they have IS2000 pads for this setup and they said yes. In the pic you see a Powerstop but I’m not sure of the part number. You can send a PM to Tony for that detail.
01-29-2024, 10:38 AM | #13 |
Rep 190,807
Looking forward to your review on how it brakes vs stock and whether the upgrade is worth it for daily cars that never see the track.
TopJimmy5463.00 |
01-29-2024, 09:18 PM | #15 | |
Rep 459
All this is definitely something to upgrade and install at your own risk, i am not a mechanic, i just get lucky sometimes |
01-29-2024, 09:28 PM | #16 | |
Rep 459
Current caliper used in the kit is a Porsche Panamera rear caliper, they came in different part numbers due to some being anodized, others black, others came in red or lime green. We use basic silver because they are most readily available off 3.6 panamera. Pad is powerstop z23 carbon ceramic pad , this caliper supports a ton of pad options from different compounds to numerous manufacturers including powerstop, ebcbrakes, hawk and many others. Pad part number is z23-1417. There is 2 radial heights pads available for this caliper but given the disc sizing we only can use bigger pad. |
01-29-2024, 09:30 PM | #17 | |
Rep 459
Its a yes and no, depending on the size and offset of the ccb rotor it might be direct fir if the rotor is identical. Good news is that porsche offered carbon ceramic brakes on their panameras so proper pad is available if needed |
01-29-2024, 09:32 PM | #18 |
Rep 459
I should have Jimmys kit out of paint with proper adjustments by the end of next week hopefully. Machine shop been crazy busy unfortunately
01-29-2024, 09:34 PM | #19 |
Rep 459
Not sure if the disc is the same. I have measurements for the steel disc, if you can find a little time and measure out your ccb disc we can compare, there is a good chance it might be the same, if so then it would be a direct fit 👍 you can pm me and we can go from there
01-30-2024, 04:41 AM | #20 | |
Rep 318
Drives: '24 M4 Competition xDrive
That being said, I'm actually putting on my new wheels on Thursday, so my wheels will be off. And while they're off, I'll get you full measurements of my CCBs if you'd like? |
01-30-2024, 05:52 AM | #21 |
Rep 5,549
CCB rotors are both physically larger in diameter and have a longer radial depth (CCB requires more surface area than iron brakes to dissipate heat). You’re already having trouble covering the swept area/radial depth on the iron rotor.. Rotor thickness and offset are different for CCB vs iron. Furthermore, CCB rotors require a special pad compound so you’d be limited to one pad profile, the G8x CCB rear pad or, if the F8x rear pad has the same radial depth as the G8x, you could use the F8x rear pad and its 4P caliper. Nonetheless, your G8x iron kit is NOT an option for the G8x with CCB rotors.
01-30-2024, 06:13 AM | #22 | |
Rep 5,549
Technic2295.00 |
