03-27-2024, 06:16 PM | #24 |
Rep 728
Bad news... I found out today that I got selected in a jury pool for a trial, so I had to cancel my appointment for tomorrow's install. Hopefully, either I don't get selected as a juror/alternate, or it's a short trial and I can get them installed next Thursday at least in time for Buttonwillow.
tom @ eas8224.00 |
03-28-2024, 04:47 PM | #25 | |
Rep 105
Tell them you can't make it because people on the internet are eagerly awaiting your feedback on an important car modification.
m4ml1834.00 |
03-28-2024, 06:48 PM | #26 |
Rep 18,823
Priorities, right?
04-01-2024, 05:54 PM | #27 |
Rep 22
04-05-2024, 01:02 PM | #29 |
Rep 18,823
We just completed installation of the SPL pieces yesterday, M4 is at alignment today. m4ml should probably be following up shortly or after his track weekend.
04-08-2024, 10:15 AM | #30 |
Rep 248
04-08-2024, 02:02 PM | #31 |
Rep 18,823
You have PM.
Yesterday, 11:06 PM | #33 | |
Rep 728
My point of comparison is between: Chuckwalla - stock rear - -2.25° front camber, 3/16" toe-in/-2.0° rear camber 3/16" toe-in Buttonwillow - SPL rear upper (camber) arms w/lockout, toe links w/lockout, and traction links - -3.2° front camber, 0" toe/-2.5° rear camber 1/8" toe-in The SPL rear upper arms allowed for the additional camber in the rear. I already had the camber plates in the front. The car felt better on exit after the upgrade. I felt more confident rolling into the throttle quicker and sitting the rear end down than I did at Chuckwalla. It also felt better in the longer sweepers, with more sense of what the rear was doing. Comparing something like turn 4/5 at Chuckwalla to Riverside at Buttonwillow (as best of a matchup for a long constant(ish) turn as I could find between the two); after a few laps at Buttonwillow I had more confidence in Riverside than I did in turn 4/5 at Chuckwalla all day, and I was able to throttle steer a bit better through it once I had that confidence. I also want to say that I could feel the car taking a set better in transitions, which also gave me more confidence. Was it a HUGE improvement? No. Was it a noticeable improvement? Yes, but only slightly. I can't think of a way to describe the rear before. I want to use the word "soft", but that's a bit hyperbolic. It wasn't soft by any stretch, it just wasn't solid and it wasn't necessarily consistent. Now the rear is solid and consistent. With all of that said, I'm not much of an NVH kind of guy. I know what I did, and I know the consequences, so I really don't care. If you are an NVH kind of guy, I don't recommend the full upgrade. NVH has increased more so than any other upgrade that I've done.
